Addiction 2021.4
#551
Mostly Harmless
Bikes: Have two wheels
Quoted: 13694 Post(s)
Liked 4,520 Times
The cheap aluminum cages I have on some of my bikes and collecting dust in parts bins do not have names. Although some of them have bike shop names printed on them.
#553
Quoted: 9652 Post(s)
Liked 6,363 Times
I just did a telemedicine visit with a patient who is also a fellow cyclist. He said he knows FOUR cyclists who have been killed while riding, including an ex co-worker who got hit head-on by a car that crossed the center lane recently. He said he is pretty much done with road cycling due to safety concerns. I told him I respect that decision. Sad.
#554
Mostly Harmless
Liked 4,520 Times
#555
Mostly Harmless
Liked 4,520 Times
#556
Tacx Tao was also a cheaper winner, but people complained the plastic tabs on the bottom broke off. Didn't happen to me. I think they got discontinued.
#557
Klaatu..Verata..Necktie?
Quoted: 10397 Post(s)
Liked 11,859 Times
I have about half a dozen cheap white aluminum cages taken off my C&V bikes. Half of them are marked "Specialized". I'm not a big fan of the cheap white aluminum bottle cages.
#558
Quoted: 20808 Post(s)
Liked 9,450 Times
My current night rider has the rubber strap that you have to stretch around the bar, the Madone SLR bars are too wide for it to stretch around.
Are light manufactures creating all quick release equal? I wouldn’t thing my night rider could fit the the bontrager light mount.
Are the backs of garmin and wahoo the same? I was under the impression they would be different, to the point a garmin mount wouldn’t match a wahoo and wahoo mount wouldn’t match a garmin. The bars come with the mount on the picture for a garmin, to fit a wahoo I would have to buy an after market mount. The only one that I have found that will do the above set up is through trek and it basically turns the wahoo from 280.00 dollars to 350.00 dollars.
No, not all lights have the same quick release plate, but (last I looked) Bontrager had a few different ones out there - I recall that my stem came with one or two. You'll have to check your light when you get home. It might be just the band and no release, which would be a bummer. I lost the other post, though - you were saying that you wouldn't be able to get something else because you were thinking that you needed the new light. Was that just a budget thing or attaching it all to your bike thing?
Yeah, the Garmin QR plates and Wahoo QR plates are the same, just 90° offset. When I went from the old Bolt to the 530, I kept my out-front mount but was able to unscrew it, turn it 90° and screw it back in (it had two sets of screw holes, probably for just this kind of flexibility/manufacturing ease).
Oh, and FWIW, it looks like K-Edge is making mounts for those Madone bars, with or without the GoPro mount underneath, which can be used for a variety of lights or cameras, with the proper adapter.
#559
Mostly Harmless
Liked 4,520 Times
#560
#561
Habitual User
Quoted: 4929 Post(s)
Liked 8,062 Times
Aluminum will eventually fail due to fatigue. It is the nature of the material, regardless what it is used for. The higher the load of the cycles, the faster it will fail.
It's rare to see aluminum bats in the softball world these days, beyond the very youngest age groups playing in their local rec league. My daughter's HS team has some old team bats that are aluminum, but no one really uses them. My daughter has been armed with composite bats since she was 9. I have no idea if youth baseball is the same or not. They seem to change the regulations on bats every couple of years, and I have no idea what the current standards are.
#562
Liked 11,859 Times
#563
Habitual User
Liked 8,062 Times
#564
Mostly Harmless
Liked 4,520 Times
#565
#566
Quoted: 10236 Post(s)
Liked 5,181 Times
Getting back to this because I forgot about it after seeing it last light night:
It was a budget thing. Comes down to where my night rider will work or not. If it works, then I don’t have to get a light set specifically for the madone, which would free up money for the varia. If it doesn’t then the light set would take the place of the varia.
Similiar with the wahoo. If I can get it to work with the mount provided then that’s great, but if I have to get the k-edge I don’t see the benefit of the wahoo.
After doing more research I’m leaning towards the 530 as it is.
I have other options to play around with cost as well. I don’t have to get the kickr, I can go the core route which would free up some more money.
When the bike comes in, and I test ride it, I then have to decide If I even like the 58. I know the stem and the bars that come on it are going to be too long and to wide, But the bike might still be too big for my liking.
If I go with it, i’ll order the slr bars I’m thinking i’ll need a 90 stem and 40 wide bars, and I will have them do a complete cost of everything. Kickr, computer, bars, cages, lights, varia, cassette for the kickr (9 speed) to see what it comes to. When I placed the order he said he would give me 10 percent off everything which would help. It needs to come to around 9400 after taxes so I can still get the left arm power meter for the cervelo. I havnt talked to him yet if I can get that through him, might have to order that from power meter city.
Likes For bampilot06:
#567
Habitual User
Liked 8,062 Times
EDIT: Here's a reasonable example of how my daughter's bat sounds. I've found the recorded sound varies a LOT depending on which device I'm using . This sounds a lot like what my ears hear...
#568
Liked 5,181 Times
#569
Habitual User
Liked 8,062 Times
Softball has regulations, too, and bats get checked at the bigger events. However, it's not nearly as nutty as LL baseball. I'm, fairly convinced the frequent reg changes are driven by the bat manufacturers. Change the rules, and everyone is buying a new $400 bat for their kid.
#570
So it is
Quoted: 11393 Post(s)
Liked 4,734 Times
Likes For LAJ:
#571
So it is
Liked 4,734 Times
Likes For LAJ:
#572
So it is
Liked 4,734 Times
I go Serfas and Blackburn, because I trust them. I have to go with what holds those bottles in based on the garbage dirt we have to race on.
#573
Administrator
Quoted: 11954 Post(s)
Liked 6,611 Times
#youasked
#574
Liked 9,450 Times
The 530 is a good unit. I don't think that you could really go wrong between the two, either way. I do like the fact that the Garmin does ANT+ light control, though, which is nice for the Varia and even better if the headlight is compatible, too. Nav is slightly better, too. Wahoo set-up is a little easier, but you do that once, really - big whoop.
#575
Liked 9,450 Times
