Tapping M4 boss to M5
Bikes: Subject to change at any given moment but currently is...... Colnago Mapei, Colnago C40, Wilier Triestina Carbon, Wilier Triestina Ramato, Follis 472, Peugeot PX60, Razesa, Orbea Terra, Soma Pescadero and 1/2 owner of a Santana tandem.
Quoted: 331 Post(s)
Liked 782 Times
Good evening all
I purchased some low profile M5 bolts for my bottle cages only to discover that Colnago apparently used an M4 at least at this time?. I’m fairly handy with tools but have never used a tap and die set, I assume I can re-tap these holes to M5 by simply running the appropriate cutter through the boss? I’d hate to screw these up by finding out too late that it’s not quite that straight forward
Recreational Road Cyclist
Quoted: 257 Post(s)
Liked 252 Times
Good evening all
Likes For BCDrums:
Quoted: 331 Post(s)
Liked 782 Times
Quoted: 980 Post(s)
Liked 582 Times
You'd have to drill out the bosses then tap the threads. If the frame is aluminum and the bosses are welded on, this might be possible, If the bosses are swaged in, or the frame is carbon, you might apply enough torque to cause the boss to spin. BCDrums' idea ^^ is much better.
Likes For sweeks:
Quoted: 2026 Post(s)
Liked 1,096 Times
+1. You can't just run an M5x0.8 tap through a threaded M4x0.7 hole without taking a great chance of breaking the tap, particularly if the bottle bosses are steel. If they are rivnuts, you stand a good chance of spinning the rivnut loose and then nothing will work.
You would have to drill out the existing holes with an M5 tap drill (4.2 mm or #19 drill bit) then tap new threads with an M5x0.8 mm tap.
Buying a few suitable M4 screws will be much easier and cheaper.
Quoted: 206 Post(s)
Liked 460 Times
Ebay has some blue M4 bolt listings, but they're all in China. So, you could order those, or you could get some from the hardware store and hit them with this.
I've used it on a few things, and it looks just like anodizing if done right. Less durable, but if they ever chip, you can just do it again.
Likes For krakhaus:
There’s nothing worse than having something go sideways when you knew it was a bad idea to begin with.
I would just get some stainless M4 bolts. If it makes it easier you can just think of them as placeholders.
Quoted: 194 Post(s)
Liked 204 Times
The tapping drill size for M5 is 4.2 mm, which is not much difference to the 4 mm thread root size of your M4, especially if you are going to have to hold the drill. You might get a nice pair of threaded holes, or you might not.
If you simply store the bike with water bottles in place, then no one, including yourself, will see the bolts, and thus a potential problem has been averted. On one of my display bikes I have a "special to me" water bottle in place on the bike, and I will confirm the bottle bolts cannot be seen.
Bikes: Lemond '01 Maillot Jaune, Lemond '02 Victoire, Lemond '03 Poprad, Lemond '03 Wayzata DB conv(Poprad), '79 AcerMex Windsor Carrera Professional(pur new), '88 GT Tequesta(pur new), '01 Bianchi Grizzly, 1993 Trek 970 DB conv, Trek 8900 DB conv
Quoted: 759 Post(s)
Liked 810 Times
There's probably more than a couple "silver" bolts on the bike. "Blue" must be pretty important to risk screwing up the holes in general. If they get messed up in the effort to make them M5...how's the next (post M5 re-work screw-up) bottle cage attachment going to look?
Some things matter..some don't. Put some silver M4 bolts in there, or paint the heads if you need to, and a week from now some other "thing" will capture your attention and the blue-bolt thing will be a distant, less important memory.
Likes For BCDrums:
Quoted: 257 Post(s)
Liked 252 Times
Likes For BCDrums:
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
I second that, and liked the first mention of it. You already have this feeling that you're going down the wrong road. You already know it's the wrong approach and, for some reason, you can't turn back.
When you finally do screw it up...you get this empty feeling in your stomach, that feeling where you wish you had listened to that voice that told you not to proceed..
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
^ interesting observation. I think that a part of maturity is having the self control to resist the impulse to simply plunge forward with a plan that you know is unsound. I'm always so proud when those moments occur, and I step back from the abyss to reconsider my way. This has come with both age and mountains of mistakes along the way, though.
Bikes: A Blue One and 2 Green One's, then there's the Yellow one. And oh, yeah, a Black One. Did I mention the Red One?
Quoted: 75 Post(s)
Liked 195 Times
You can't just run a larger tap into a smaller thread to enlarge it, you would have to drill the old threads out first. (machinist drill register bit). Especially since the threaded bung you're talking about is probably no more that a few mm deep. It would just tear out the old threads and mess the hole up real good. the tap would have to be held firmly in a fixture as it turns to ensure it is going in straight. A long hole to be tapped is kind of self straightening for a hand tapping job but a shallow one will Hogg out.
Re-tapping the hole is a ruined frame waiting to happen.
If they make 5mm blue bolts, the same company makes 4mm blue bolts. Maybe not the packager you got the 5mm from, but the company that actually made them. Patience and looking around for the right bolts is the answer
Worst case scenarios:
Your bolt heads aren't blue
You ruin an expensive frame
Likes For macstuff:
Quoted: 331 Post(s)
Liked 782 Times
Quoted: 1438 Post(s)
Liked 1,092 Times
If by "anodized" you mean aluminum, I avoid aluminum nuts and bolts (and spoke nipples) like the plague. They are weak and liable to both stripping and seizing, especially when mated to aluminum threads.
Likes For dsbrantjr:
Quoted: 980 Post(s)
Liked 582 Times
Original stainless steel hardware on the left; titanium replacements on the right,
Quoted: 257 Post(s)
Liked 252 Times
For several years I have purchased the odd titanium bits from Toronto Cycles and have been quite happy with their products. Sadly, the site seems to be closed since the pandemic started.
Likes For BCDrums:
