Most breathable bike rainwear?
Explorer
Hi All - greetings ,
I am considering retiring my car and getting back to cycling some more. However, a couple of years ago when I biked more frequently I remember that the then "better" bike rainwear actually was not that breathable - and I often ended up being quite sweaty/wet after a bike drive in the rain.
So I wonder if things have gotten better today - & also what is considered the current "98% best" bike rainwear in terms of breathability (& also durability)? When I say "98% best" I am assuming (maybe incorrectly) that the very best bike wear may be quite costly - I am looking for a very-close-to-best but also less costly solution ...
Any suggestions / concensus on what such rainwear would be? I'd appreciate your experiences ...
Cheers & thanks - Jesper
Likes For Atlas Shrugged:
Quoted: 4227 Post(s)
Liked 2,488 Times
100% waterproof and 100% breathable doesn't exist, the isn't a fabric out there that can keep water out and let sweat out at the same time...You have a choice, you can either accept getting wet with rain or getting soaked with sweat... I don't care what they advertise out there or how expensive it is, the truth is that any intense physical activity will overcome the breathability of the fabric and you will end up wet with your own sweat.
Likes For wolfchild:
Explorer
@Atlas Shrugged: Thanks for your input ... I will check it out!
Quoted: 365 Post(s)
Liked 419 Times
I agree with wolfchild. Unless you're riding at a very easy pace, you're going to sweat faster than the breathable fabric will "breathe". For warm weather, just get wet ("technical" fabrics will absorb less water, which has other advantages, but you'll still be wet). For cool/cold weather, focus on blocking the wind to keep the sweat/rain mixture from evaporating and chilling you.
For hiking during warm weather, it is just barely possible for breathable fabrics to work, if you're not hiking too hard. IME, if it's much above 70°F or if my HR climbs into the aerobic zone or above, breathable fabrics cannot keep up with sweat production.
Quoted: 6963 Post(s)
Liked 10,963 Times
I like bike
Bikes: Roubaix Comp 2020
Quoted: 267 Post(s)
Liked 283 Times
If there is a bit of rain/snow and a lot of cold, the Castelli RoS line-up is excellent. Too bad it is so expensive, but consider getting one jacket in this line-up. I have the Alpha RoS.
Here is a review from someone who actually used it and is not just repeating the marketing points: https://www.teknecycling.com/collect...a-ros-2-jacket.
I used to commute in downpours in my "youth", but not doing that any more..
Quoted: 18413 Post(s)
Liked 15,536 Times
Likes For indyfabz:
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
Quoted: 2333 Post(s)
Liked 2,097 Times
Likes For Rick:
Bikes: 2016 Masi strada vita due, 2019 Kona Dew Plus
Quoted: 268 Post(s)
Liked 80 Times
Agree w/several others- you cant be windproof & breathable at the same time. Disclaimer: I have never worn gore or any other expen$ive fabric.
Im looking for something that has a windproof front only, w/breathable in the back. I have a jacket that matches that description, but the back/breathable is so heavy it may as well be windproof. I only wear it @ 30degF or below.
Quoted: 338 Post(s)
Liked 408 Times
My go to autumn/winter rainwear is either one of the better jackets from Decathlon, from their Van Rysel brand of budget premium stuff which is very well sized and tailored, or the Castelli Perfetto ROS which is made out of somewhat better materials but while width and tightness is perfect I wish it extended a bit further down. That said neither is completely waterproof. If it is really pouring and really cold I add a packable rain jacket over all of it. As long as I dress that I'm cold at the start of the ride, the sweating isn't a big issue.
If it's really warm and raining I just don't care and wear summer kit with maybe a water resistant gilet and simply get wet 🤷 There's no winning move to stay dry when it's both warm and raining.
Castelli have also made some sort of Shakedry based packable rain jacket but it's obscenely expensive even for my tastes.
