components for late 90's Merlin
Bikes: Merlin Odyssey, Marin Fairfax 2
Quoted: 7 Post(s)
my original post click here
hello, I could use some help or pointers for going to singlespeed on my Merlin see above link.
cheers
cheers
- What does the drop out look like? If it's vertical then you will need a single speed tensioner (or use the existing rear mech as low budget alternative)
- If it's a semi-horizontal dropout then you should be able to adjust the chain tension through it without need for a tensioner
- What kind of hub is on the rear? If it's a free hub then all you need to do is to choose your gearing of choice, add spacers onto it and line it up straight with the front chain ring.
- If its a screw on freewheel then you might need to change out the bottom bracket with a long or shorter spindle to accommodate a straight chain line with the rear wheel
- If you're going to be using the existing crankset/chain ring then you'll need to choose from the three chain rings to run (im assuming it's somewhere in the neighborhood of 53/42/37) and get single speed chain ring bolts to cut the slack
Quoted: 7 Post(s)
acoustophile thanks for the tips, ill have to look into those suggestions/items you mentioned.. its more of a semi vertical drop out for the back wheel. rear hub is the Spinergy spox you can see ill need to add spacers to line up with the front chain rings or keep the rear cassette how it is and just pick one that lines up with the front. perhaps i should bring it into a shop for more help/motivation
Live not by lies.
Bikes: BigBox bikes.
Quoted: 860 Post(s)
Liked 784 Times
If using the rear derailleur for the chain tensioner, can the H and L limit screws be adjusted such that the chain line can be further out from perfect alignment?
