Gear - Inches chart for reference
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
I like this for the same reason I like slide rules: it gives you a sense of just how important (or unimportant) accuracy to the 4th decimal point is.
Likes For WizardOfBoz:
Sheldon brown one cuz it's straightforward and clearly shows percentage jumps between each shift
And the "HTML gear calculator" because it's so flexible, you can change stuff on the fly and easily visually compare two setups, a great tool. Doesn't display percentage jumps clearly though, which is nice to know.
Quoted: 1572 Post(s)
Liked 643 Times
Whenever I want to look up that stuff I just work out each ratio with my pocket calculator. It's faster than using a chart if you include the time I'd have to spend looking for the chart.
Bikes: 50/34, 11-40, 11 Speed
Quoted: 142 Post(s)
Liked 73 Times
Thanks for posting that as it contains good info to know. Unfortunately, maybe I'm the only one, but I have to confess that I find my ability to read or understand that graph/chart a bit visually challenging. It's not the gear feet concept info but the chart that is confusing.
Bikes: old clunker
Quoted: 684 Post(s)
Liked 105 Times
Quoted: 836 Post(s)
Liked 1,061 Times
For graph challenged types, such as myself, I like this calculator. BikeCalc.com - Bicycle Gear Ratio Chart
Likes For Crankycrank:
I love this gear calculator. It takes a little time to get used to it, But once you do in an instant you can see where the ratio's between any # of gears and chainrings are to large and where they overlap. You can even set the max chain angle to show only the gears with minimum cross chaining.
Bicycle Gear Calculator
It's true what they say "A picture is worth 1,000 words" or in this case, Numbers.
Likes For xroadcharlie:
I'm the anecdote.
Bikes: '12 Schwinn, '13 Norco
Quoted: 1110 Post(s)
Liked 1,176 Times
I never used a slide rule like Wizard of Boz mentioned, but I did spend many hours using a cardboard E6B flight computer back in the day.
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
Which 26" wheel size does the chart reference? Which 20" wheel size? What about 700/622? Etc.
I vote for online gear calculators.
Quoted: 3238 Post(s)
Liked 2,084 Times
Liked 2,084 Times
Yes, got that, but it then lists every ratio for every potential chainring between 30 and 46. That displays a lot of useless info as nobody has that type of system. It wants to just show the ratio for the 1,2 or 3 chainrings used, as Sheldons gear calculator shows.