Bikes: 2021 Salsa Fargo 1x12, 2019 Jamis Renegade Exploit 1x11. Motobacne NX Fat Tire
Quoted: 198 Post(s)
Liked 332 Times
My best rain jacket hands down is my camo Kuiu Chugach packable, stretchable, hunting jacket.
For obvious reasons I don't wear it biking...
Quoted: 1364 Post(s)
Liked 1,677 Times
I started using DIY rain capes a few years ago. Not as dry as a rain jacket, but much cooler and more comfortable (for me). I commuted in bike clothes and changed at work, so a little wetness didn't matter.
Likes For BobbyG:
Explorer
Hi again - wow, so many replies and experiences - thanks all ;-)
I think I will just consider your suggestions for rainwear - as well as my own specific needs - and see if I can find a rainwear that is appropriate both in terms of functionality and cost. As it is I already have some Goretex "rainwear trousers" that have positively surprised me in terms of breathability (not for biking, though) so I have a slight preference here.
Thanks again for your feedbacks & have a good day wherever you may be!
Cheers - Jesper
Cheers - Jesper
Liked 2,097 Times
My first goretex jacket was 40 years ago, they have come a long long way.
With a proper baselayer, I do not get wet inside Gore Shakedry UNLESS I am climbing slowly on a long climb but let's be honest, we'd be sweating in our birthday suit on an extended climb.
I was backpacking in the Smokes this spring and it was pouring and sleeting. Two younger and stronger thruhikers (Triple Crowners at that) got hypothermic. I survived much better in my shakedry. Moisture control is much more difficult hiking than bicycling. Shakedry is fragile and expensive and not for everyone.
I am amazed when people say nothing will keep you dry and breath and yet in the same breath admit that they have not used any of these new fabrics. We have come a long way since waxed cotton.
Likes For GhostRider62:
Quoted: 873 Post(s)
Liked 726 Times
I have both a Shakedry jacket and Shakedry cap. I've gotten the jacket to have a thin layer of moisture on the inside, never more. Bought the cap recently and first wore it on my commute when the forecast called for rain that never fell. When I took it off, it was absolutely dry. When I've worn fabric caps (polyester, never cotton) they have been completely soaked from sweat at the end of the same commute.
The downside of the Shakedry tech is that it isn't reinforced for wear and tear, so high friction contact points are not good applications for it. That and it can be very expensive if you don't find it on sale -- when it is on sale, it's only somewhat expensive.
Likes For surak:
Explorer
@GhostRider62 & surak: I did some searching on the shakedry but it seems there are more models .. Might you have a suggestion for a/some models that are accessible to get/buy - maybe also occasionally on sale? In a first round I would need a jacket & bike trousers (if available?) ...
Cheers, Jesper
Cheers, Jesper
Likes For irpheus:
Quoted: 800 Post(s)
Liked 512 Times
The 7mesh Oro jacket - found here: https://7mesh.com/mens-oro-jacket
Expensive as all get out, but damn. Worth every penny.
Likes For NoWhammies:
QR-disc must die!!!
Bikes: '99 Trek 520, '20 Kona Sutra (FOR SALE 48cm), '21 Simon-Bikes mini-velo and a chromoly-framed folding bicycle with drop-bars and V-brakes, that rolls even while folded.
Quoted: 397 Post(s)
Liked 199 Times
There really is no such thing as "breathable rainwear". However, if you look at it another way, there is at least one solution to the stated problems. If you ask what is the most ventilating garment that keeps you dry while riding in the rain, my answer is a combination of a hood-less rain cape, a helmet cover and effective fenders on the bicycle. That combo provides all the rain protection I need. The cape is waterproof but open enough to get ventilation.
Likes For Nyah:
Liked 2,097 Times
Cheers, Jesper
Cheers, Jesper
https://www.bikeradar.com/advice/buy...-rain-jackets/
I like bike
Quoted: 267 Post(s)
Liked 283 Times
