Steel Frame & Stock Aluminum Fork. Early 1990s. Anyone remember this era?
Quoted: 49 Post(s)
Hi folks
Wondering if anyone recalls this "aberration" era. A steel bike with a stock aluminum fork would (AFAIK) never be marketed today. But it was for a time. My first real high end road bike (bought it used) was a Specialized Allez Pro from 1994. Tricolour STI. Steel tubes, aluminum fork.
At the time, the fork was advertised as being "lighter" and to actually be vibration damping compared to steel(!). Given aluminum's current reputation for harshness, no one would ever "upgrade" their steel fork for an aluminum one to give a softer ride, but at the time, aluminum's harsh characteristics weren't yet widely known. It was simply considered a newer/lighter/better material found on higher-end bikes in a world of full of steel bikes.
In a sense, the alu fork "upgrade" was kinda the entry into "better tubing", the way modern entry-race alum bikes have carbon forks - they would be for people who didn't shell out for an all-aluminum (now all-carbon) frameset. But alum's characteristics soon trickled out, and then you couldn't advertise it as a vibration-damping material, and hence such bikes were no longer designed/marketed.
Is what I just said all true? I do know steelframe/alumfork existed - I'm just guessing the era was very short lived because it simply didn't make sense. Anyone else have a take on this?
weapons-grade bolognium
Quoted: 984 Post(s)
Liked 2,353 Times
Yeah, I remember that era. Quickly got superceded by CF. I have one of those Allez frames stashed away. Wish the fork was steel.
I had the carbon tubed Allez Epic with the Alu fork. probably the same fork that was on the steel - Perhaps it was the carbon helping out, but it felt fine and did the job it was made to do with no complaints.
Quoted: 7287 Post(s)
Liked 2,361 Times
I'm still riding my Viscount with its so-called Death Fork. I'm still alive. The fork was subject to recall, but I don't think it caused any deaths.
Quoted: 826 Post(s)
Liked 2,048 Times
I have a couple. My Parkpre (Tange Prestige frame tubes) came with a bonded alum Tange Fusion fork. As far as I can tell, the stock fork on my Merlin Ti frame is the same. I also rode a Vitus 979 with it's stock alum fork for many years. No complaints about the ride quality of these forks and I wouldn't say they give a hard ride though I haven't spent as much time on the Merlin. If anything, the 979 fork flexed more than comparable steel forks; you could really see that fork flex with hard front braking.
Decrepit Member
The 1998 and 1999 Schwinn Pelotons had an 853 steel frame and aluminum alloy fork. I never owned one, but thought at the time it was an odd combination. In 2000, Schwinn went to a Time Club Carbon fork on the same 853 steel frame which made a lot more sense to me.
Strong Walker
in the early 90ies, some recommended a Vitus fork as a comfort upgrade for any lugged steel frame. My first oversized alloy bike came with one, 1". Still own it, its a sweet ride.
Bikes: '00 Koga Miyata Full Pro Oval Road bike.
Quoted: 475 Post(s)
Liked 7 Times
Yet another example of the bike industry and their decades of BS. I dont know that aluminum forks were necessarily bad, but like many things before and after them, they were marketed as a better ride, then eventualy just vanished. Things like oval tubing, oval chainrings, and aero shifters come to mind as well..
Strong Walker
Now oval chainrings, they are something else wanna have a good laugh? check out https://moeve-bikes.de/en/cyfly, sort of oval chainring 2.0
"more efficient" torque *and* "more efficient" performance... yeah, right. These guys call themselves Engineers.
curmudgineer
Bikes: 2 many 2 fit here
Quoted: 263 Post(s)
Liked 111 Times
I'd like to see the power transmission efficiency from the crank to the chainring...
(for a conventional crank with one moving part, the only loss is in the bottom bracket bearing system, which is common to any crankset.)
Bikes: Too many to list
Quoted: 1764 Post(s)
Liked 1,119 Times
I've got a lot of miles on Aluminum forks both on my GT Edge, and several Cannondale's over the years.
