1974 Fuji Finest Tubing? Double butted or plain gauge seat tube?
Quoted: 16 Post(s)
Liked 24 Times
I recently acquired a 1974 Fuji Finest. I think this was supposed to be a pretty high end bike. But the seatpost is only 26.6mm instead of the 27.2mm or so you see with single butted seat tubes.
I figure this frame either has a double butted or plain gauge seat tube. Anyone know which?
Quoted: 5887 Post(s)
Liked 3,469 Times
catalogs for vintage fuji bikes are online: https://www.classicfuji.com/1974_04_Finest_Page.htm
This will give you all the info you want on your bike.
I really like vintage fuji bikes. You should post some pics. I had a buddy that rode a fuji finest and it was a great bike. It was 3d from the top of the line at the time.
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
Are the decals gone? I have a '72, and am pretty sure the decal specifies butted chrome molybdenum tubing.
www.rhmsaddles.com.
www.rhmsaddles.com.
Photographer
Quoted: 105 Post(s)
Liked 98 Times
ClassicFuji.posthaven.com.archive
IG @scottryder.surf.cycle
IG @scottryder.fine.art
Phyllo-buster
Quoted: 2295 Post(s)
Liked 2,042 Times
My 76 America is double butted with a 26.7 seat pin. Yes.
feros ferio
Quoted: 1390 Post(s)
Liked 1,322 Times
It may depend on frame size. In late 1973, plagued with the dreaded oscillation problem, Kawamura switched to a straight gauge seat tube on its 25" Nishiki Competitions. The frame tubing pedigree decal on rhm's Fuji looks identical to the one Nishiki used, for Ishiwata double-butted CrMo.
Decrepit Member
Typically, seat tubes on frames labeled 'double-butted' are either straight gauge or single-butted. On the single-butted seat tubes, the butted end is at the bottom bracket shell while the non-butted end is at the seat cluster. Although there are double-butted seat tubes, they aren't used very often.
This shows Columbus SL tubing. Note the seat tube has 0.9mm walls at the butted end and 0.6mm walls at the seat cluster end.
