Go Back  Bike Forums > Bike Forums > Training & Nutrition
Garmin Training Status: Unproductive
Training & Nutrition Learn how to develop a training schedule that's good for you. What should you eat and drink on your ride? Learn everything you need to know about training and nutrition here.
Old 08-11-22, 01:57 PM
Seattle Forrest
Seattle Forrest's Avatar
Quoted: 18883 Post(s)
Liked 10,646 Times in 6,054 Posts
Originally Posted by terrymorse
Thanks.
I re-linked the GARMIN unit with my iPhone via Bluetooth, maybe that will get the feature working again.
I use Android and don't know iOS well enough to go deep into the details. But your phone should have some kind of list of apps with the permissions you allow them. The answer is almost certainly there. This comes up fairly often on r/Garmin and that seems to usually be the solution. I hope it helps. 🙂
Edit to add: the "heat acclimation" is ... you're probably not missing much there. But correctly adjusted VO2max is probably worth having if you use that feature or the training summary based on it.
Seattle Forrest is offline
Old 08-18-22, 02:44 PM
Iride01
Iride01's Avatar
Quoted: 6193 Post(s)
Liked 4,809 Times in 3,317 Posts
Maybe I should just leave this thread alone, but today I may have figured out something somewhat related to an issue the OP referenced.
I to generally will get a "high aerobic shortage" when it's not giving me a cue about something else in the Garmin phone app. Today I was actually on Garmin Connects website comparing some things with RWGPS which is what I normally rely on for post ride data review.
I noticed that the times in HR Zones of GC were way off compared to RWGPS. Garmin Connect had my max HR at 210 bpm instead of the more correct 175. So that means I'd never get into the high aerobic or even anaerobic zones.
So possibly the OP needs to check their max HR setting in GC. I think mine got messed up a short while back when my strap went bad and I had to get another. Possibly my Edge 530 ask me about whether I wanted to record a new max HR as it does some other things. But if it did, I just mindlessly accepted that so I could get on to seeing the other things I look at on my Edge immediately before I dismount and go in the house.
Iride01 is offline
