can cable housing make a cracking sound when turning the handlebars?
Old 04-25-22, 02:39 PM
masi61
masi61's Avatar
Quoted: 1163 Post(s)
Liked 441 Times in 314 Posts
I get an intermittent cracking noise on the front end of my titanium road bike. It happens only when turning the handlebars side to side. It will happen loudly once then not recur for a long time. It does not happen when actually riding the bike. For a while I thought I had made some kind of mistake torqueing the stem bolts on my Ritchey stem or thought that perhaps my Chris King headset doesn't like to be fully turned.
Lately when it happens I get the impression that it is coming from either the brake housing (wound, standard issue brake housing) or the compression-less derailleur housing. I am running slightly oversized compression-less housing on my Dura Ace 7800 shifters that was Deore XT spec (oversized).
If the housing is making a noise, is it something that can be fixed by lubing the ferules or should I replace the housing?
masi61 is offline
Old 04-25-22, 02:44 PM
Crankycrank
Quoted: 836 Post(s)
Liked 1,058 Times in 742 Posts
Yes, usually from the cut strands of the housing ends rubbing against a ferrule or cable stop. Check to make sure that the housing ends are cut/ground square and no individual strands are protruding beyond the others. A tiny bit of grease on the ends may help.
Crankycrank is offline
Old 04-25-22, 02:52 PM
Rolla
Guest
Quoted: 1346 Post(s)
Liked 3,269 Times in 1,439 Posts
If the cable housing is too short, the ferrules can bind in the cable stops and make noise when turning the bars. It can even happen when they aren't too short; dab a little light grease or lube at the contact point and see if it stops the noise.
Rolla is offline
Old 04-25-22, 05:51 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 4191 Post(s)
Liked 3,834 Times in 2,293 Posts
The early SIS casings had metal end caps (and current 5mm housing still usually uses the same end caps) and as mentioned the slow spiral of casing strands will scrap against the base of the ferrule as the casing tries to twist (with handle bar turning). Going to 4mm casing and plastic end caps pretty much stops the clicks. Andy
AndrewRStewart
Andrew R Stewart is offline
Likes For Andrew R Stewart:
Old 04-26-22, 08:52 AM
KerryIrons
Quoted: 503 Post(s)
Liked 630 Times in 352 Posts
Might just be a little corrosion where there casing/ferrule ends. Either way, a touch of grease or a drop of oil fixes the noise.
KerryIrons is offline
Likes For KerryIrons:
