Columbus "SL" tubing year of introduction
SAARF WAS WRONG!
I am trying to determine the year Columbus introduced "SL" tubing for bike framebuilding. Also, I would like to know when Columbus first used a reinforced steerer tube with the 5 ridges. I am trying to determine the approx. earliest year of a frame; possibly 60s?
Forum Moderator
Quoted: 3090 Post(s)
Liked 6,593 Times
Thread moved from Framebuilders to Classic & Vintage.
Quoted: 3811 Post(s)
Liked 3,336 Times
Buongiorno Jesper & welcome to the forum!
Quoted: 2333 Post(s)
Liked 2,097 Times
Randomhead
Liked 3,696 Times
It's interesting to me that the Columbus website doesn't mention the history of SL at all.
The other thread doesn't seem to show anything that actually says, "SL," or maybe I'm not reading it right. On edit: reading further in that thread confirms the stuff from 1935 didn't say anything about SL. I think before the late '70s it might have just been "columbus" and you pick your tube thickness. Might be easier to find a frame of known provenance with an SL sticker
Liked 2,097 Times
Interesting historical tidbit. 531 was around back then, so, similar dates for Columbus...??
Randomhead
Liked 3,696 Times
I think SL was just branding, so it's quite possible they introduced it much later. The tubing company was spun off in the '70s, so they may have decided they needed more branding about then. As opposed to earlier where the tubing existed in the material and thickness of SL, but wasn't branded as such.
Quoted: 1079 Post(s)
Liked 1,898 Times
So my understanding is the tubing that was introduced in 1935 had pretty much the same properties as SL, but it wasn’t until the 1970’s that it was labeled as such.
Some good info here: https://www.bikeforums.net/classic-v...sl-tubing.html
This bit in particular:
Bit hard to nail down an exact date. The Columbus tubing that was first drawn in 1930 for bicycle frame building was probably close to the same alloy and dimensions as what would later be called "SL", but from 1972 thru about 1977 at the earliest, there was no SL on the tubing decals, just gold foil and later (about 1978 thru 1984) the blue bordered decal which also would be used on SP tubing frames.
It was probably noted as SL in Columbus catalogs, and so spec'd as such by builders, but I can't find the earliest mention of that in print.
Magazine ad in 1975 mentions the 5 tubing sets that were in the market that year (still using just a gold foil decal for all 5 AFAIK): SL, SP, PL, PS and Rekord.
Pic of the earliest gold foil decal that Robt. Broderick says was in use from 1972 to 1974, the next 2 iterations look about the same except the dove eventually got printed in white ink.
Crawlin' up, flyin' down
Quoted: 1025 Post(s)
Liked 2,525 Times
Metallurgically speaking, SL, SP, SLX and SPX are all the same as what in the 1960s was stickered simply as "Columbus" tubing. The same tubing probably goes back into at least the 1950s and maybe before that, although I don't know that for sure. SL and SLX have thinner walls than SP and SPX (the difference is 0.1mm in most places). SLX and SPX was the same tubing with the addition of the helical reinforcements. I am 95% sure that PL and PS were also the same thing but designed and intended for track ("pista") frames.
I know that Reynolds 531 dates from the 1930s and was used to make the part of the Spitfire framing that held the Rolls Royce Merlin engine in place. Columbus was certainly in business back that far, but I don't know when they came up with the specific alloy that eventually came to be known as SL, SP, etc. Their website is not exactly a model of clarity on this, although it is at pains to point out that a lot Columbus' production before WWII went into furniture making.
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
My early 80s Columbus catalog claims 1930 as the start date for the company. It doesn't specifically mention when "SL" came on the market, but it's reasonable to assume around the same time. SL, SP, PL, and PS tubing were all the same alloy, just drawn to different thicknesses and shapes. Columbus tubing decals didn't distinguish between these versions until the mid-1980s.
https://www.os2.dhs.org/~john/catalog...mbus-tubes.pdf
Likes For JohnDThompson:
framebuilder
Just to add to the confusion, SL and SP I believe were heat treated. This is what made that tubing different from AL. When I was at the NY bike show in the middle to late 70's (before they stopped having it in NY), Columbus had a booth with a video of them making their tubing. After the double butting process, they showed a black screen with white letters saying "secret process". The surface of SL and SP has a bluish to golden hue. Their cheaper AL tubing with the same specs is just dull gray. I believe their "secret process" is the result of some kind of heat treatment. It is also probably when they started marketing their tubes as SL and SP. Of course that is just a guess on my part. I started building frames in 1975 and I think I remember Columbus having the SL and SP designation then.
