Light code Flagpole’s
Any recommendations for a light that can be mounted to a fiberglass flag pole for my trike?
Thanks
Dave
Thanks
Dave
Quoted: 569 Post(s)
Liked 581 Times
Looking forward to any favorable relies as it might help but be difficult t do.
Half way there
Quoted: 986 Post(s)
Liked 880 Times
Perhaps one of these ICE headrest adaptors would work for you. Then you could mount any light. You could probably make one out of a wood dowel of suitable diameter. Yet another reason to invest in a 3d printer,
Likes For jays35:
Half way there
Quoted: 986 Post(s)
Liked 880 Times
I had another thought: Those non-cork plastic/rubber type wine corks might work if you drilled a hole to fit the pole. And it's a good excuse for some imbibing.
Quoted: 523 Post(s)
Liked 229 Times
Duplicate post - see Electronics-lighting-gadgets
Since this same question was posted in the Electronics-lighting-gadget section you can see a much simpler answer https://www.bikeforums.net/electroni...lag-poles.html
BTW while ICE accessories are nicely designed, the prices are quite pricey. I can't imagine spending $48 for just the mount used to add a Mirrycle bike mirror to the trike.
I cut two scraps of gray PVC pipe about 6"-7" long and zip tied or used 'O' rings to attach them to the two neck rest supports on my trike: one for a small bag attachment and the other for my Garmin Varia radar blinky. I don't think attaching a light to the flag staff is the way to go. I use neon streamers, which are highly visible, rather than a flag. A roll of neon streamer material is inexpensive and available at most hardware stores.
