[Gear hub] Shimano alignment tool TL-8S30
Old 06-24-22, 03:59 AM
Winfried
Winfried's Avatar
Quoted: 458 Post(s)
Liked 87 Times in 76 Posts
Hello,
Out of curiosity, what is the Shimano alignment tool TL-8S30 for?
Is it required to put a Nexus/Alfine gear hub back together, or just nice to have?
Thank you.
Winfried is offline
Old 06-24-22, 07:37 PM
Dan Burkhart
Senior member
Dan Burkhart's Avatar
Quoted: 803 Post(s)
Liked 400 Times in 230 Posts
Originally Posted by Winfried View Post
Hello,
Thank you.
the purpose of that tool is to phase the planetary gears. The Nexus/Alfine gear carrier sub assembly has the sun and planetary gears in constant mesh, so unless you disassemble the gear carrier that tool is not necessary.
even if you do take it apart to that extent it is possible to phase the gears without the tool. This video explains the concept behind it although it is a totally different hub.
Dan Burkhart is offline
Likes For Dan Burkhart:
Old 06-24-22, 08:45 PM
sweeks
sweeks's Avatar
Quoted: 810 Post(s)
Liked 350 Times in 256 Posts
Originally Posted by Dan Burkhart View Post
...unless you disassemble the gear carrier that tool is not necessary.
This ^^
You can open the hub and oil-dip or re-grease the gear cluster without disassembling the gear carriers themselves. I've been doing this for years with Nexus 7 and 8 speed hubs, and have never found it necessary to take the gear carriers apart.
sweeks is offline
Old 06-25-22, 03:24 AM
Winfried
Winfried's Avatar
Quoted: 458 Post(s)
Thank you.
So it's only needed (convenient, rather) if you take a hub completely apart for a thorough cleaning + lubricating.
Winfried is offline
Old 06-25-22, 06:43 AM
Dan Burkhart
Senior member
Quoted: 803 Post(s)
Thank you.
You can go as far as removing the gear carrier from the axle without having to worry about phasing the planetaries.
Once you disassemble the carrier it becomes necessary
Old 06-25-22, 07:08 AM
sweeks
sweeks's Avatar
Quoted: 810 Post(s)
Thank you.
Whatever you do, don't take apart the "Axle Unit" (the long skinny part the gear carrier modules ride on)!
I did this once on a Nexus-7 and never got it back together. I've been meaning to swallow my pride and send it to Rat City Bikes (lots of interesting pictures on this link).
sweeks is offline
Old 06-25-22, 08:39 AM
Dan Burkhart
Senior member
Quoted: 803 Post(s)
It can be done. I have never done a video showing the removal and replacement of the actuating arms and pawls, but I did do one showing how to get the shift spring assembly back together.
Old 06-25-22, 09:26 AM
sweeks
sweeks's Avatar
Quoted: 810 Post(s)
Thanks, Dan!
I know it's possible, and I've seen some other videos and pictorials about it but haven't had the need to do it... I have several other Nexus hubs. I should probably review your video and the others, then give it the old "amateur mechanic's" try!
EDIT: I just watched this video. Your understanding of the mechanism and ability to reassemble it is nothing less than awesome! But I'm wondering how in heck this thing was designed in the first place! I will have to dig out the box I put the parts in and see if I can follow your guidance. Thanks again!
sweeks is offline
Likes For sweeks:
