Help get my tire off my bike…
I have a brand NEW out of the box eBike. I got a flat tire the other day. It has 20x4.0 tires so I order a tube. Today I tire to loosen the nuts to get the tire off. All I am doing is stripping the nuts they are on there so tight. What am I doing wrong or can I do?
Quoted: 1819 Post(s)
Liked 1,693 Times
Do you have the correct size wrench to remove the wheel? Your should not use an adjustable wrench for this job. Rear wheel nuts are usually 15 mm. You should have the correct size socket so as not to round out the nut
Quoted: 1109 Post(s)
Liked 1,200 Times
Sounds like you are trying to get the wheel off the bike. After that, you can get to the tire. Get the right size wrench and a long handle for more leverage. Make sure you're turning it the right way: counterclockwise to loosen.
Quoted: 241 Post(s)
Liked 454 Times
At this point stop...the more damage you do the more difficult the repair is going to be...take it to a shop where they know what they are doing and have the tools to do the job.
If not...crack on
If not...crack on
Quoted: 836 Post(s)
Liked 1,061 Times
What make/model E-bike is it? Some have their own weird procedures. Have you tried contacting the place where you bought the bike from or checked their website for instructions? YouTube may even have a video for your specific bike.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
What tool are you using to take the wheel off?
Likes For cxwrench:
Clark W. Griswold
Quoted: 4350 Post(s)
Liked 3,989 Times
I would probably see if you can return the bike, the headaches have already started and you just pulled it out of the box. A tiny tired fat bike is really not a practical for much. Fat tires are for sand and snow but really low initial cost bikes probably won't handle that well. E-bikes are awesome but the low initial cost stuff is more pain than you want unless fixing bikes is your real interest but it seems like you might not be wholly ready yet. Find a practical bike with Bosch, Shimano or a Brose motor (or something of similar quality and support) and you will enjoy it more and have to bring it to the shop less.
If you decide to keep it use the correct tools or take it to a shop.
Quoted: 836 Post(s)
Liked 1,061 Times
Here's another option to make changing a tube easier on Ebikes that are a PITA to remove the wheel. You just need to remove one bead of the tire and trade out the tube. Here's one example I found with a quick search so you may find some less expensive. Gaadi Tube, Comfort, 16 to 29-inch - Clever Cycles A friend of mine bought one of these for his Ebike after getting a rear flat on a ride that nearly sent him to therapy but hasn't used it yet so can't give any reviews.
Quoted: 1083 Post(s)
Liked 686 Times
Think about it. You could pop one side of the tire off while still in the frame and remove the tube from inside the tire, but you'd have to cut it to remove it from the bike. And how would you get the new tube in? There would need to be an opening in the rear triangle.
At best you could expose the old tube enough to patch it, and then put it back together.
Quoted: 965 Post(s)
Liked 1,628 Times
I'm confused?
Quoted: 326 Post(s)
Liked 735 Times
Wait....what?
Liked 686 Times
I see - a special tube just for bikes where you can't remove the wheel. I think I'd rather be able to take off the wheel and use a conventional tube, but that's just me.
Quoted: 836 Post(s)
Liked 1,061 Times
Yes I'm with you on that but that's just us. Some will find this type of tube a wonderful thing and don't mind cutting the old tube. You can also in some instances, tie the punctured tube to the frame and out of the way so you can take it out and patch it in the comfort of your garage or living room.
