Anybody ever see anything like this!?
Bikes: Many!
Quoted: 186 Post(s)
Liked 206 Times
Hey man rubber isn’t cheap!!! Oh wait...
Looks like post-war spring wheel. Have to say I’ve never seen a photo of one with a tyre mounted.
Quoted: 3810 Post(s)
Liked 3,335 Times
just imagine the energy loss from the spring flexure
gives a whole new meaning to the phrase "spinning one's wheels"
Likes For juvela:
Quoted: 831 Post(s)
Liked 2,124 Times
I'd expect some out-of-the-saddle brake rub.
Not much room for the pump head. Probably need an aero disc wheel chuck for that.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3883 Post(s)
Liked 6,476 Times
Even though this isn't a great solution for anything, I'm still a fan of the mentally handicapped occupying engineering positions.
Shifting is fun!
Bikes: Yes, please.
Quoted: 2197 Post(s)
Liked 4,599 Times
The best of both worlds: 650B and 27"!
Likes For non-fixie:
Likes For SoccerBallXan:
Likes For roadsnakes:
All Campy All The Time
Bikes: Listed in my signature.
Quoted: 177 Post(s)
Liked 114 Times
The newer version above must have been an engineering student's class project. It must have created more problems than it solved, if any. What, exactly, was the objective?
My C&V Bikes:
1972 Bottecchia Professional, 1972 Legnano Olympiade Record,
1982 Colnago Super, 1987 Bottecchia Team C-Record,
1988 Pinarello Montello, 1990 Masi Nuova Strada Super Record,
1995 Bianchi Campione d'Italia, 1995 DeBernardi Thron
My C&V Bikes:
Bikes: Novara Safari, CAAD9, WABI Classic, WABI Thunder
Quoted: 365 Post(s)
Liked 457 Times
Apart from adding a couple of pounds to rotational weight, I can imagine cornering at any elevated speed would've felt like cornering on a flat tire.
Be watchful, stand firm in the faith, act like men, be strong. Let all that you do be done in love.
Quoted: 4722 Post(s)
Liked 3,036 Times
The brakes won't be worth a hoot even in the saddle. The compression and expansion of the springs will mean the outer rim's position will be constantly moving up and down relative to the brake pad position. For this to work effectively with caliper brakes you'd need a brake with a super long reach, working on the fixed position the inner rim
Likes For T-Mar:
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4678 Post(s)
Liked 5,795 Times
You guys are missing the obvious. The person who built the wheels had different sized rims, but only one length of spoke and one tire size. Looking around, there was a box of springs hidden on a top shelf...
Likes For gugie:
Quoted: 18372 Post(s)
Liked 4,507 Times
verktyg
Quoted: 1036 Post(s)
Liked 1,238 Times
Notmantel
WW1 German??? bike called a Notmantel...
No pump needed!
verktyg
Chas. ;-)
Chas. ;-)
Quoted: 2363 Post(s)
Liked 1,749 Times
If they'd laced it up right, they could have lined up the two valve holes, and then used a loooong stem tube (or some sort of adapter).
Crawlin' up, flyin' down
Quoted: 1025 Post(s)
Liked 2,525 Times
If you scroll through the article Choke linked to in Post # 5, all becomes clear - The Germans did this in WWI because of the shortage, expense and difficulty in the repair of rubber at the time. Knowing that, it seems pretty ingenious to me.
These were military bikes; the intent was to get soldiers from here to there relatively quickly (compared to walking). Comfort and handling characteristics were likely not at the top of the list of design priorities.
Likes For bikingshearer:
Liked 4,507 Times
The dynamic movement would likely tear up a rubber stem (are those rubber over a hard material?
And for a steel stem, it would still need a lot of flex somewhere.
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,390 Times
Quoted: 1119 Post(s)
Liked 2,255 Times
Someone shared this airless tire design with me earlier.
https://mashable.com/video/new-way-o...never-go-flat/
Ageing Warrior
All of these examples, apart from, possibly, the latter, must have made cornering and braking 'interesting' to say the least!
The old motorcycle sprung hubs on anything heavier than a BSA Bantam were (are) a pain to set up and subject to very uneven wear and need frequent adjustment. Some makers used them long after the innovation of the swinging fork (often referred to as 'swing arm').
