Ok to put new tubeless rim tape over old rim tape?
Quoted: 192 Post(s)
Liked 11 Times
I just got a slightly used set of tubeless wheels that has rim tape installed. It's probably fine, but out of an abundance of caution I want to freshen up the rim tape. Do I need to remove what is already there or can I just clean the existing tape and throw a new layer on top? Are there any issues or consideration in doing this?
Quoted: 2432 Post(s)
Liked 638 Times
When I did the conversion on my MTB the stock tubeless rim tape was leaking. I put a strip of Gorilla tape over it and it's good to go. It actually helped me get air in the tire and set the beads because the bead pressed up against the extra thickness of the tape for a better seal, if that makes sense.
Quoted: 1104 Post(s)
Liked 1,824 Times
The only tubeless tires I know anything about are on motorcycles. Adding material/height to the center channel of a rim can make mounting/de-mounting the tire more difficult.
Bikes: 2021 S-Works Turbo Creo SL, 2020 Specialized Roubaix Expert
Quoted: 762 Post(s)
Liked 4,026 Times
I remove the old tape which gives me a chance to make sure the is no water in the rim and to clean the rim with alcohol so the new tape sticks well.
Quoted: 20801 Post(s)
Liked 9,448 Times
Likes For WhyFi:
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
This, exactly this. Then get a clean rag and some isopropyl alcohol, and get the rim good and cleaned up before putting the new tape on...I cannot reiterate how important this is. A clean rim is much less trouble to work with when setting up a tubeless tire. A little extra work at the outset will give you months of trouble free use.
Likes For Badger6:
Likes For tyrion:
Quoted: 532 Post(s)
Liked 621 Times
That's really the key...get the left over adhesive off the rim. Period. You want that rim bed surface to be clean, like your legs right after a proper shave.
Quoted: 762 Post(s)
Liked 4,026 Times
Quoted: 800 Post(s)
Liked 512 Times
Just adding my $0.05. Pull the old tape. That way if you have any issues down the line you won't be questioning if it's the old tape, the new tape, or something in between.
Likes For NoWhammies:
Quoted: 532 Post(s)
Liked 621 Times
Likes For Badger6:
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4361 Post(s)
Liked 3,000 Times
Are we still talking about the Mavic Cosmic Pro's. Pull off the old tape. Start fresh, do it right. If you mess it up, do it again.
You want the tape to be clean and to seal.
