How the pros fuel for a long race
Quoted: 2333 Post(s)
Liked 2,097 Times
Why not?
120g carbs = 480 calories using the normal convention, one burns even 500 calories on an easy hour. Granted not all are carbs, some will be burnt as fat, but if you aren't interested in weight loss, I see no issue going up to 480 calories consumed per hour. The more I consume during a ride, the less hungry I feel after.
Of course you may not tolerate that, but that is a separate issue.
1. Excessive glucose would be counterproductive to what one would be trying to achieve metabolically on an endurance ride.
2. You'll need a lot of toilet paper or nappies to wipe the puke on long rides.
Replacing half the calories is usually a good number,
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
Another mistake lots of joes make is the assumption of how much fat adapted they are and at what power output that fat/carb contribution actually does bias towards the fat. In other words, they're likely burning more carb than fat at a lot lower power level than they're assuming.
Likes For burnthesheep:
Liked 2,097 Times
just another gosling
Quoted: 3886 Post(s)
Liked 1,938 Times
We await the results of your experiment with consuming 480 kCal/hour on any hilly ride over 5 hours. That 50% rec is not arbitrary at all.
Results matter
Results matter
Liked 2,097 Times
says the person who thinks eating 480 calories per hour on a long ride is easy. Long races are partly a digestion competition, especially for those with a high VLa Max
Quoted: 528 Post(s)
Liked 230 Times
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4387 Post(s)
Liked 3,016 Times
Liked 2,097 Times
When I was more able to burn fat and could have been called fat adapted, I could ride seemingly forever. Now that I eat a little more carb, my FTP is higher but my endurance is less. There is a tradeoff on a continuum, and as you say, it isn't like a light switch.
https://alancouzens.com/blog/improvi..._burning2.html
Liked 3,016 Times
For most riders, it doesn't matter really. Most riders do rides under 3-4 hours and those can be fueled easily. But for Ironmen or ultra endurance riders, it is not possible to fully keep glycogen stores topped up unless pace is reduced OR one can burn more fat percentage wise.
Liked 2,097 Times
Interesting point, but I'm not sure where the cutoff would be and if it is the same for everybody, depending on their training. I've never been deliberately fat adapted and I used to be a total carboholic. However, when I am/was properly trained (i.e., had lots of miles in my legs), I have had no trouble doing centuries or up to 150 miles without fading at the end - that is, 5-8 hour rides. That's not ultra-endurance, but for me, the window is definitely greater than 3-4 hours. Without "fat adaptation". I do not favor rides longer than about 7 hours for other reasons.
What I find interesting is looking at the training intensity and duration of professionals during the off season or "base" period.......early in the season. Lots of hours at fairly low intensity.
Specifically, exercise training after an extended, overnight-fast augments skeletal muscle adaptations such as GLUT4 and AMPK protein levels, and reductions in postprandial insulinaemia, even when energy balance is unaffected.
Liked 3,016 Times
And those centuries are commonly well above zone 2, btw.
Quoted: 1221 Post(s)
Liked 629 Times
Ah man I didn't see this thread till now. I'll checkout the link and videos for sure. Here's my favorite recipe for rice cakes, they're super good!
https://www.efprocycling.com/tips-re...ke-rice-cakes/
I'm also a huge fan of maltodextrin, specifically HEED by Hammer.
Quoted: 4399 Post(s)
Liked 4,844 Times
I have already successfully tested it over a three hour ride where the middle hour was sweet spot. I did 90-120-90 without issue and felt much better after the ride than I usually do when I eat (too) little. I also tested 90/hour over a 4 hour ride (which was above 50%). I am not a racer, much less a pro, and I haven't even tested digestion all that much (yet). I absolutely do not see why you need to make blanket statement when digestion is so individual and trainable and people should test it for themselves. Also, I never said everyone should do it or that it is easy, my why not was aimed at your absolute statement. It is almost as if you completely ignored the "Of course you may not tolerate that, but that is a separate issue." part of my reply to you.
The other big factor is intensity. The harder you are riding, the harder it is to consume carbs. For example riding at a leisurely pace I could eat pretty much anything I wanted. But ramp the pace up to tempo for several hours and it gets much harder to fuel. I don't think in reality many ordinary guys could replicate MVDPs fuel intake while riding at the same relative intensity. But you can certainly copy the principle.
Likes For PeteHski:
Quoted: 528 Post(s)
Liked 230 Times
I find the longer the ride, the harder it is to keep slamming down the carbs at that kind of pace. My event rides are typically around 5-9 hours and it really gets hard to force down the carbs after the first few hours. Moving from solids to gels and liquid helps, but I usually struggle to average more than 60g / hour over say 6 hours. But I don't bonk at that level, so it's enough for me. I'm not at all surprised MVDP is taking in double what I would given his power output! As you say it is trainable to some extent and I know the Trainer Road guys are quite big on increasing carb intake for endurance. I've certainly tried it and take in what I can tolerate on events.
And agree, I mean if it were impossible even at rest, you couldn't smash down any large carb-heavy meal without getting problems (and maybe some people do get problems). One needs to figure out how one can keep the intake up with increasing intensity.
Liked 4,844 Times
This is really what I wanted to say. You may not get to 120g/hour, but why not try and just see to where you get.
Liked 2,097 Times
Well, there's no question that I lose weight when I get into the swing of things and do a century or century+ every Saturday, so surely I'm burning fat. But I thought that you were earlier making a distinction between "I did a long ride and so I burned some fat" and "I'm fat-adapted, so I'm better-able to do long rides"
Pros are barely out of Zone 1 into one 2 sitting in during easy pace sections of grand tour stages, so, it is easy to consume a lot of carbs. During climbs or breaks, it is a different story for sure. They have great metabolic flexibility (switch between fat, lactate, and glycogen for instance). Nonetheless, they are not eating on the bike for today's race but for the tomorrows races because it can take 36+ hours to completely refuel when depleted. Most of us do not have that concern. There has been some recent research showing up to 120 grams per hour are possible and that an even higher percentage of fructose in the mix is tolerable with specific training of the gut. I am experimenting with a higher intake using a commericlal product made mostly of cyclic dextrin and I am adding fructose. So far, it looks like it is far more tolerable than what I used in the past. So, old dogs might be able to learn a few new tricks. I'll find out on a hot 400 or 600K
