Weird knee "pain."
Weird knee "pain."
I put the word pain in quotes, because it feels more like a muscle getting tired. It's like a pressure. I was on the trainer tonight, and after about 30 minutes of fairly hard cycling, the inside of the knee feels like a pressure, almost like it's getting tired, over stressed. if I stop pedaling, the pressure feeling goes away in about two or three seconds, like a muscle relaxing. It's the left knee, on the right side of the knee cap. It feels like the pain (or whatever you want to call it) starts directly adjacent to the knee cap, about 3/4 of an inch from the right edge of the cap, and extends down towards the shin an inch or so.
In looking at diagrams of the knee, muscles, etc, there doesn't appear to be a muscle in that location. I have no pain off the bike at all. Thoughts?
MotuekaCascadeChinook
Bikes: '20 Tarmac Disc Comp '78 Raleigh Competition GS
Quoted: 4295 Post(s)
Liked 2,850 Times
Might just be your knee telling you to slack up on the resistance for a while. If you were grinding out a steady 800 watts for those 30 minutes at 50 rpm, that's going to be more pressure on your knee than a steady 800 watts for 30 minutes at 80 rpm.
You can substitute any number you want for the avg. watts. I just pulled that out of my ....
just another gosling
Quoted: 3340 Post(s)
Liked 1,281 Times
Knees are complicated. There are many causes for this sort of thing. I encourage you to not pedal so pronated. Our knees aren't designed for that. Try to pedal with your toes pointed almost straight ahead, say no more than 5° of pronation. That'll take some practice/training because you've done it the other way for so long and sure enough, now you see the result. Could take 6 months of retraining. I also encourage you to supplement with off-the-bike exercise and stretching. The stretches I do every morning are here: https://www.bikeforums.net/road-cycl...l#post15372967 They help.
There's also a series of fix-your-knees videos on YT by the "kneesovertoesguy." I do a few of his exercises, very helpful. I walk up stairs backwards for 10 minutes (up and then down), do 3X25 reps of tibialis raises, and his split squats. That's been helpful for when my legs get out of balance. If you do the backwards walking, point your toes straight ahead, same with toe raises and split squats. It's therapy. You can search YT for the above terms.
Results matter
Results matter
I can appreciate the idea of doing some off-the-bike training to work other muscles....I think it's generally a good idea, as one can develop muscle imbalances anywhere...even the upper body. Cycling is a pretty artificial activity, unlike walking, i think it promotes imbalances.
Likes For Wattsup:
I like to get my cleats centered under the ball of my foot. Then sitting on a counter I see which direction my feet point. Whatever direction that is, the cleats are angled in the same.
Likes For Greg161:
Quoted: 1682 Post(s)
Liked 1,790 Times
Thanks. I put flats on the trainer today and didn't have the problem. Outdoors I always ride flats on a Shimano XT groupset. I think the wider q-factor helped me there...175mm. On the trainer, the q-factor is 150mm. I think that's part of the problem. I nudged by feet about 15mm off-center on the wide flat pedal today, and I had no knee issue. I'm going to purchase a pedal extenders. and see how it goes.
Likes For PeteHski:
In case anyone's interested... I think I need a cleat wedge on the left foot. How do I know? I started using flats to see if I could figure this thing out. One thing I've noticed is that I can't engage the hamstrings and butt on the problem leg as much as I can on the right leg. I thought maybe I have quad dominance on that leg, and the hams just got lazy and won't fire. In addition, the inside head of that quad is significantly bigger than the one on the right. That makes some sense, but.....I think the thing that causes it all is my left leg pronation, the foot wanting to tilt to the inside. Using flats, I found that by riding a little on the outside of the left foot, (with the foots slightly tilted, like a wedge would do) I could easily engage the left hamstrings and butt. This was after a long hard ride that tired that "muscle" or whatever it is on the inside of the knee, which is the main issue. My point is that, even after that muscle got tired, when I changed the position of my foot, I could continue cycling, without the muscle getting tired again, That, and I could engage the hamstrings and butt more.
Likes For Wattsup:
OM boy
Bikes: a bunch
Quoted: 292 Post(s)
Liked 297 Times
Depending on how marked it is, you might be able to deal with it with an interior heel wedge.
