Is my tire still safe?
Bikes: Trek Domane AL 5 Disc 2022
Quoted: 24 Post(s)
Liked 36 Times
GP 5000 28mm, tubetype, 'milage' around 5000Km. I actually have no idea of when this happened. I just noticed it while tinkering with my bike. Still some thread left to go, at least another 1000Km.
Liked 2,943 Times
given the option, I'd replace it.
-Oh Hey!
-Oh Hey!
Likes For Troul:
Likes For 10 Wheels:
Happy With My Bikes
Quoted: 877 Post(s)
Liked 2,302 Times
IMHO it probably isn't going to be, but it possibly could be a problem. I'd replace were it mine. If I did keep it, I'd run it on the back wheel.
Quoted: 5223 Post(s)
Liked 3,577 Times
I once rode an old bike from the '70s w/ the original tires. they were dry & cracked but I rode it anyway. after about 10 miles the sidewalls opened up & I heard cracking popping sounds as the threads broke & the tube started to bulge out the tire. turned around & made it home another 10 miles. this is nowhere near as bad as that was
Likes For rumrunn6:
Quoted: 24 Post(s)
Liked 36 Times
Right, I'll replace it then. I'll replace both, my OCD would never allow me to ride a bike with mismatched tires, and the ones I have on my stash are Pirelli P Zero's.
Thanks for the input, everyone!
Quoted: 6177 Post(s)
Liked 4,794 Times
What kind of catastrophe do you think will happen to you if you were to continue to ride it?
I have no issue with replacing it right now, but if you were to continue to use it, all that is going to happen is that you save the new tire some wear and abuse. Which is actually a positive thing. Nothing unsafe at all.
Quoted: 2026 Post(s)
Liked 1,095 Times
It is unlikely to fail catastrophically but is more likely to be susceptible to a flat so if you don't mind doing a road side repair, you could ride it a bit further. If it were mine it would be gone. 5000 km is excellent service if it was a rear tire so it doesn't owe you anything.
Quoted: 492 Post(s)
Liked 395 Times
Once the ply is exposed the rest will wear away really quick.
You can try sticking a tire boot patch inside it, but with the tire already removed, might as well slap on another one.
Quoted: 2596 Post(s)
Liked 1,923 Times
It's probably OK to ride on a smooth, clean velodrome.
On the roads I ride, any kind of glass or wire will go right through the threads and give you a flat. A nail, piece of metal, or large bottle shard will cut the exposed thread. If you notice and replace the tire immediately, no harm, no foul. If you miss it, the cut threads will form a stress riser, which can slowly cause adjacent threads to break, and the cut to enlarge, until the tire blows out.
Can you tell I'm in the "replace it ASAP" camp?
don't try this at home.
Quoted: 972 Post(s)
Liked 509 Times
No bulge when the tire is inflated? I'd use it. Cuts through the tire fabric, though, just seem to keep getting bigger.
Quoted: 567 Post(s)
Liked 562 Times
I would replace but agree with Iride01, if the cord does not look damaged which it does not in your photo the missing side wall rubber offers next to nothing in resisting circumferential or longitudinal stresses. That said a side wall blow out can be very bad especially if not in the back.
Quoted: 2975 Post(s)
Liked 1,178 Times
Tires are cheap compared to doctor bills and time off work. I would throw that out and put on a new one.
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
ahh dump it.
I wouldn't ride that. Not picking on you but the fact you are asking should be a big clue if its safe to ride. My motto is if any doubt chuck it. And I am very cheap person. But safety always first.
Liked 4,794 Times
But if one is riding down a long twisty grade at high speed and steep cliffs right on the edge of the road, then it will be prudent to change them.
Liked 1,178 Times
I've witnessed people lose control and go over the bars when the front tire flatted. Last person I saw that did this 2 years ago ended up in the hospital with a broken collar bone and head injuries.
Quoted: 24 Post(s)
Liked 36 Times
But yeah, I tend to agree that safety comes first. I already installed a fresh set of tires on the bike.
Likes For Rodrigo Kenobi:
Likes For prj71:
Likes For soyabean:
Quoted: 4789 Post(s)
Liked 3,915 Times
If I valued this tire, I`d patch it with dacron sailcloth (the real stuff from a sailmaker) with contractor's contact cement (the stuff countertops are glued down with) and ride the tire until the cords were showing through the rest of the tread. I wouldn't consider this model with 3000 miles worth that kind of effort but did this with 3/4" cut in a Vittoria Corsa with about 800 miles, did Cycle Oregon on it and rode it until it died of natural causes.
