For the love of English 3 speeds...
#2876
Schwinnasaur
I bought a new Kalloy 25.4mm X 350mm seat post and a Breeze plate so I could get better angular adjustment on a B72 saddle. The new post won't go in at all. The original Raleigh post goes in and I can set the height but more than moderate force is needed, especially to remove the post. Should I have the seat tube reamed? Or would it be better to sand a little from the alloy post? The new post is much longer than the original but it does not need to be. I could cut it to the same length and chamfer the bottom. The bike is a Raleigh Sports.
#2877
Quoted: 17 Post(s)
Liked 42 Times
There is some variation in post diameters but if it's the correct nominal size you should be able to fit it - and removing material from the post is better than reaming the bike.
The excess length only increases the potential of a stuck post down the line: Cut it to length and chamfer it just as you suggested.
- Auchen
- Auchen
#2879
I just wanted to say that I have been watching this thread and you lords and ladies really have something going. I've been kind of shy to get to interested because these old beauties make me miss my old Raleigh so much. And today I came across my S.A. hub cone spanner.
Underlining mine. Yes! I loved my '58 Reg Harris Lenton Sports, but I cursed that hub. I am virtually certain that I sustained a permanent injury to to its slipping into free-fall when I was standing. I was in my early teens.
In Canada I have a Miyata double butted HiTen frame tucked away in a friend's garage. I'm thinking of turning it into a sit-up 3 speed, lighting, cargo basket, chain guard and Shimano 3 speed hub on 27 inch rims.
It was the "All Steel bicycle" and for most of it's production life was fitted with a Sturmey Archer AW hub although through 1957 and 1958 it was fitted with the poorly designed and ill fated SW hub.
Vitus 979, Simplon 4 Star, Gazelle Champion Mondial, Woodrup Giro, Dawes Atlantis
#2880
This is the Sports I purchased last weekend. I swapped out the brown saddle I had purchased for the Sprite along with the rack and trunk bag. Basket is a new purchase. New tires have arrived and will be replaced as soon as I get a lesson on wheel removal.
#2881
OldBikeGuide.com
#2882
OldBikeGuide.com
Just disconnect the 3-speed gear cable and they are off.
#2884
Quoted: 17 Post(s)
Liked 42 Times
(I would recommend another SA AW hub though. I never owned a Shimano 3spd, but from what I have read, the SA's are by-far the most reliable hubs you can get.)
- Auchen
- Auchen
#2885
Schwinnasaur
#2886
Get off my lawn!
Bikes: 1917 Loomis, 1923 Rudge, 1930 Hercules Renown, 1947 Mclean, 1948 JA Holland, 1955 Hetchins, 1957 Carlton Flyer, 1962 Raleigh Sport, 1978&81 Raleigh Gomp GS', 2010 Raliegh Clubman
Quoted: 93 Post(s)
Liked 98 Times
I used leather collars, much cheaper...I mean economical.
#2887
auchencrow:
It may be awhile cuz I have to much on the go right now. But someday ... someday when I visit the hometown and fetch the frame perhaps. I readily accept that Sturmey Archer is the the most reliable, but I would avoid another SA model at all costs. AW? ... OK! Shimano does have an advantage though: I should be able to scrape one up for free. And the ground should be heaving with spares here. OK ... on order. Shimano usually takes about 4-5 working days. All the ancilliary parts are readily available too.
In Japan there are billions of Shimano hubs on mama-charis. These days, my wife and son ride uni-speeds, but we have had a couple of hand-me-down Shimano equipped 3 speeds over the years. But, they only ever came with 2 speeds working. That may support your comment. I'll be on the lookout for a Sturmey Archer to tuck away for the day I build my "black shopping bike".
#2888
Liked 7 Times
And don't you have to put the wheels back on the correct way so the hubs don't rotate apart?
https://sheldonbrown.com/raleigh.html is your bible.
#2889
Bicycle Repair Man !!!
A hub I liked, that Shimano no longer makes, is the Nexus 4 speed which appears to have been too bombproof for Shimano to keep in production.
After that... the Nexus 7 speeds are crap while the later generation Alfine 8 seems to be pretty rock solid as Shimano has worked out all the earlier bugs and will probably discontinue the 8 speed now that they have an 11 speed which has yet to prove itself.
Will a Shimano 3 speed or any of their IGH hubs run out beyond 30,000 miles ?
We know that an SA AW hub will do that in it's sleep and have a very low operating cost with nothing more than basic upkeep.
The SA AG on my winter bike is a 1964 and was NOS... it will probably take me 10 years to run it up to 30,000 miles but I expect the next decade of use will be trouble free.
#2890
#2891
The Wayfarer is running a 1954 rear hub although it is a later production bike... the hub that came with it was one of the few I had to repair as the main gear on the axle had slipped off due to the retaining pin shearing off. I had another 1954 hub at hand and just swapped the internals and the shop I got the hub from took the old guts for parts / rebuilding.
#2892
THANKS! Sixty Fiver!
#2893
Bikes: 1983 Peugeot UO14, KHS Green-Heavily modified, 1972 Raleigh Sprite 27" (work in progress)
https://www.ebay.com/itm/Raleigh-head...item19cca34282
"NEW custom fabricated metal replacement Raleigh/Sturmey Archer type headlight or head lamp mount interface "bracket" piece. "
If this guy is having new ones made it's kind of a big deal.
#2894
Just picked up my new Moulton Mk2... was given the choice of an AW, FW, or 2 speed and had to go with the stock FW 4 speed.
Should be a fun project... this is the bike after I packed it up for the ride home... the front wheel and extra alloy rims are small enough to be tucked into my rear pannier.
#2895
Hopelessly addicted...
Bikes: 1949 Hercules Kestrel, 1950 Norman Rapide, 1970 Schwinn Collegiate, 1972 Peugeot UE-8, 1976 Raleigh Sports, 1977 Raleigh Sports, 1977 Jack Taylor Tandem, 1984 Davidson Tandem, 2010 Bilenky "BQ" 650B Constructeur Tandem, 2011 Linus Mixte
Liked 10 Times
That really does sound like a fun project. Probably the only thing that could make that project more fun would be for you to have had the choice of a Sturmey FG thrown into the mix!
#2896
Liked 10 Times
I think I may have posted this in its previous incarnation, but here is my 1956 Hercules Royal Prince after some additional polish and spit-shining. I am really happy to have gotten rid of the Wald fender stays...
1956 Hercules Royal Prince - The Evolution - 13 by Sallad Rialb, on Flickr
1956 Hercules Royal Prince - The Evolution - 5 by Sallad Rialb, on Flickr
#2897
Quoted: 478 Post(s)
Liked 634 Times
Fantastic Herc....I agree - wire stays look more elegant (IMO), though they are hard to keep straight. Is that a 22T sprocket on the back? If so, did you have to add links to the chain to make it work?
#2898
Would not rule out the 3 speed fixed option or a 5 speed IGH at some point either.
#2899
#2900
Liked 10 Times
As far as the cog, that's a 24t. I bought a dozen from an eBay seller in Germany. Where I live we have hills and I'd not be able to get up any of them without pushing were it not for that cog. When I first got the bike I replaced the chain, and put a 22t cog on at that time, so I did not need to add any length to the chain. Typically if you're going from the normally installed cogs (18 or 19 ime), you'd need to replace the chain or add links to the existing chain.