I don't recall it ever being an issue --- but I wasn't in the market for a plush, Lincoln-like ride at the time
Bikes: Bianchi Volpe, ANT 3-speed roadster, New Albion Privateer singlespeed, Raleigh One Way singlespeed, Raleigh Professional "retro roadie" rebuild, 198? Fuji(?) franken-5-speed, 1937 Raleigh Tourist, 1952 Raleigh Sports, 1966 Raleigh Sports step-through
Quoted: 248 Post(s)
Liked 26 Times
My grandfather has a mid-'90s Fuji Team road bike with CrMo frame and 6061 fork...first time I'd ever knowingly seen such a thing, when I was visiting my grandparents this summer. Thought it was really weird...
Riding like its 1990
Having ridden aluminum forks I agree that's the wrong direction to go! What about the opposite: Alloy main tubes bonded to steel parts with a steel fork? Good old Univega Viva-tech. It was a strange time indeed.
Quoted: 5703 Post(s)
Liked 2,429 Times
Kinesis, SR (Prism), and others produced some very nice riding aluminum forks in that era.
The claim that an aluminum fork will give a harsh ride is absolute nonsense. The ride properties of any fork, of any material will be determined by the wall thickness, taper, curve and mechanical properties of the material.
Aluminum frames tend to be stiff and ride harshly not because they are aluminum, but because they were produced in an era of "stiffer is better and stiffest is best" and the makers used oversized tubes to maximize stiffness.
That doesn't apply to forks which have tapered and curved blades, especially when the blade is made by thinning the walls at what will be tapered down. Thinning before tapering reduces the tendency of walls to thicken as they're tapered to smaller diameters.
Bonding rather than welding also allows the designer to work with thinner tubes so achieving good ride quality is easier.
FB
Chain-L site
FB
Chain-L site
Quoted: 2300 Post(s)
Liked 4,764 Times
My 1999 was one of these. I took it on a 3 week business trip to Mississippi and put a lot of miles on it down there where the roads were dreamy, smooth pavement. The bike was so fast, responsive and joyful to ride. Then I got back home to the nasty chipseal roads we have here and that straight, aluminum fork would just beat the heck out of me. I sold the bike in a moment of weakness when I thought I had too many bikes. I do miss it but to be honest it was a harsh beast if the roads weren't perfect.
I also would buy it back today if it was for sale. I loved it and I hated it....
Steel is real...and comfy.
Quoted: 1361 Post(s)
Liked 422 Times
Happened to find this in a 1993 Suntour / SR catalog.
[IMG]SunTour and SR catalog 1993 aluminum fork by carrera247, on Flickr[/IMG]
Quoted: 1627 Post(s)
Liked 629 Times
It could be the V-rims and skinny tires I put on it after the "as found" pic, but this is definitely the harshest riding bike in my rotation right now. Feels fast, though.
Liked 2,429 Times
Happened to find this in a 1993 Suntour / SR catalog.SunTour and SR catalog 1993 aluminum fork by carrera247, on Flickr[/IMG]
FB
Chain-L site
FB
Chain-L site
Bikes: My wife says "Too Many"
An early 90's Specialized Allez Epic was my first "light" performance bicycle. I loved this bike and it blew me away every time I rode it. Granted my only comparison at that time was a few thrift shop, boat anchor bikes. But even later, after picking up a nicer italian steel frame, I still recall loving that Allez. Eventually I sold it but I can't say I ever thought the fork negatively affected the ride.
Quoted: 4742 Post(s)
Liked 3,860 Times
Hi folks
I'm not quite sure where to start here. Aluminum is considerably less stiff than steel. This has been common knowledge a long time. Sophomore engineering As a fork with cross section remotely close to steel, it is a lot more flexible. What made aluminum famous as a "stiff" frame material was the huge diameters used for the tubes. Again, not "new" knowledge. I did a quick ride on an early Klein in 1976. I couldn't have flexed that bike at twice my weight and strength.
I owned a Lambert. That fork was not stiff. Very comfortable on rough roads. The 1990s aluminum forks I saw weren't a lot thicker so obviously also not very stiff.
Edit: Oops. Guilty of answering an ancient post.
Last edited by 79pmooney; 06-22-21 at 09:13 PM. Reason: added paragraph return to be more readable
Likes For 79pmooney:
Quoted: 2432 Post(s)
Liked 638 Times
This. Steel is actually a more stiff metal than aluminum. The early pre-Cannondale aluminum frames with tubes of the same diameter of steel, such as Vitus, were noodles.
Likes For Lazyass:
