What tire width on an old bike
I have an old Clive Stuart frame that I want to finally get around to building up. It came with the old tubulars (way narrow) tires (23mm? Or so Maybe) anyways I would like to but a new wheel set on the bike for clinchers or tubeless and was curious (generally) will these bikes handle 28-30mm tires? Or is this not even worth exploring?
Quoted: 837 Post(s)
Liked 1,080 Times
From that angle it looks like you have a massive amount of clearance and could go beyond 28mm even. Photos showing the actual clearance points (under the fork crown, rear chainstays and brake bridge) would help us be certain though
Likes For polymorphself:
Quoted: 5888 Post(s)
Liked 3,471 Times
I'd be surprised if it wouldn't take a 32c tire. Those center pulls have a lot of reach and it looks like you have generous frame clearance.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3870 Post(s)
Liked 6,461 Times
Between the chainstays is probably the primary restriction.
Likes For SurferRosa:
Quoted: 929 Post(s)
Liked 1,289 Times
What those guys said. In my experience and looking at those photos, 32 mm would almost certainly be achievable and would be very desirable. See if you can borrow a wheel that has 700C x 32 tires and see if it'll fit. The main issue you might have is that you may need to deflate the rear to remove the wheel...a minor inconvenience.
Bikes: N+1
Quoted: 94 Post(s)
Liked 419 Times
I’d go with a 28 or 30 mm tubular tire on the original rims. In my limited experience a good tubular rides like a clincher a size bigger as far as comfort and shock absorption.
My experience is that undimpled round-oval-round chainstays limit you to 28mm or so tires. If there is a dimple (or if you choose to add a dimple), 32 mm is a possibility. There is clearly plenty of radial clearance. The other possible pinch point is fork crown width.
Quoted: 1946 Post(s)
Liked 2,004 Times
It is a lovely bike. Especially the fork blades and their smooth curve: Yowza! If your not interested in Tubulars, (and you should be), and fat tires wont fit, I'd recommend some TB-14s and 23 or 25mm Continental Grand Prix 4-5000s. I was recently surprised how nice some 23s rode on the wider rims. Of course there are other wide rims and nice tires but that was a revelation for me.
Really cool bike. I recognize you only have 22 posts but posting only one NDS photo on such a machine is frowned on here😇
Thank you all for the follow up responses to my question. VERY helpful. I am going to grab some measurements and look into this further.
mad far as going with tubulars - they make me a bit nervous as I’ve not had any experience with them. I can change a clincher in minutes so it’s more just the unknown for me. I want to use the bike for some light touring and the thought of tubulars is just an big question for me.
Extraordinary Magnitude
Quoted: 2607 Post(s)
Liked 1,696 Times
That's a pretty sweet bike, I'll bet it'll gleam with the brightness of a thousand suns once it's polished up!!!
Commence to jigglin’ huh?!?!
Likes For The Golden Boy:
