Tires- Tube or tubeless?
Expired Member
Quoted: 3559 Post(s)
Liked 5,119 Times
What's on it now?
Likes For Billydog:
Expired Member
Liked 5,119 Times
Tube or tubeless and what size?
Likes For fooferdoggie:
How come these tires look like they hardly have any tread?
Continental Grand Prix
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2013 Post(s)
Liked 4,068 Times
He IS correct
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For rsbob:
Quoted: 2152 Post(s)
Liked 2,423 Times
stay with tubes and tires (make sured tires are not tubeless ready tires). you can convert non tubeless rims to tubless but it is not pretty or reliable especially for road rims
Likes For squirtdad:
Veteran, Pacifist
Quoted: 3669 Post(s)
Liked 4,123 Times
Tires for a vintage drop handlebar race/road bike? Tubulars = best.
Clark W. Griswold
Quoted: 3915 Post(s)
Liked 3,382 Times
I would semi-agree-ish with Wildwood but in the end open tubulars would probably be the most sensible option for most people these days. It gives you the handmade casing and feel of a tubular with the ease of a clincher for tire removal and tube replacement.
Quoted: 432 Post(s)
Liked 539 Times
"open tubulars" is really just a marketing term for high-end clincher tires. Back in the day all clinchers were relatively heavy with casings that were not very compliant. These days there are plenty of tubed tires with highly compliant casings and light weight. Some companies call these "open tubulars" because the casings are similar to what a good tubular uses. Other companies have the equivalent performance tire but don't describe it as an open tubular.
Clark W. Griswold
Liked 3,382 Times
Yes there are some clinchers that are quite good light and compliant but they are not built the same as a tubular so hence not an open tubular.
Not everything is just marketing and even if it was not all marketing is always terrible. I am quite happy with the ride of open tubulars marketing or not they ride quite nicely and look good.
Habitual User
Bikes: 2019 Trek Procliber 9.9 SL, 2018 Storck Fascenario.3 Platinum, 2017 Bear Big Rock 1, 2003 Time VX Special Pro, 2001 Colnago VIP, 1999 Trek 9900 singlespeed, 1977 Nishiki ONP
Quoted: 4060 Post(s)
Liked 6,514 Times
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 979 Post(s)
Liked 174 Times
Misnomer for tubeless is that they are lighter than tube type, and when you first use tubeless that is true, but every 3 to 6 months you have to put in fresh sealant, the first time you add sealant that tire will weigh the same or more than a tube tire will be, and the second time you have to add sealant after the initial application you will definitely weigh more than a tubed tire.
Mounting a tubeless tire can be a *****, they are extremely tight fitting which is necessary to make a solid seal against the rim, but in the mean time you're cussing like a Marine. Then you have to have a special pump designed for tubeless tires, because you need a blast of air to seat the bead onto the rim.
Now you can begin to see that a tubeless set up is more expensive, the tires and wheels are more expensive, you have to buy sealant, you have to buy a special pump, money money money.
Going tubeless means, you may need to carry extra sealant, tubeless plugs, a sewing kit, super glue, and a high-volume pump to repair a large puncture or sidewall tear. You’ll also need a spare tube or two in case you can’t make the tire airtight after making the repair. All of this gear adds weight and costs. Things to consider if you are considering to go tubeless.
A lot of other forums I've been on some people who have gone tubeless are quietly switching back.
Quoted: 6499 Post(s)
Liked 10,144 Times
Likes For Koyote:
Quoted: 996 Post(s)
Liked 1,041 Times
Quoted: 979 Post(s)
Liked 174 Times
At least you have a open mind on the subject! In reality tubeless is great and there is a reason why it is so popular with most engaged cyclists. I could disassemble your screed one exaggeration at a time but not sure it is necessary given how obvious the flaws are.
An endless FAQ to tubeless bicycle tyres - CyclingTips
Tube Vs Tubeless Bike Tires: Pros and Cons - Where The Road Forks
The internet listings go on and on, but I guess I ran into a religious zealot.
Liked 10,144 Times
geez.
Likes For Koyote:
Habitual User
Liked 6,514 Times
I’m going by my actual experience with multiple bikes, not an article I read somewhere.
Likes For Eric F:
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 11231 Post(s)
Liked 6,199 Times
You really shouldn't have any more than 60 grams of liquid sealant in a 28mm road tire. If you ride 5000 miles a year you'll likely only top off sealant twice before you get a new rear tire. Let's say 50 grams dried sealant and 60 grams liquid sealant in the tire after one year. Add the valve stem 7 grams. 117 grams tubeless, I run 80 gram tubes in my road tires, so 37 gram weight penalty at the end of one year in order to not have to change a tube for 90% of punctures. Pretty good trade off there.
I carry a spare tube whether riding tubeless or tubed. It's a wash on that account. On long solo centuries on a tubed bike, I'd carry a patch kit, two spare tubes and a spare tire.
An air compressor is handy for other things besides installing tubeless, might as well get one.
Likes For LesterOfPuppets:
Bikes: Lynskey R350, Ritchey Breakaway, Ritchey Double Switchback, Lynskey Ridgeline, ICAN Fatbike
Quoted: 340 Post(s)
Liked 398 Times
Your use of this word is a misnomer.
Also, your information is false. How many miles have you ridden on tubeless road tires?
Every single flat I have seen on group rides for the past three years has been a tube, and the tires are split about 50/50.
I now carry only a plug kit and a couple of CO2 cartridges. I also have had a puncture on a solo ride this year and I didn't know it had happened until I went to top up the tires the next morning and they were down 20 psi. That and the sealant on the frame were the only clues.
