Is hood repair possible?
Bikes: 1987 Centurion Ironman Master, 1992 Koga Miyata Exerciser, 1992 Schwinn Crosscut
Quoted: 209 Post(s)
Liked 175 Times
Probably not, but you guys have amazed me in the past so I thought I'd ask.
(For reference, it's the inside of the right shifter...)
Could this split be tucked back together, then somehow re-fused to itself?
South Carolina Ed
Bikes: Holdsworth custom, Macario Pro, Ciocc San Cristobal, Viner Nemo, Cyfac Le Mythique, Giant TCR, Tommasso Mondial, Cyfac Etoile
Quoted: 344 Post(s)
Liked 291 Times
put some backing material inside (maybe fabric?) and glue it all together with gel super glue - amazing stuff
I've heard of people using automotive, form-a-gasket type stuff. Never tried it myself, but I did buy a tube thinking I might.
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4677 Post(s)
Liked 5,790 Times
Likes For gugie:
Quoted: 1606 Post(s)
Liked 2,570 Times
I've wondered, never tried, if that Flex seal would work. Those the 7400's? Good luck.
verktyg
Quoted: 1036 Post(s)
Liked 1,237 Times
A little trick that I recently discovered by accident...
First off take some 70% or 91% Isopropyl Alcohol and clean off any grease or oil that may be on the rubber surface.
Next, get a reinforced paper towel like Bounty and cut a small piece to use as a "boot" or backup over the inside of the tear. Next apply some instant glue to both sides of the gap in the tear and also to the inside of the hood in that area.
Place the piece of paper towel over the instant glue so that it soaks in. Hold the tear together until the glue hardens. If need be, add a little more glue on top of the paper towel boot.
I like Loctite Ultra Super Glue as it's easy to apply.
I should have taken some pictures the last time I did this.
verktyg
verktyg
Chas. ;-)
Chas. ;-)
South Carolina Ed
Quoted: 344 Post(s)
Liked 291 Times
I had another thought
something like Gorilla tape inside https://www.walmart.com/ip/Gorilla-B...-Roll/15160148
something like black silicone outside to fill gaps https://www.harborfreight.com/3-oz-r...ack-90024.html
Bikes: Still have a few left!
Quoted: 466 Post(s)
Liked 529 Times
No longer have the bike, but repaired a black French half hood using some of this liquid rubber + similar method to @verktyg above. Worth a try, has other uses too.
https://www.amazon.com/Star-brite-Li...6&sr=1-17&th=1
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3870 Post(s)
Liked 6,461 Times
This, at least for that hole. Black, of course. Find a few more projects around the house for it, because once you open the package, it doesn't keep. Like that hole at the rear of your Turbo saddle and the torn rubber clips on your grocery pannier. And wear disposable rubber gloves!
Shoe Goo. You can get it in clear or black.
Quoted: 209 Post(s)
Liked 175 Times
Thanks for all the suggestions!
I decided to try the Sugru. If it proves strong enough, despite a fairly thin layer, I will be duly impressed.
It went on easily, allowing plenty of time to mold. As you can see in the pics I sewed the rip together to "clamp" it while applying. I also spread a thin layer on a few other degraded spots, and may try a final coat of liquid electrical tape to smooth everything out.
Of course I did not heed the warning about using latex gloves, but acetone cleaned me up just fine.
I will report the final result after complete curing. The real test, of course, will be stretching it over the levers!
Likes For 67tony:
Quoted: 209 Post(s)
Liked 175 Times
Snagged some Liquid Electrical Tape today, and applied a coat.
Looks decent enough, and I figure another layer might smooth things out a bit more.
It's quite tacky, but I presume that'll dry up some with use.
No matter what the result, they're way better than previously...and I saved about a Ben Franklin!
Question.
Not wanting to over-stretch my Sugru repair, what would I use to install the hoods, in as SLICK a way as possible?
WD-40? Baby Powder? Dawn Dishsoap? Some other magical super-slippery concoction?
This pic is where the hole and bad rip was, on the outside of the right shifter. (post #1)
I stitched it up, then used the Sugru.
Question.
Likes For 67tony:
Quoted: 209 Post(s)
Liked 175 Times
Final result. Not perfect, but definitely serviceable.
Hopefully the Dura Ace groupset outweighs judgement of the refurbished hoods!
This is the side that had the hole.
The other three sides look pretty much like this one.
Likes For 67tony:
Liked 2,570 Times
I have a spray bottle with alcohol I use but I'm not sure what that would do to your repair materials.
señor miembro
Liked 6,461 Times
"What would [you] use to install the hoods, in as SLICK a way as possible?"
Dish soap.
Dish soap.
don't try this at home.
Quoted: 972 Post(s)
Liked 509 Times
You probably should have installed the hoods on the brake levers before the Sugru. It's adhesive, but can be peeled off of smooth surfaces with some effort. Stretching the hoods back on the levers will likely break the bond, but the sewing will help a lot.
I got the black 8 pack three years ago, and just used the last two packets this week. It keeps for at least 3 years in the fridge. I'll get another 8 pack soon, so I have it when I need it.
This was first, after using one pack for testing on some surfaces. My Nikon had the surface layer of the rubber facing peeling off where my hand held the camera. I cleaned the surface with rubbing alcohol, then lightly scuffed the surface with fine sandpaper.
The sugru is best applied by mashing small pieces onto the surface, pressing them in. Then it can be smoothed and worked with a finger. Wipe the finger with dry paper towels then smooth some more, ripples and bumps can be smoothed with enough passes. It can be worked for quite a while. It's pretty easy after the first session for practice.
Rubbing alcohol with a paper towel cleaned off my fingers when the job was complete.
This patch job isn't perfect -- I could do a better job now, and would probably also get some textured item to press into the surface for a better visual match. But it's been great, no peeling or wear for almost 3 years now. It looks a lot better in person than it does in this picture with highlights reflecting off the surface. The edge of the patch blends smoothly into the rest of the body -- nice!
A full pack. The packets are quite small, and have to be used up in the 30 minute time frame.
That camera repair used a small portion of one packet, as shown below. They can be smeared out to a thin layer if needed.
Other uses for the rest of it:
Fraying sewn seams on black biking shorts. I pressed a very thin coating over the threads. It's kind of ugly, but it completely stopped the fraying, and it's flexible so the shorts are still good.
Sticking a plastic kitchen towel hook to the side of the fridge. Very secure, but a putty knife should be able to remove it some day.
Molding a small "fin" to a micro usb2 plug, so I no longer try to use it upside down.
Fixing some broken black trim on the car -- not invisible, but good enough. That took a few packets to fill.
Molding longer zipper pulls on a winter jacket, so I can zip it with gloves on. I molded over a few loops of strong thread through the metal zipper hole for pulling strength.
