Difference in wheelbase (Canyon vs. Litespeed)
Hi all, I currently ride a size Small Canyon ultimate which has a 543mm TT and 385mm reach. I am looking to buy a Litespeed Ultimate, but seem stuck between size M and M/L. The size M Litespeed has a very similar TT at 541mm and reach at 380mm. This makes the Medium Litespeed seem like a perfect match. Where the Litespeed differs is in the wheelbase. My Canyon's wheelbase is 993mm while the Litespeed's is 972mm. So the Litespeed wheelbase is 2.1cm less. Also throwing me off is the Litespeed size chart which lists M as 5'5" - 5'8" and the M/L as 5'8" - 5'11". I am 5'9.5" and 32 in. inseam. I am definitely leaning towards the Medium since the reach and stack are very similar. Should the shorter wheelbase and sizechart be of concern?
Thank you everyone
Thank you everyone
Quoted: 6191 Post(s)
Liked 4,807 Times
My 60cm Scwhwinn Paramount had a way longer wheel base than my 59 cm Raleigh Competition G.S. The Raleigh felt way sportier to ride, the Paramount was more like a very stable luxury sedan going down the road.
They both fit me equally comfortable. But there are other things besides wheel base that affect the perception of how sporty or stable a bike is.
My current bike is a 56cm Tarmac and that is the lower of the two sizes I was between on the Specialized sizing charts. I wish I'd tried an even smaller 54cm in the same model that wasn't even in the recommended sizes. But the 56cm still fits me very well with just a stem change and narrower handlebars.
No.
Unless riding something that feels different than your other bike will make you uncomfortable. In that case you don't need to get anything but the exact same bike you had.
Thank you! I guess what I am asking is if the wheelbase is only 2cm shorter, am I likely to notice a significant difference? I do understand this could make it more quicker handling.
Liked 4,807 Times
Between the two sizes of the same model, it'll be insignificant. But if you could ride them both, you might describe the smaller wheel base bike as being sportier. But only in a very minute way. Not in a significant way just for that one reason of wheel base.
Quoted: 4393 Post(s)
Liked 4,837 Times
Are you sure your Canyon's wheelbase is 993 mm? Geometry Geeks has it listed at 985 mm. Still a bit longer than the Litespeed, but more like 13 mm difference. Mainly due to the steeper head angle on the Litespeed. The Litespeed is going to be a bit quicker handling and slightly less stable. The M is definitely a closer match to your current bike in terms of fit.
