Clearance between tire and seat tube
Quoted: 77 Post(s)
Liked 26 Times
I've put 28s on an old road bike. There is about 2 mm between the tire and seat tube. Is this enough space? What is the worst realistic outcome?
Also, I have wheels with 14 mm internal width and 19.5 external. My undestanding is that 25C would be better for speed but 28s would be better for comfort. Does that sound right?
Many thanks for your help.
Quoted: 6177 Post(s)
Liked 4,794 Times
It's pretty much your call on that. I'd want more space. If something got between the seat tube and the tire, you rear wheel might suddenly stop.
Likes For Iride01:
I put 700x41 tires on my bike that was spec'd for 700x40 max. A couple mm clearance in the bike shop. I drove the bike to New Mexico and rode pavement in early June. The tire started rubbing against the carbon chain stays. Heat expansion. Not good.
Quoted: 2952 Post(s)
Liked 3,106 Times
If you're riding on clean, dry pavement, I wouldn't give it a second thought. If it's muddy or sandy, you might have an issue.
Likes For caloso:
Frame building options: longer chain-stays , or an S bent Seat Tube... so seat tube bends around the tire.
Dimpling the seat tube is another technique done to keep the chain stays short ...
Only in so far as the PSI of the Slightly Wider tire's operating PSI is an RCH lower..
( vernacular for a rather tiny amount ) 3mm in this case..
My understanding is that 25 mm would be better for speed but 28 mm would be better for comfort. Does that sound right?
Liked 3,106 Times
The OP wants to know if he can fit a slightly bigger tire in his existing frame, and your response is to rebuild the frame?
Quoted: 4195 Post(s)
Liked 3,837 Times
If the tire clearance under the rear brake caliper (assuming there is one) is equal to or less then that behind the seat tube then the caliper will be a "wiper" to clear the tire of road derbies.
I suppose the answer depends on the value of the paint job Andy
AndrewRStewart
AndrewRStewart
Depending on the geometry of the bike the wheel might not go on with the tire inflated. There might be too little a space between the seatstay and tire to get the wheel far enough forward to slip into the drop-outs. You will have to inflate the tire after the wheel is on.
Likes For hrdknox1:
Quoted: 645 Post(s)
Liked 797 Times
