Weight training and cycling - best training/nutrition routine?
Quoted: 446 Post(s)
Liked 1,043 Times
It's worth noting that this is the exact opposite of the fastest strategy to climb a hill. The fastest way is to go harder on the steeper sections and easier on the flatter sections. I'm talking about power rather than pace, which will still be faster on the flatter sections. Also don't fall into the trap of thinking that a lower gear automatically means less power. You will often find that you actually put out more power in a lower gear at a more efficient cadence. It often feels like less power just because the pedal force is lower, but Power = force x cadence.
But anyway, it sounds like your better overall pacing strategy made a big difference. There's nothing worse than going too hard at the foot of a climb only to get passed and dropped near the top. Another strategy is to power over the top of a climb and keep on sprinting into the first part of the descent when most people will back right off at the top and then coast over the summit. You can pull out large gaps instantly like this!
Also I do train in high cadence low gear riding. I swap back-n-forth between my road and gravel bikes. My gravel bike is setup with short 165mm cranks and Shimano GRX 2x gearing. With this setup my cadence is 10-20rpm over my road bike with lower overall gearing.
Quoted: 4395 Post(s)
Liked 4,839 Times
My road bike is actually setup for lower cadence climbing. I'm 5'7", but using 175mm crank arms with a 50:34t crankset and 11-32t rear cassette. I've been experimenting with different climbing techniques, but lately I've been wanting to stay in my big chainring while climbing, lowering the cadence and then climbing out of saddle to maximize my leg muscles built up from powerlifting on the sprints. One thing I notice is that I fatigue faster if I go hard early, but if I preserve energy I can make up the distance later on when other riders start feeling the burn. Oh yeah, I always imagine the top/summit/finish is about several yards/meters ahead. I never slow down until I go pass so I don't slow my pace while still on the climb.
Likes For PeteHski:
just another gosling
Quoted: 3886 Post(s)
Liked 1,938 Times
Results matter
Results matter
Likes For Carbonfiberboy:
Two possibilities to consider.
1. Assume you workout Mon to Sat, with Sun off.
Do legs on Sat. Take Sun off.
2. Workout Mon Tue with Wed off. Again, Th, Fri, Sat with Sun off.
Powerlifting on Tue and Sat.
In either case, you get a day's rest after weights.
Likes For anga:
Quoted: 446 Post(s)
Liked 1,043 Times
Every well-conditioned rider's climb rate limitation in any gear is HR. The issue then is one of duration. What is fastest on a short climb will not be the same thing that's fastest on a long climb, long climb meaning 1000' of vertical or so. On short climbs, hammering OOS will always be faster. This is true for short rides but on long rides doing that will make you slower overall as your legs can't take too much of that. On long climbs and long rides, one tries to balance leg effort and HR. If legs are tiring, gear down. If legs are fine but HR is too high, gear up. Power is interesting in that one can see what the result of HR and leg effort is. One doesn't actually need a HRM as breathing is a good analogue of HR. However I've found HR is an excellent method of pacing on long rides and climbs. Power doesn't matter much for that. What one wants to know is the physiological cost of power.
Anyways, I've opted to place squat day before I take a day off. Legs tend to take the longest recovery for me.
Likes For jonathanf2:
