order my first carbon wheelset going to try tubeless
#51
Quoted: 426 Post(s)
Liked 274 Times
Yeah but they look cool so that helps!
I have a charging canister style pump at home, works great with my Tubeless tires. The GP5000’s I really haven’t needed it for (but I did need soap and water). The Schwalbe’s which I loved as well definitely needed the charge style pump. They are very easy to put on.
one of these days I’ll probably just get an actual compressor I think they’re pretty cheap
Can you recommend charging canister style pump ?
#52
Habitual User
Quoted: 4941 Post(s)
Liked 8,080 Times
I installed a pair of new Conti GP5KTLs tonight. As is the common story, the most difficult part was getting them on the rim. Doing the first one helped me learn a process that made the second one a little easier. The front tire seated easily with just rapid pumping from my old floor pump. The rear, however, wouldn't seat in a couple of spots, even after some repeated manipulation attempts. I used a blast from a CO2 cartridge, and it popped into place. I then deflated it, injected the sealant through the stem, and inflated it with my floor pump. Since I like buying toys and tools, I probably will buy a canister pump at some point.
Likes For Eric F:
#53
Quoted: 426 Post(s)
Liked 274 Times
yeah those jobs where money losers.
I guess I am as bad as people the collect
https://www.amazon.com/Collectible-F...&ts_id=1095304
Likes For sean.hwy:
#54
Habitual User
Liked 8,080 Times
I am an x-auto-mechanic. I have sooooo many tools that I have only used a a handful times. ha-ha :/
GAS (Gear Acquisition Syndrome) is a real thing.
Likes For Eric F:
Likes For smashndash:
#56
member
#57
Quoted: 426 Post(s)
Liked 274 Times
The Giant came tubeless. Heavy tires so I put some gravel kings 32mm slicks. The lightbicycle wheels came with stems and the rims have no holes in them so it was easy to install tubeless tires 25mm road tires on them.
I tried all the tricks on youtube to seat the 32mm gravel kings with a regular floor pump. I was not having any luck. I bought this charge pump. I only use it with the valve stem out and only to seat the tire. I then use my normal floor pump to pump up the tires. While it works fine if I had the space I would have preferred to buy a HF quite small air compressor.
https://shop.sportsbasement.com/prod...ve-2-5-gls-blk
I have a few cheap allow wheel sets ( l like lots of wheel sets for my gravel bike, different tires and different gears ) that I would like to convert to tubeless. What kind of tape and valve stem should I get?
Yeah I am convert now. I have bleed out some sealant hitting a rock/thorn what ever that would have flatted a tube tire. I took the wheel off put the hole at the very bottom so all the sealant would go to the area. spun the tire a few times added a little more air and made it home just fine.
I kind of regretted just buying my wheels plain with nothing on them. The gf said she didn't care either way. So the plan was the new wheels with labels was going to be mine and she would get the plain lightbike wheels. As you can see she changed her mind. ha-ha
#58
Quoted: 20810 Post(s)
Liked 9,456 Times
For valves, the main two things that I look out for are: length and internal clearance. Length for obvious reasons, the internal clearance so that I can inject/remove sealant with a syringe. Unfortunately, some stems have a constriction point inside that'll keep a syringe tube from fully passing through. I tend to buy Muc-Off alloy stems because they're available locally and I know that they work.
Likes For WhyFi:
#59
Dead but dreaming
Location: Bay Area, CA (East Bay - Contra Costa County)
Bikes: 2020 Santa Cruz Stigmata, 2022 Cannondale Synapse
Quoted: 171 Post(s)
Liked 326 Times
DT Swiss is good tubeless rim tape but I just set a new carbon wheelset up using Muc-Off tape, stems, and sealant and it all was easy to install with no drama.
For the tape buy it a few mm wider than the internal rim width to account for the center channel. When you stretch it out give it a side to side wiggle and do a spoke hole or two at a time using your thumb to press out any air bubbles as you work around.
Likes For KJ43:
#60
Bikes: 2022 Moots RCS, 2014 BMC SLR01 DA Mech, 2020 Santa Cruz Stigmata, Ibis Ripmo, Trek Top Fuel, Specialized Levo SL, Norco Bigfoot VLT
Quoted: 464 Post(s)
Liked 182 Times
Glad that the sealant did its job. I have started to prefer Muc-Off tape as well. I am not sure what tape (if any) my 303 Firecrests will come with but I'll check with them and keep some handy. I always throw in a tube and regular tires overnight first...foolproof that way. Well, not as foolproof as Skinny Strippers (a super thin rubber or latex band that goes around the rim) but as close as it gets.
Likes For Chandne:
#61
Bikes: Speedvagen Steel
Quoted: 429 Post(s)
Liked 248 Times
Happy to hear that all worked out, nice that the GF made the switch as well lol.
are your alloy wheels tubeless compatible? If not, although many have converted normal wheels to tubeless using an extra layer of rim tape I’m not sure if I would risk it with the high pressures of road tubeless.
if they are tubeless compatible then the guys above have given all the suggestions I would have as well.
enjoy!
enjoy!
Likes For robbyville:
#63
Liked 9,456 Times
My 303S came wrapped with Zipp branded tape that looks very much like DT Swiss. No extra tape was provided.
#64
Quoted: 464 Post(s)
Liked 182 Times
[QUOTE=WhyFi;22456947]Is the Muc-Off tape more along the lines of DT Swiss (more rubbery with some stretch) or Stan's/etc (plastic film without much give)? My only two knocks against DT Swiss are cost and availability, so if something comparable or better improves upon either or both of those points, that'd be a win.
It seems to be thinner than Stan's and with a little more give. I think DT Swiss and Muc Off are the best tapes for most wheels. I do not like Stan's or Whiskey but I have never used Schwalbe.
Likes For Chandne:
#65
Quoted: 426 Post(s)
Liked 274 Times
enjoy!
enjoy!
from the good deal thread post #2973
https://www.bikeforums.net/22370478-post2973.html
I purchased these cheap rims and tires for $200. The tires have actually been great. I have used them on lot's of gravel rides. lol
Continental Grand Sport Clincher tyre – 28mm
the link says tubeless ready
https://www.probikekit.com/bicycle-w...ime=1641246181
Tyre Type: 2-way Fit Ready (For Clincher And Tubeless Ready)
Rim Width: 23,8 Mm
Inner Rim Width (Channel) : 19 Mm
Does that mean I need to buy tape that's 19mm?
Is this no name brand ok at $15 ( 1000 review )
https://www.amazon.com/BWSHLF-Tubele...NsaWNrPXRydWU=
or better to get the muc off one at $27 ( only 35 reviews. weird less reviews but it's a name brand )
https://www.amazon.com/Muc-Off-Tubel...13&sr=8-7&th=1
#66
Dead but dreaming
Quoted: 171 Post(s)
Liked 326 Times
Likes For KJ43:
#67
Dead but dreaming
Quoted: 171 Post(s)
Liked 326 Times
After I install my tape I run a bunched up (clean) rag over it to smooth it out, run a tire lever over the sides to get them down, and then install the tires to max pressure and see how they do overnight. I don't expect them to hold full pressure overnight, but it's a good test before putting sealant in.
Likes For KJ43:
#68
Quoted: 429 Post(s)
Liked 248 Times
Lol, I always seem to be late to the party! I think the above poster is correct I would go with a 21 mm or thereabouts. I prefer to use a namebrand rim tape like the DT or Muc off, It lasts as long as you need it to number of years for the few extra dollars but that’s just me!
