Will my Zac 19 rims convert to Tubeless?
Old 03-25-22, 07:45 PM
BikingViking793
Bikes: 2015 Felt Z75 Disc, 2008 Fuji Cross Comp, 2010 Trek Navigator 1.0, 1974 Raleigh Sports, 1974 Schwinn Le Tour, 1981 Schwinn Super Le Tour, Surly Cross Check, 2021 Giant Talon 2
Quoted: 202 Post(s)
Liked 71 Times in 60 Posts
I have Weinmann Zac 19 rims and 700x32 tubeless ready tires. Can I convert these rims to tubeless without issues? I've read you can convert about any rim but want to check opinions before I give it a try. This would be my first tubeless attempt. I don't want to try and fail because I never really had a chance it would work. Here are the rims for more info:
Wheel Master Weinmann Zac 19 Wheels 700c – Frugal Average Bicyclist
This is going on a Surly Cross Check btw.
check out the Frugal Average Bicyclist
Frugal Average Bicyclist – The goal here is to help you keep cycling on a budget.
BikingViking793 is offline
Old 03-27-22, 09:54 AM
BikingViking793
Quoted: 202 Post(s)
Hmmm…. Did I post this in the wrong forum?
Old 03-27-22, 10:49 AM
masi61
masi61's Avatar
Quoted: 1163 Post(s)
Liked 442 Times in 315 Posts
I suspect you will have issues setting these up tubeless. In the last photo where it shows the inner and outer dimension, you get the cross section of the interior rim extrusion - it does not have a square shelf out at the edges of the interior that are necessary to provide a native tubeless leak free tire fitting.
I've read about a company that makes air bladders that seal the inside of the rim to make any rim tubeless compatible but that falls into the "ghetto tubeless" category, So if you are willing to do the work to get these things to hold air, then I guess you could say you went tubeless "without issues.". But seeing that rim, it looks like tubes are needed to me.
masi61 is offline
Likes For masi61:
Old 03-27-22, 03:21 PM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times in 1,489 Posts
No, that rim is not tubeless compatible. If you try it and end up in the hospital I'll send flowers.
cxwrench is offline
Likes For cxwrench:
Old 03-27-22, 08:16 PM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3871 Post(s)
Liked 2,568 Times in 1,579 Posts
I also doubt it. For tubeless, you want rims with a flat ledge where the beads seat (newer designs include a little hump near the rim well), and tires that fit those rims snugly, if not tightly. While you could probably find tires that fit those ZAC19 rims tightly, I wouldn't trust them to stay put if you lost air while out riding.
IMO, tubes aren't so bad. I'd stick with them until you've got a full complement of tubeless-ready parts.
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 03-28-22, 06:42 AM
WhyFi
WhyFi's Avatar
Quoted: 20810 Post(s)
Originally Posted by BikingViking793
Can I convert these rims to tubeless without issues? I've read you can convert about any rim but ....
This is affectionately known as "ghetto tubeless." If the rim bed doesn't have the appropriate profile, I wouldn't do it.
WhyFi is offline
Old 03-28-22, 06:49 AM
sloppy12
Quoted: 166 Post(s)
Liked 252 Times in 147 Posts
if you try you will need to "fill in" that lowered section of the rim with some backer rod, and I would for sure go with the fatty strippers. They end up glueing to the tire(holds better at low pressure) you can do it with the spit tube method but its not as good.
sloppy12 is offline