I actually had a supination issue in my younger days, and it's swung over to pronation. But whatever footbed you try, the base needs to be solid, not a cushion. That slight buildup under the heel is often just what's needed to align the ankle bones and eliminate slight pronation. I've been using the Superfeet Black for some years to take care of my pronation. I've found that up to a 2 degree cant can be effected on a good footbed.
You wouldn;t think that heel canting would make a difference in cycling, where the contact is at the BallOfoot - but it does.
Otherwise, if the pronation is more than mild, a podiatrist may be able to make a footbed which can fit into your cycling shoes.
Canting/wedging the cleats can be a process...
Ride On
Yuri
just a suggestion - Before going exterior wedge/cant, you might wanna try a hard shell footbed like the Superfeet, and put a 'wedge' under the inside heel area. Pronation is very common, especially as we age.
Ride On
Yuri
Ride On
Yuri
OM boy
Bikes: a bunch
Quoted: 292 Post(s)
Liked 297 Times
Thanks, I'll give it a try. My left knee is the problem knee, but actually, my right foot is more pronated than my left, and yet I have no issues with the right. I think what I have going on on that left leg is the pronation, but also my calf is more curved, bowed more than the right. I guess it'll be just trial an error.
You can't assume that both legs need the same rotational alignment.
Idea for most riders is to have the shoe/foot in a 'natural' posture for that leg - very individual to each leg of any person.
This assumes that your leg muscle actuation is balanced when your foot rotation is what it normally falls into when standing/walking/running... not always true, but true for most/many.
There are a number of ways to determine cleat rotation.
my method is now a little unconventional/old school... because I've used since my earliest days, riding with leather nail-on cleats and just modified the methodology as newer stuff was used.
I'll tell you what it is, but don;t be surprised if you don;t get it to work for you.
If it's a 'new' shoe (not replacement of same shoe model and size).
Make sure there are no cleats on the shoes. I put in whatever footbed I'm planning t use. I put oldschool rattrap pedals onto the cranks - same cheapish pedals you current get on a new bike, when you buy the bike - metal cage though... Wellgo pedals... preferrably with 'teeth'... LOL!
Put 3 layers of duct tape on the shoe sole approximately in the area where the REAR cage of the rat trap pedals might strike when the ball of foot is over the spindle.
Get on bike, go ride, get your shoes/feet placed on pedals with the Ball O Foot over the spindle. ride around the block 3 or 4 times, approx 1 to 1.5 miles, in a moderate gear where you're putting light but consistent pressure on the pedals.
In that time, your foot rotation will fall naturally to what your leg is accustomed to. THIS DOES NOT COMPENSATE FOR ANY MISALIGNMENT YOU MIGHT HAVE - DO TO Biomechanical issues, muscle imbalances, knock knee or bowleggedness - those need specific attention not addressed by this method.
Back to pedal rotation... in the short ride time, the rattrap pedal cages will 'mark' the tape (cages MUST be straight and parallel to spindle).
Peel up the front edge of tape to where you can cut the tape across the cage marks - leave the back part of the tape on the shoe.
Place the cleat onto the shoe and align the Ball O Foot to where the pedal spindle would be (you can figure that out).
Then rotate the cleat until the cleat aligns with the marked/cut edge of the duct tape. Cleats like SPD-SL, LOOK, are a very easy job to do this alignment.
Tighten screws. Go ride/test... Modify as needed. Pull off tape when you're satisfied...
Ride On
Yuri
EDIT: Not forgotten, but other BIG consideration in the whole foot/leg alignment and muscle actuation is 'Q' - can be very complicated and is very important.
ANother Ball of wax -
also great discussion...
Other thing which has a great effect on both leg vertical alignment and muscle actuation is cleat rotational alignment. In a big way.
Ride On
Yuri
ANother Ball of wax - 'What is Q factor'
'Q' is pretty much set by your equipment - but many people really need something other than what they have... and may/can/will have a great effect on pedaling performance/strength/comfort/injury for many...
Want more Power (How to Respect Cycling Q-Factor)
Ride On
Yuri
