Bony Butt & Ride a Racing Bike?
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2566 Post(s)
Liked 5,599 Times
As I have - eh, matured - I seem to have lost padding where I sit making longer rides rather uncomfortable. After 40 miles I just can’t wait to get off the seat. Sure I mix it up by standing a bit or coasting downhill with my bum slid back off the saddle but that isn’t enough to really help. I have purchased about about a grand’s worth of new seats, mostly different Selle Italia with cutouts because of gentleman issues which probably put more pressure on my sit bones. So who has had a similar issue and found a good solution that helps you ride 50+ miles comfortably? I do use good chamois shorts and my saddles do have some padding.
Any double padded shorts?
Any miracle saddle with cutout that does not have springs or feel like a sofa that have been ridden over 50 miles?
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Cheerfully low end
Quoted: 644 Post(s)
Liked 1,044 Times
During much of last summer I regularly rode wearing two pairs of cycling shorts which helped quite a bit. In winter I always have some type of warmup pants or sweatpants over the shorts which provides much of that same help.
Lately I’ve been spent most of my rides in a tall enough gear (42/14) that I need to spend a lot of time out of the saddle, which also helps.
Otto
Otto
Likes For ofajen:
I tend to have similar problems like you do on popular saddle designs where the sides slope downwards on the sit area. They do feel like sofa in a bad way.
I'm also in desperate need of cutout but I also found that a cutout is unnecessary in some saddle designs especially those where the top is almost flat if viewed from the front. If you're looking for a comfortable saddle without cutout and doesn't impose on the jewels, look for ones that are almost flat if viewed from from the nose
Likes For tempocyclist:
ignominious poltroon
Quoted: 2223 Post(s)
Liked 3,407 Times
Leather saddles might be worth a try, if you haven't already. My most comfortable one is a B17, although I kind of wish I had something slightly narrower, but I don't have enough years left to live to go through more saddle break-in.
Quoted: 2479 Post(s)
Liked 2,947 Times
No two of my bikes have the same brand and model of saddle. They're all uncomfortable at the start of the season and they're all fine once I've done enough mileage. If your saddle was good for 50-mile rides and longer during your peak riding months last year, chances are that it's now uncomfortable simply because you've recently increased your mileage dramatically, as we all tend to do in the spring.
Let's start at the beginning when talking about saddle comfort on race/pure road bikes. What's your saddle to ground/bars to ground difference? When there is little difference between those two, you'll be hard pressed to find a saddle marketed as a pure road bike saddle to be comfortable.
You can certainly interchange saddles between the two (road and XC MTB). Hybrid being more upright, more weight on the saddle requires wider design. Many XC MTBs have saddles that are identical in design to road bike saddles. Pros deliberately try to rotate their pelvis in a more upright position for many good reasons. To achieve it in a slammed down stem requires good flexibility at the lower back. A sign of this good flexibility is able to reach your toes with your fingers.
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
Things that make the bum hurt less:
-weigh less
-"all day" or "audax" advertised bib shorts
-make more power
-if your arms can take it, a more aggressive fit with more weight on the hands than upright, if not add some clip on bars
-ride a route needing some out of saddle once in a while
-not sure if this is true, but in my feeble brain it seems a lower cadence may mean more pedal force for the same power meaning less force on the bum
-weigh less
-make more power
Quoted: 6177 Post(s)
Liked 4,794 Times
Do you sit very upright? Is your saddle pushed back or your seat post has a large amount of setback? If yes to both, then you might be sitting heavy in the saddle and not getting any lift from your legs while you pedal to lighten the load on the saddle.
Otherwise with out more info about your measurements and your bike model and size, that's just a wild grasp at something.
I still find more padding is worse. Even for gloves and especially saddles and chamois.
Quoted: 20808 Post(s)
Liked 9,450 Times
Generous cut-outs are a must for me, too, and for the same reason. Width is also important. I also found that I did better with less padding. In my experience, once I got these right, I was putting more pressure on my sit bones, and was experiencing the same kind of discomfort that I think you're experiencing, but that went away completely after a two or three weeks riding.
That said, I do still experience some of that discomfort when I go out for long rides with friends that are more casual in their cycling - I chalk that up to less weight on the pedals translating to more weight on the saddle.
Likes For WhyFi:
Fxxxxr
Quoted: 2670 Post(s)
Liked 1,149 Times
"Similar to the other PS saddles, the PS 1.0 features a slight upward slope at the rear – providing superb hip support when your body is rotated forward in the aero position, or an aggressive road riding position. This tends to be preferred by athletes that don’t move around on the seat excessively while riding. It is also a top choice for triathletes and time trialists who ride in the aerobars, or for flat courses in which the athlete likes to ‘settle in’ to one position and go."
