Specialized Sirrus 6.0 Future shock headset top cap.
Changing the spring in my Future Shock fork shock. Its the original non adjustable type. The top cap is completely flat, no allen wrench fitting, nothing. Do I jus pry this off?
Likes to Ride Far
It has a really small threaded shaft attached to the base, so it should just unscrew - turn it anticlockwise and then pull up once it's very loose because it has a rubber ring to stop it falling off even when unscrewed.
Thanks Chris! I appreciate the info, will give it ago today
Changed my spring, thanks Chris, worked like a charm
