Tarmac SL7 Cockpit question?
Recently picked up a 'new to me' Tarmac SL7 Pro w/SRAM Force Etap 1x12. 54cm. I am 5'-10" and I have only ever ridden 54cm bikes. Ride about 100-150 miles/week. Flat terrain.
Absolutely love the bike. However it feels a little long. The Aerofly bars swoop forward a couple cm, and the Sram hoods are for sure a little more out front then the Shimano hoods I had been used to. Currently the stock 100mm stem, and the stock 20mm offset seat post. I have the saddle a little forward of center but not much.
I am thinking about shortening the cockpit a little. Need some opinions... Would I be smarter to get a shorter stem- 90mm, or go with a zero offset seat post rather than the stock 20mm offset? Or is it an either or? The shorter stem pulls my arms back and the seatpost pulls my body forward.
The bike fit option i on the table too but not there yet. Thanks.
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
I'd get your seat position sorted out first with the seatpost (or fore/aft placement of the saddle rails). If it's correct, then only the stem/bars would be changed.
Bikes: SL8 Pro, TCR beater
Quoted: 989 Post(s)
Liked 586 Times
Your body will thank me later.
Quoted: 1851 Post(s)
Liked 679 Times
Saddle should be set based on your fit and position relative to the bottom bracket. You do not move the saddle to adjust reach.
If you need shorter reach, try a shorter stem, or flip your stem up.
Likes For eduskator:
The general recommendation for reach after the saddle is correct in relation to the BB is seated the bars should line up with the front axle while holding the hoods. That is just a general starting point so as a sanity check this is where I start. The body left enough time will adjust as necessary to just about anything so it my be you are tweaked. But in a good way.