Likes For Doug Fattic:
Quoted: 4722 Post(s)
Liked 3,036 Times
I don't buy into the belief that Columbus has been producing SL since the 1930s. While pre-1970 Columbus catalogues are rare, threre is an extant 1950 Bozzi catalogue with spec sheets for Falck and Mannesmann-Dalmine, who were Columbus' two biggest Italian rivals. Neither offered SL gauge tubesets at the time. Their lightest sets were basically SP equivalents. Also, a 1950s Reynolds catalogue shows an SL gauge tube available but only as a top tube. The larger diameter and heavier stressed down and seat tubes are at least SP gauge. I don't think any of these three companies would have given Columbus a two decade head start without responding. My basic feeling is that the roads of the era were considered too rough to warrant tubesets this light.
As for butted steering tubes with helical reinforcements, the 1950 Bozzi catalog shows one but doesn't mention the brand.
Likes For T-Mar:
Liked 3,036 Times
As for heat treatment, it's standard practice to anneal cold drawn tubes between drawing operations, to restore ductility and prevent brittle fractures. This would have been done with both Aelle and SL/SP.
SAARF WAS WRONG!
Thanks to all for the input. I had essentially found the same information, albeit vague, regarding their use of Columbus tubing for aircraft, race cars, motorcycles, and furniture; with just a mention that Columbus was also making bike tubes. One would assume the name "Cyclex" had some significance regarding tubes manufactured specifically for bikes. Since "SL" (et al.) tubes are made with that alloy formulation, and Columbus was already making butted tubes; I assume that the "SL" dimensioned tubes came into being around the same time, regardless of whether it was designated as "SL" or not, as the onset of Columbus developing that "Cyclex" alloy formulation for use primarily for bike frames. I have not found any reference regarding a "Cyclex" year of introduction in any timeline.
My query is in regards to a frame I got from an honest seller who could not guarantee that the frame was Columbus tubing (fork has Columbus dove stamp on tube and "rifling"), nor that the frame, which has Vicini decals, is even made by that brand bike company (frame repainted at least once). The frame feels too heavy to be all "SL", possibly only the main tubes are "SL". Smaller frame (55cm) so I doubt that it is "SP" tubing; frame is far too early (I assume 1960s to early 1970s, no braze-ons anywhere) for "SLX/SPX" variants.
Liked 3,036 Times
You should post pictures of your frame. There could be other characteristics that may provide an indication of the age.
Quoted: 236 Post(s)
Liked 171 Times
SAARF WAS WRONG!
Sorry, I do not understand your meaning or reference.
T-Mar Was Cyclex a name for a new steel alloy formulation used for '80s tubes, or was it the same alloy formulation used in '70s and earlier tubes ("SL" tubes and others), but just given a fancy name in the '80s? The previous owner was dubious about everything regarding the frame; thus, the reason for selling it fairly cheap ($75).
I will post photos when allowed.
Rider who can know more
Bikes: 1995 Trek 850 Mountain Track turned trail and road bike, 1989 Centurion Le Mans RS, 1993 Bianchi Advantage. Dead: 1982 Schwinn Traveler
Quoted: 46 Post(s)
Liked 8 Times
The late Sheldon Brown disagrees with you: https://www.sheldonbrown.com/org/ranger.html
Liked 3,036 Times
As for photos, you can upload them now. They won't attach to your post but they will upload to gallery album, under you user name. Then, myself or another member could post the link to the photos or post them directly in this thread.
Quoted: 3464 Post(s)
Liked 2,829 Times
( which I thought was cool as the chainstays were 24mm then swaged down for the bottom bracket shell sockets. I can confirm the blue to bronze discoloration. Think 60’s motorcycle exhaust pipes after a time,
in 1975, a Carlsbad Masi could be ordered for a $25 upcharge the frame made with Columbus tubes, if you knew to ask.
smart choice as Mario Confente built those.
he offered that brazing Columbus was a bit more work than Reynolds, heat control was more important, Reynolds was more forgiving.
someone out there has one made of Ishiwata tubes, Mario stated he liked them.
Assuming that the SL/SP alloy is close to 4130, there must be some heat treating. As-drawn 4130 is only 480 MPa yield and 655 Mpa UTS; Columbus SL/SP is 735 yield and 835 UTS. Increasing the strength while retaining ductility and brazeability would be the tricky part, and it makes sense that the temperatures and durations of quench and temper would be a secret process. BTW, as-quenched 4130 can be as strong as 1325 yield/ 1600 UTS if you want to make a knife from it.
BMX Connoisseur
Bikes: 1988 Kuwahara Newport, 1983 Nishiki, 1984 Diamond Back Viper, 1991 Dyno Compe
Quoted: 399 Post(s)
Liked 108 Times
I can't seem to find it, but I believe I read somewhere that when he registered the name Columbus, he also registered Tenax and Aelle in the early 1930's. Tenax from other pages on here sounds like SL/SP but slightly different?