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Jamis Citizen 1, Ellis-Briggs FAVORI, Rivendell Clem Smith Jr.
Quoted: 411 Post(s)
Liked 896 Times
Maybe try one of these...
I feel the same way about my bony-ass sit bones, myself. Maybe I need to do squats as well as stretches. Anyway, this seat really seems to fit my under-carriage:
Selle SMP TRK
I can ride comfortably for miles in the "crotch cradle", as I call it, then scoot back a little and perch on the generous pads for a change-up.
I have a Medium on a drop-bar bike, and a Large on an upright bike. The only difference seems to be about 3/8" in width at the rear.
Selle SMP TRK
Likes For Fredo76:
For The Fun of It
Bikes: Lynskey GR300, Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 2134 Post(s)
Liked 1,643 Times
It has taken Aerotech Designs shorts and ISM or more recently Cobb Randee (now jcob type R https://speedandcomfort.com/collecti...roducts/type-r) saddles to give me any hope of riding over 50 miles.
Quoted: 1109 Post(s)
Liked 1,200 Times
It does have a small amount of minimal padding. I believe excessive padding will actually exacerbate pundendal type pressure because the sit bones sink into the padding and cause pressure elsewhere, thus exacerbating the need for a cutout. The Kontact/E3 design addresses that without a cutout.
But everyone has to find their own saddle. I recommend at least trying the Kontact or better yet, if you can find an E3 Form on Ebay, it will be a cheap test.
Grupetto Bob
Liked 5,599 Times
Grupetto Bob
Liked 5,599 Times
Grupetto Bob
Liked 5,599 Times
Selle SMP TRK
Selle SMP TRK
That's what I use (flat) and have never had a problem with soreness anywhere. I've homed in on the Kontact saddle, and it's predecessor, the E3 Form which was sold by Performance a decade or so ago. I'm so happy with it, I stockpiled some E3's when I could get them on EBay and bike swaps for cheap and lately bought a Kontact- same saddle, different styling. The description of the design by the guy who designed it touted it's ability to avoid pressure that is normally addressed with a cutout, therefore no cutout needed. My experience is true to that.
It's a thing when you needed a cutout. Unfortunately, many designers simply put a hole in the same "sloping-side" saddle design. It can still put pressure on the fleshy bits because of the sloping sides but if you make the hole bigger, it starts hurting the sitbones. Any pressure on the fleshy bits would make you feel unstable on the saddle and that's wasted energy and major cause of discomfort for constantly adjusting to a stable position.
The solution is a saddle that only slopes little to the side.
Likes For qwaalodge:
Ignore what ISM is telling you "Don't sit at the wide part!!". It never hurts to try. For me, the wide part (slightly behind it) is the most comfortable position in the ISM saddle for me.
In practice, I either sit just slightly aft of the widest part of the ISM saddle when cruising in the flats or descending and then on the nose when climbing, especially on steep climbs.
Also comfort is relative. Don't expect to be pain free for 50 miles, that's unlikely to happen. But not constantly thinking about your bum and only noticing it occasionally is doable.
Also like it was mentioned here earlier, check you setback. I'd suggest that after lowering the seat to a level where you can pedal with your heels with absolutely no hip rocking, you push the saddle all the way forward and start inching it back in 1cm increments until you feel balanced. Of course balanced also requires a correct saddle tilt so keep it level if at all possible. You can also try the "push all the way back" -method, but I find that tends to leave you too far back. You want to be as far forward as you can be and still be well balanced. If you start at the back you'll find balance way sooner and potentially stop too far back. And having a saddle too far back has the same symptoms as having the saddle too high.
Likes For elcruxio:
Liked 4,794 Times
Though I'm not sure how to translate any of that to saddle/butt issues. Though maybe you are pushing easier gears and not getting as much lift from your legs anymore. But that's only a supposition looking for a hypothesis. <grin>
Likes For Iride01:
Grupetto Bob
Liked 5,599 Times
If your life is slowing down like mine and you don't get all the other activity to keep all your body in shape then exercises for all your body might help. I seem to be finding that some resistance exercise for my upper body has helped for the oddball issues that I never had before on the bike since retiring.
Quoted: 6936 Post(s)
Liked 10,940 Times
I would also suggest that the OP consider Rapha Classic bib shorts or shorts… the chamous is rather thick.
SMP saddles were the answer for me. They make a large number of models in each of several widths. They assume that the larger your not fat waist size, the wider the saddle. I use the narrow stratos that has standard padding. Less or firmer padding is probably not what you want.
Fxxxxr
Liked 1,149 Times
mine is on a fixed and i kinda feel the same way ........................................ i know a lot of ODD feeling people so i guess im OK with it
Likes For jack pot:
