Huffy + Campagnolo Super Record = The Ultimate C&V Sacrilege build
Old 05-31-23, 10:27 AM
  #1601
dddd
Ride, Wrench, Swap, Race
dddd's Avatar
Quoted: 1476 Post(s)
Liked 1,138 Times in 769 Posts
This well-developed project is truly a lesson in time/cost-no-object perseverence, which I'm sure has been therapeutic if you have anything like a "typical" day job.
I enjoyed seeing all of the obstacles overcome, one by one. The arrival of the brazing torches took it to the next level!
I'm really not surprised that it's a great-riding bike, especially if the frame dimensions fit you. I believe (based on my own measurements of 22- and 23-inch frames) that Huffy shared the time-proven geometry from Schwinn's electro-forged models, so how could it not ride well, comfortably so, once the saddle and handlebar cockpit are up to standards?
This thing is a rolling conversation piece.
I'm looking forward to the many photos that this project deserves, including (hopefully) the look on people's faces as they take in this bike during inspection.
I'm guessing at this bike weighing 27-28 pounds.
The right/rear brake cable would normally rest to the other side of the stem, but with such a short stem it might need to be tucked under the front brake's cable to stay there, and which might necessitate a bit of shortening of the front brake housing to equalize the loops(???)...
If the steering is twitchy it might only be because of a slow speed exacerbating the steering flop factor of the 70-degree HT angle, otherwise I would check the headset bearing tension with the front wheel removed or with the headtube held at 90-degrees (i.e. vertical) to discern any bearing drag.
Best wishes on your big weekend going well, hopefully you'll have time to get everything feeling fully sorted by then.
The spoke nipples need fixing, I have a few tricks I use to get them turning.
First is to lubricate them from both ends using your best penetrant, don't forget the rim-seating area which by itself can effect a LOT of torsional resistance to turning.
Allow said penetrant some time to work if possible.
Apply wrench torque using a slightly-undersized spoke wrench, in both directions. Then do the same on the other pair of flats. Repeat.
Failing the above attempts to get the nipple moving, apply a smooth-jawed Vice-Grip to a pair of flats, but slide it down to meet the rim first. Then squeeze, then twist, first in one direction and then the other. Repeat. Then move 90-degrees and squeeze the other pair of flats. Then twist back and forth again This ovalizes the threaded bore, allowing the threads to free up and the penetrant to migrate.
The idea here is not to exceed the torsional strength of the spoke with any one twist.
Lastly, apply a pencil-point torch tip to the nipple, but not to the spoke which might lose it's temper. Then quickly apply wrench or Vice-Grip torque to one set of flats and then to the other. Again, this works the bore of the nipple a bit, allowing the corrosive bond to break.
A spoke nipple that has damaged flats can be turned using a well-fitting screwdriver blade, in concert with whatever wrench torque can be applied to the damaged flats. A Vice-Grip often offers some last-resort grip and torque on a damaged nipple.
Be sure to have some spare nipples handy with the exact same wrench-size (Japanese, Euro, DT in descending size order), and replace any bad ones. I forced (sliding action toward the rim) the Green "Euro" wrench onto the Japanese spoke nipples yesterday, with good results.
An ovalized spoke nipple can still have torque applied using the other set of flats, or the original set of flats when applying reverse-torque (assuming it was first damaged in the tightening direction).
Lastly, before adjusting any damaged or heavily-tight spoke, always first check what's going on with it's neighboring spokes on the same side of the wheel, using comparative spoke-plucking tone (with a finger held against any crossing/touching spoke to damp it's also ringing). Also check the two closest opposite-side spokes for their comparative tension along that side of the wheel. The spoke tension uniformity should thus only improve as a wheel is dished and trued (an efficient builder is thus making the rim run truer and the spoke tensions more uniform at the same time).
I spent some hours over the last couple of days fighting with having to re-dish an old, weathered rear wheel and a mis-dished front wheel. A lotta time spent on those two wheels so it's still all-too-fresh in my recollections!
dddd is offline
Likes For dddd:
Old 05-31-23, 10:38 AM
  #1602
billytwosheds
billytwosheds's Avatar
Bikes: Peugeot, Legnano, Fuji, Zunow, De Rosa, Miyata, Bianchi, Pinarello, Specialized, Bridgestone, Cinelli
Quoted: 393 Post(s)
Liked 357 Times in 170 Posts
Hell ya. I'd ride it.
We're gonna need a full set of pics though. Perhaps you can fly jamesdak or alexihnen out to do it. Just to be over the top about it.
Cheers.
billytwosheds is offline
Old 05-31-23, 12:23 PM
  #1603
stoneageyosh
Bikes: Dave Tesch Model 100 Custom Reynolds 753 / Custom Panasonic built by Takao Ono (1973)
Quoted: 60 Post(s)
Liked 122 Times in 76 Posts
Originally Posted by smd4
The derailleur cable tension should keep everything together for a while...
Oh, good thought. That means the quantity of stuff that goes BOOM!! for mid-cartwheel disassembly can be reduced which will allow the use of a smaller SpaceX launch vehicle.
stoneageyosh is offline
Old 05-31-23, 12:53 PM
  #1604
SurferRosa
señor miembro
SurferRosa's Avatar
Bikes: '70s - '80s Campagnolo
Quoted: 3519 Post(s)
Liked 5,655 Times in 2,843 Posts
Originally Posted by AdventureManCO
There has to be a better solution than that to bring the finishing tape/thread over to the bar sleeve.
SurferRosa is online now
Likes For SurferRosa:
Old 05-31-23, 01:01 PM
  #1605
AdventureManCO
AdventureManCO's Avatar
Bikes: The Campagnolo Huffy w/ Home Depot tubulars
Quoted: 923 Post(s)
Liked 2,714 Times in 1,057 Posts
There is - get me some 90”+ bar wrap and I’ll put it on
Rarer than a Confente...it's the Huffente!
AdventureManCO is offline
Old 05-31-23, 01:04 PM
  #1606
Eric F
Habitual User
Eric F's Avatar
Bikes: 2019 Trek Procliber 9.9 SL, 2018 Storck Fascenario.3 Platinum, 2017 Bear Big Rock 1, 2003 Time VX Special Pro, 2001 Colnago VIP, 1999 Trek 9900 singlespeed, 1977 Nishiki ONP
Quoted: 4060 Post(s)
Liked 6,523 Times in 3,099 Posts
Agreed. For a bike that has had so much attention paid to details, that gap seems quite unacceptable.
Eric F is offline
Likes For Eric F:
Old 05-31-23, 01:40 PM
  #1607
AdventureManCO
Quoted: 923 Post(s)
Is that really a faux pas?
I guess you learn something every day!
I’m going to be stopping by the leather store on the way home for some toe clip material. If I get 1.5” width what length should I be looking for?
Old 05-31-23, 01:57 PM
  #1608
Eric F
Habitual User
Eric F's Avatar
IMO...Yes. The handlebar wrap should finish butted up to the center sleeve section of the handlebar. If finishing with tape, the tape should be centered over the joint between the tape and center section. Personally, I think the rough-ish edge of the leather you used looks out of character when compared with how well-finished the rest of the parts on the bike are. My preference would be for a manufactured leather bar wrap. I understand that others may have a very different opinion.
I have zero idea what length is typical for handlebar tape.
Eric F is offline
Likes For Eric F:
Old 05-31-23, 02:28 PM
  #1609
smd4
Quoted: 2687 Post(s)
Liked 2,222 Times in 1,348 Posts
Definitely. Some of the wrap overlaps look pretty large--can you stretch the tape out any more to get to the sleeve without resorting to new tape? Then cut the end of the tape at an angle to completely butt up against the sleeve.
smd4 is online now
Old 05-31-23, 02:32 PM
  #1610
stoneageyosh
Quoted: 60 Post(s)
Being a fishing rod builder/wrapper in a parallel universe I would consider wrapping the offensive bare sections with rod guide wrapping thread in red, white and blue bands. The outer band can be made to climb the end of the leather wrap to secure it. Using a bobbin will make it fairly easy to wrap the bar. Apply rod finish to bind the thread.
Edit:
Thread colors could be five, world champion or just red and white.
Old 05-31-23, 03:52 PM
  #1611
AdventureManCO
Quoted: 923 Post(s)
Alright y’all convinced me. If these aren’t long enough, I will stitch them together with the other ones under the hoods.
Old 05-31-23, 04:08 PM
  #1612
Mad Honk
Quoted: 1159 Post(s)
Liked 1,528 Times in 941 Posts
Cheers.
Alex has likely ridden more than one AMF bike in his tenure. (I know I did when I was the Mechanical Steward of the race.) So he should know how to handle this ruffian of a bike. When will he be booked on a flight? Smiles, MH
Mad Honk is offline
Old 05-31-23, 04:54 PM
  #1613
SurferRosa
señor miembro
SurferRosa's Avatar
Looks more appropriate for toe clip straps.
Old 05-31-23, 04:58 PM
  #1614
smd4
If you don't know the "cutting the tape on an angle" trick, it goes something like this:
When wrapping bottom to top, approaching the sleeve looks a little like this:
As you near the sleeve, continue wrapping at the same angle, but cut the edge of the tape parallel to the sleave:
Roll the tape right up to the edge of the sleeve:
Finish how you see fit. I use electrical or silicon self-adhesive tape. I don't overlap the sleeve, but I don't see that being a problem unless it covers any graphics:
smd4 is online now
Likes For smd4:
Old 05-31-23, 07:17 PM
  #1615
AdventureManCO
Quoted: 923 Post(s)
My hands are destroyed for the day and I still have one more full side to go.
