Michelin Power Road Review
Bikes: Garmin/Tacx Bike Smart
Quoted: 646 Post(s)
Liked 289 Times
OK, this review will be mercifully brief. After 1,250 miles no cuts, no flats, no issues at all. The front tire is only about 25% worn, the rear about 75% worn (guesstimate based on TWI).
I'm running 700 x 28 size tubed tires mounted on Fulcrum Racing 3db rims, which are stock with no mods. The bike is a Specialized Roubaix, 2017. I'm an average rider who weighs about 175 pounds, so there was no "racing" stress put on the tires. Riding has been a mix of moderately hilly and flat (SW Florida since January).
Ride and handling are top notch. Riding over course pavement did not transmit high vibrations to the bars. Cornering and grip were also really nice in both wet and dry conditions. If you're looking for a tire that's more durable than the Conti 5000 but still a nice ride, this is a good choice.
Likes For dmanthree:
Quoted: 20808 Post(s)
Liked 9,450 Times
Quoted: 646 Post(s)
Liked 289 Times
Liked 9,450 Times
That's actually good mileage for me. My last pair of Contis, the GP 4000s, only lasted about 1100 miles on the rear tire. I'm guessing I'll get about 1,500 miles on the rear tire on the Michelins. I have a spare I'll install when needed. As far as the RR difference between this and the GP 5000, well, I don't ride fast enough to worry about that.
Likes For WhyFi:
Quoted: 646 Post(s)
Liked 289 Times
My most recent tires, tubeless Schwalbe Pro One Evo Addix, got about 2500-3000 per rear tire and were a little more supple than the Power Road TLRs, so I was really hoping the Michelin would be significantly better in terms of mileage. As far as RR, they're all pretty fast, fast enough for me to not worry about it, at least.
Liked 9,450 Times
Then again, I'm not afraid to run tires beyond the TWI and keep going until cords start to show.
Quoted: 6944 Post(s)
Liked 10,944 Times
Quoted: 646 Post(s)
Liked 289 Times
FWIW, I've NEVER been able to get good mileage out of a rear tire. Must be me. OK, except for those Conti GP 4 Seasons I ride in bad weather. Those damned things last forever.
Quoted: 800 Post(s)
Liked 512 Times
Here's hoping the distance you're seeing/experiencing is an anomaly.
Quoted: 850 Post(s)
Liked 344 Times
Could be braking style? If you regularly use the rear brake, that could explain it. I personally don't use the rear brake much at all.
Bikes: SL8 Pro, TCR beater
Quoted: 981 Post(s)
Liked 583 Times
Rear tire will always wear out first because of the weight distribution. It is the same thing on a motorcycle. Buy 3 tires, it'll save you some hassle!
Likes For eduskator:
Quoted: 646 Post(s)
Liked 289 Times
Not likely. I brake using both front and rear, and never "drag" the rear wheel. Honestly, I get this response a bit when I tell them how quickly I go through rear tires.
Quoted: 646 Post(s)
Liked 289 Times
I didn't this time because this was a new tire for me, and I wanted to find out if I liked them or not. I did buy a third tire after about 500 miles since I really like them and wanted a spare in case I sliced one of them. But so far the worst I've seen is a "rub" on the rear tire that's showing some cord. Not worried about it, though.
I've got a little over 2000 miles on my current Power Competitions and the rear is starting to get squared-off, but it's got plenty of life left. I'm a bit heavier than the OP and run correspondingly higher pressures, so as the saying goes YMMV. Echo all of the sentiments about the tires quality-wise though
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
Yeah... mileage on parts on bikes really doesn't do anything for me. On all components it's so different. Personal variables, terrain, weight, riding style, etc. Then to top it all off there's the je ne sais quoi - the variable that no one can explain. Like the mystery variable that leads some people to get more flats than anyone else in their group even with the same tires, pressure, weight, etc.
All mileages with regard to performance, should be given in "less than, about the same, more than, around twice more" terms when comparing to previous use.
In this case the OP could have said "At this point I have enough wear to imply I might get between 35-40% more wear out of these than I do out of Conti 4000's ...YMMV" but what fun would that be. It's way more interesting to argue about minutia over the internet.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Hear myself getting fat
Bikes: Sir Velo A Sparrow
Quoted: 335 Post(s)
Liked 265 Times
Weird, I've used Conti for my "nice" riding for 5 years. First the 4000's and now the 5000's. I'm conservative when I change my tires and change them out at around 2,500 miles and there was life in them according to the Conti tread marks they put on their tires. I tried some Michelin Pro 4 Endurance for my commuting tires when living over in the UK, but went back to Panaracer Gravel Kings which are my 2nd favorite tire after the Conti's.
I ride only road, weigh 230lbs and ride a mix of hills, some races (mostly crits) rolling hills and some miles on MUP's too.
I know Shane Miller did a review of his Conti 5000's and was at 5,000km on them and still going strong. But lots of people don't like them. Hopefully the Michelin's work out for you but you seem to wear out tires rapidly.
Liked 9,450 Times
I'm loving my Michelin Power Road 28mm tubeless tires. They roll well and they are simple to install.
Quoted: 1163 Post(s)
Liked 441 Times
You might be changing out your rear tire a bit prematurely, who knows?
For the last 2 years I have ridden inexpensive Tufo Calibra and Challenge Criterium tires and get between 1,500 & 2,000 miles out of a rear.
Liked 9,450 Times
They were tighter than anything that I've used in years. I mean, I still got them on with bare hands, but I had to be more deliberate about the process. I could see some people, those not well versed in tubeless install, swearing that they were impossibly tight. Seating the beads was snap, crackle, pop easy, though.
Liked 10,944 Times
Quoted: 646 Post(s)
Liked 289 Times
I have used the Michelin Power All Season in the rear and I changed it out after it was pretty squared off at somewhere around 1,800 to 2,000 miles. The front was an old Pro3 Race Service Course that still not rounded off despite changing to a 3rd new rear tire.
Quoted: 800 Post(s)
Liked 512 Times
dmanthree not to derail your thread, but if you are looking for a tyre that might last you longer than what you've experienced before, give the Giant Gavia series a go. I've had good luck with those tyres. Not the fastest tyres in the bunch, but for price to life ratio, they seem to do pretty good.
WhyFi Speaking of mounting tyres, I had to mount another Veloflex after the slash to my rear wheel. That tyre, while a struggle to get on the rim, did not seat as easy as snap, crackle, pop. Sealant here, sealant there and a couple of inflation attempts later (not to mention some sealant bubbling out of the wheel/rim/tyre) and I'm all set. Tyre is seated and holding air nicely. Was a brute to get going though.
Sojodave and WhyFi both of you are making good arguments for me to add yet more tyres to my inventory...Mrs. NoWhammies will be so pleased
Liked 9,450 Times
I eat carbide.
Liked 1,306 Times
Reason 8,234 that I charge a lot of money to set up tubeless.
