Press fit hub, help needed
Bikes: 1987 Centurion Ironman Master, 1992 Koga Miyata Exerciser, 1992 Schwinn Crosscut
Quoted: 209 Post(s)
Liked 175 Times
I'm a noobie to press fit bearings...having experience only with balls.
Can someone tell me how to remove them from this Velomax hub?
Thanks!
Thanks!
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
They're not 'press-fit' bearings, they're cartridge bearings. You can remove the first one by tapping on the axle and it will drive the bearing out of the opposite side of the hub. Then you can put the axle in the other bearing and tap it out. You'll need bearing press tools to put new ones in.
Likes For cxwrench:
Quoted: 209 Post(s)
Liked 175 Times
Cool, thanks a ton...and for the terminology fix, also.
I did tap on the axle, but only carefully.
Then I went straight to my laptop for expert assistance!
I asume a bit of wd-40, prior to tapping, would be good, too.
Quoted: 3511 Post(s)
Liked 2,926 Times
So you need a bearing press tool to press in bearings that aren't press fit?
This may be a pressing matter.
Likes For smd4:
Quoted: 209 Post(s)
Liked 175 Times
Done deal, easy-peasy, thanks again.
I watched a video, and have the odds-and-ends to use a threaded rod and washers to re-install.
I took them out because they felt just a smidge rougher than the butter smooth rear hub.
Now out, though, they feel just fine. Can you re-lube these, maybe with Phil's Tenacious Oil?
Looking at new ones, I see different brands, and mostly a "R8-2RS" label. Is this the same as mine?
I assume the rear is the same as the front, right?
SE Wis
Quoted: 2747 Post(s)
Liked 3,394 Times
R8 is the bearing size 2RS describes the seals
https://www.skf.com/us/products/roll...tid-D%2FW%20R8
https://www.astbearings.com/bearing-closures.html
Likes For davidad:
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
You can (carefully) remove the cover with an exacto knife and put grease (not oil) in the bearings.
Maybe/probably, but I wouldn't assume it. Take a look at the numbers.
Quoted: 209 Post(s)
Liked 175 Times
Found them...they are labeled R6RS
I'll just order new, as they are quite inexpensive.
Likes For 67tony:
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
Whenever we find a new bearing size that we don't have, we order a sleave of 10 (future)
Bikes: lots
Liked 2,932 Times
Likes For cxwrench:
Guest
Liked 3,270 Times
Liked 2,969 Times
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