I know some of you are dubious about the leather wrap and that’s fine. It’s not tradition and that’s probably a big reason. I like it and it looks better the more it ages. It looks really raw and naked when you first out it on but shows more and more character the more you interact with it. It isn’t a good match with the saddle now but will be eventually.
Likes For AdventureManCO:
Old 05-31-23, 07:18 PM
  #1616
AdventureManCO
Quoted: 923 Post(s)
Thank you for that. Yep this is the method I used.
Old 05-31-23, 07:22 PM
  #1617
smd4
Muuuuch better. I like the leather. It’ll look great as it’s used—and absorbs the sweat pedaling that beast will generate. Going to the sleeve will give you added hand positions. I’ve got some leather tape I want to use myself.
smd4 is online now
Likes For smd4:
Old 05-31-23, 07:28 PM
  #1618
AdventureManCO
Quoted: 923 Post(s)
Got some for that too, which means it will be matching!
It is an aberration, just like a Super Record Huffy. I actually like the way it feels. It’s soft in a firm way; not harsh.
EDIT: Totally misread your post! You probably saw that in the picture there was some leather that was stubby and thick. That is indeed for toe straps.
Sorry bout that. I'm beat and used up. Just in time to ride 100mi. I suppose it wouldn't have the same meaning if it wasn't a struggle. Thanks for your continued interest and support!
Old 05-31-23, 07:44 PM
  #1619
dddd
dddd's Avatar
Yet another struggle overcome.
Destroyed hands indeed!
How many pounds of tension did you apply to that second go at tape wrapping?
At least it won't have any tendency towards slipping on the bar!
dddd is offline
Likes For dddd:
Old 05-31-23, 07:53 PM
  #1620
Mad Honk
Do you need the brake hoods for those levers? I get the ones from Dennis in CA. smiles, MH
Mad Honk is offline
Likes For Mad Honk:
Old 05-31-23, 08:46 PM
  #1621
Macguyver909
Bikes: '56 Raleigh sports, 70's Raleigh International
Quoted: 23 Post(s)
Liked 43 Times in 19 Posts
Forks bent!
Macguyver909 is offline
Likes For Macguyver909:
Old 05-31-23, 08:49 PM
  #1622
Eric F
Habitual User
Eric F's Avatar
That looks better! 👍😀
Eric F is offline
Old 05-31-23, 09:19 PM
  #1623
AdventureManCO
Quoted: 923 Post(s)
This reminds me - I should check the mail.
Old 05-31-23, 10:41 PM
  #1624
AdventureManCO
Quoted: 923 Post(s)
Well, another day, another round of pain and suffering. Lol it just never seems to end with this thing. After all this, it will be the rear wheel. After that, something else I'm sure!
I thought I'd maybe get at least a day to rest from the bike constantly nagging me, but it looks like that's not going to happen
Today it was the bar tape, tomorrow it will be the cages. Still need a water bottle cage mounted. Still don't have a stand. Heck, I don't even have biking shorts yet
We're gonna be riding into this thing on a wing and a prayer!
See the different coloration? On the previous leather wrap, I split a wider piece of leather, so it was from the same piece. These are two completely different pieces, so they are going to react to everything just a bit differently. I chose the both because they were closest to the same color in the store. Well we see how that worked out haha. But, I kinda like it. Adds a bit of quirk to the bike, and it will probably become more subtle as the leather darkens with age, use, and sunlight.
I'm pleased with out the wrap came out - I'm very thankful it is somewhat symmetrical.
That's all for tonight, my hands are feeling it. Tomorrow, the work wont stop. I really need to think about a stand...
Mad Honk I got your piece of plexiglass in the mail the other day, thank you! Can I just mimick those rear alloy stands that go in the rear? How do those work, does it just mount on the NDS where the axle cone nuts are?
Old 05-31-23, 11:15 PM
  #1625
Steel1
Quoted: 35 Post(s)
Liked 80 Times in 36 Posts
I took my hands off the bars...the bike no longer tried to violently throw me off. It rode straight and true, and dare I say, 'nimbly'
It would be cool if you could recreate the Huffy Aerowind commercial… wearing sandals.
I don’t even know where to begin. Thank you or berate you?
This thread has stimulated conversations, while at the same time disturbing the harmony of my own household. My young daughter sent me this text while I was at work today.
Thats a real screenshot, btw. I think she will get over it (with time, lots of therapy, and possibly inheriting one of my bikes some day).
Steel1 is offline
Likes For Steel1:
