Mount rack needed
Bikes: Lemond Poprad, Cervelo Soloist, Cannondale F4, RANS Velocity Squared
Quoted: 42 Post(s)
Liked 66 Times
Go to Saris, Yakima, Thule. And others. All have .com and search based on vehicle.
Clark W. Griswold
Quoted: 4353 Post(s)
Liked 3,993 Times
Thule, Küat and Yakima would be my top choices but hear good things about 1UP all the time (though not a fan of look of their racks but that don't matter) I would certainly avoid the cheapie brands because keep in mind these are safety items not a place to save money. You want something sturdy and that won't come loose easily and can hold the amount of bikes, weight per bike and have the overall handling capacity for what you need if not a lot more. Keep in mind as well what the PER BIKE weight is, the overall weight is important but you CANNOT exceed the PER BIKE weight especially if you are traveling on highways and places you might hit more speed or bumps.
I would avoid a trunk rack unless that is the only option that exists for the vehicle and in that case I would buy the best trunk rack possible and really check those straps often and really make sure I followed the instructions to the letter. If it is being held on with 2 or 3 straps I would avoid they really should have at least 6 straps and they should be from a reputable manufacturer. Again not a place to save money I have heard enough stories of failed trunk racks to always be leery. Trunk racks DO NOT fit all vehicles and one should not assume that many modern cars have spoilers and other things that could prevent a trunk rack from working and many decent manufacturers will have a list of things you need to do to make it usable on your specific car. Saris, Thule, Yakima all have car fitment guides where you put in Year, Make and Model and they can recommend what racks may work. However still try the hitch option first.
Before you leave shake the rack and try and move it put some pressure on it. If it is going to fail better it fails before you leave then on the road on potentially hurt someone or wreck your bike or both.
Also if you get a hitch you can get one of these: https://rubiconep.com/hitch-tent-rack-system (PS: they also make a cool hanging rack for bikes but haven't test either or seen them in person so just mentioning)
Likes For veganbikes:
Quoted: 765 Post(s)
Liked 1,735 Times
Kuat Sherpa. Possibly one of the best designed and easiest to use hitch racks out there.
Quoted: 1062 Post(s)
Liked 665 Times
Choose a rack, or at least narrow down your options, before choosing a hitch, because hitches come in at least 2 sizes, and having to use an adapter is an inconvenience. If you're a skilled DIY'er, you might be able to install your own hitch. I've installed hitches from www.etrailer.com for a minivan and a newer SUV.
QR-disc must die!!!
Bikes: '99 Trek 520, '20 Kona Sutra (FOR SALE 48cm), '21 Simon-Bikes mini-velo and a chromoly-framed folding bicycle with drop-bars and V-brakes, that rolls even while folded.
Quoted: 397 Post(s)
Liked 199 Times
Mount racks are available at the more extensive bicycle retailers, especially ones that specialize in touring bicycles. Some trusted brands to look for are Racktime and Tubus.
Quoted: 5224 Post(s)
Liked 3,581 Times
just strap the sucker on the front bumper! ;-)
just kidding. I have a hitch on my 2014 Jeep Cherokee & I really like having hitch mounted racks. I have a small one for just me, or me & Wifey & a big one for carrying 4 bikes. not crazy about mine, so I won't suggest them. but that old 2001 Ford Escape was a trooper!
