Dura-Ace FH-7403 question
Bikes: BMC Road V2; '17 Marin Pine Mountain 2; '91 Marinoni Special TSX; '89 Specialized Stumpjumper Comp; '98 Salsa La Cruz; '79 Centurion Pro Tour; '77 Romic custom sport-tour; '77 Centurion Semi-Pro; '23 Kona Sutra LTD
Quoted: 62 Post(s)
Liked 220 Times
I have a couple of Dura-Ace 7400 series hubs, and the FH7403 (the one that can take a hyperglide cassette with the mushroom locknut that help it press a 126mm spacing out to 130mm) has one quirk that is really frustrating.
It seems that, in order to tighten or remove the lockring with a typical lockring tool like the TL-FW30, I need to remove the axle (because of the size of the mushroom lock nut). A typical lockring tool just doesn't have the internal diameter to get over the mushroom locknut. I'm wondering if there is a lockring tool that has a large enough internal diameter to get around the mushroom lock nut--do I need to track down an old TL-HG15 or is there something I'm missing when it comes to using a hyperglide cassette on this particular hub? Maybe there's an obvious solution I'm just failing to recognize?
This old FH-7403 instruction page says that both the TL-HG15 and the TL-FW30 can be used, but my experience has been the TL-FW30 requires the added step of removing the axle (and then needing to repack the bearings & adjust the lock nuts every time a cassette is replaced). https://manualzz.com/doc/53871484/sh...e-instructions
blahblahblah chrome moly
Quoted: 1172 Post(s)
Liked 2,567 Times
Maybe sand a little off the locknut by spinning it up against a belt sander (poor man's lathe), and/or take a little off the ID of your tool like with a sanding drum in a drill or dremel.
Mark B
Likes For bulgie:
Quoted: 62 Post(s)
Liked 220 Times
Interesting idea; I hadn't really thought about dremelling out the inside of a lockring tool. My immediate worry is thinning out the metal to the point of failure, but that's without checking to see how much is there to remove. It could also be that my lockring tool is sort of a mess after so many years of use--I should probably just get the dang thing out and see if it needs to be replaced.
Quoted: 33 Post(s)
Liked 125 Times
Maybe use a readily available aftermarket lockring tool, rather than the Shimano freewheel tool? I don't recall having any problem with mine with this kind of tool.
Likes For Seanaus:
Catching Smallmouth
Bikes: 1990 Specialized Sirrus Triple, 1985 Trek 460, 2005 Lemond Tourmalet, 1984 Schwinn LeTour 'Luxe, 1988 Trek 400T, 1985 Trek 450, 1997 Lemond Zurich, 1993 Diamond Back Apex, 1988 Schwinn Circuit, 1988 Schwinn Prologue, 1978 Trek TX700, Sannino
Quoted: 88 Post(s)
Liked 134 Times
I have a couple 7403 hubs currently in service. I've got a tool like this one. I don't know what brand it is but I've never had a problem.
Likes For BradH:
Quoted: 4722 Post(s)
Liked 3,036 Times
If the hub has been taken apart, it's possible that the locknuts were installed on the wrong side, as both locknuts are not the same.The non-drive side (NDS) locknut has a larger diameter (by ~0.031") and a deeper bevel. The TL-FW30 will not fit over it. If your tool fits over the locknut currently installed on the non-drive side, then the locknuts have been switched, side for side.
Edit: The non-drive side locknut dfoes not fit into either of my two Shimano TL-FW30 or my Park tool. It's a light interference fit with mu LIfu.
Last edited by T-Mar; 09-29-22 at 07:55 AM. Reason: added tool comparison and photos
Quoted: 377 Post(s)
Liked 535 Times
I got a set of DA wheels in a package trade that not only had the nuts swapped but they were both on backwards. The WTF? moment was very special. All in all it was actually a dyno deal and def good for a laugh.
Likes For Steel Charlie:
Master Parts Rearranger
Quoted: 1556 Post(s)
Liked 2,024 Times
Learned something new today! Glad both of my 7403 hubs that came to me were overhauled correctly in the past. I can confirm I've never had an issue with using any normal Shimano FH lockring tool on them. Love these hubs.
Likes For RiddleOfSteel:
Liked 3,036 Times
Likes For T-Mar:
Quoted: 1607 Post(s)
Liked 2,216 Times
I was in the process of accepting DA as a quality, durable product until two things happened.
1. The piece that keeps the adjustment screws on the FD failed and fell off.
2. FH-7403 cone RS1 2 on Flickr
1. is minor and can be addressed with something else than the original part.
2. Does not have an easy solution without extravagant $ outlay for a near commodity like part due to lack of supply of a unique design. Leads one to think it was designed to be disposable.
I will stick with the Campagnolo components which I have a higher level of acceptance of failure because I have found parts or alternative solutions. Just my preference. No problem with others choosing other brands.
Quoted: 62 Post(s)
Liked 220 Times
Quoted: 62 Post(s)
Liked 220 Times
Unfortunately, the locknuts are installed correctly; or, to be more specific, the NDS locknut is on the correct side. I think the DS locknut on my hub is wrong, possibly the wrong type and size installed during someone's haphazard hub overhaul. I'll take the hub apart & see what's going on--and post pics, of course.
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
https://www.amazon.com/Hozan-Tapered.../dp/B002TKEHVM
