Mafac adjuster repair
Quoted: 1106 Post(s)
Liked 1,326 Times
The inner portion of the Mafac brake adjuster used in the half-hood version is badly designed - the bottom projection is such a thin wall that it bends - and breaks:
So I got some stainless tubing, 4mm, 0.5mm wall and silver-soldered a bit in to replace it:
I had to get a lot more tubing than I need. If anyone out there needs the same repair, pm me. Postage plus beer money, depending on how many you want done.
(Yes I can do the bent ones, that bit just gets cut off.)
Likes For oneclick:
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
So THAT'S what I pulled out of the Co-op's brake ferrules and adjusters bin! It's the right size to fit a Raleigh brake bridge, but too tall for a clean bend. The housing wants to push it out. When I bring it back, I'll put it in the Mafac parts bin!
Quoted: 961 Post(s)
Liked 1,627 Times
Great Fix... and it keeps the original Mafac brake adjuster.
