Quill seatpost can cause tube bulge, so how tight is TOO tight?
Old 08-16-16, 03:22 PM
shuru421
Quoted: 284 Post(s)
Liked 50 Times in 20 Posts
How should I go about possible over-tightening a quill seatpost? I guess its the insecurity thats sinking in, never had a quill seatpost, and reading about possible 'bulging' doesn't sound very nice, given the fact that I REALLY like my bike. So, whats the rule of thumb to go about this? Don't have a torque guide, nada. So, tighten till I can't tighten with my hands? Or should I use a handle-bar stem torque as a guide?
shuru421 is offline
Old 08-16-16, 03:28 PM
bulldog1935
Bikes: '74 Raleigh International utility; '98 Moser Forma road; '92 Viner Pro CX upright
Quoted: 939 Post(s)
Liked 5 Times in 5 Posts
I use green Loctite 609 in the seat tube in conjunction with quill seatpost, and get it as tight as I can torque with a 4" allen and no cheater - it's held for thousands of miles
bulldog1935 is offline
Old 08-16-16, 06:29 PM
shuru421
Quoted: 284 Post(s)
what do you mean by -no cheater?
shuru421 is offline
Old 08-16-16, 07:20 PM
gear64
gear64's Avatar
Bikes: State Black Label All Road, Univega Gran Premio, Lotus Classique, Terranaut Metro
Quoted: 105 Post(s)
Liked 94 Times in 62 Posts
some type of sleeve, tubing to make 4" allen longer for more leverage
gear64 is offline
Old 08-16-16, 07:41 PM
rekmeyata
rekmeyata's Avatar
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 1011 Post(s)
Liked 192 Times in 158 Posts
see this:
Notice it doesn't appear he's using much force at all to lock in with the allen wrench.
rekmeyata is offline
Old 08-16-16, 08:04 PM
FBinNY
Quoted: 5359 Post(s)
Liked 1,802 Times in 1,019 Posts
The same rule of thumb applies here as everywhere else.
Tighten everything tight enough to do it's job and no more.
It's a seatpost, and all you care about is that it doesn't slip. Once it's tight enough not to slip, tightening it any more can't make it slip any less than zero.
In fact many older timers and race mechanics, use a variation on this called "race tight". On a post you want to be sure that it can't slip or twist in normal, or even rough use, but can still twist at extreme loads as might happen in a crash. This can prevent saddle rails from twisting, or more important, reduce bruising between your legs if you go down badly in a crash.
Opinion follows.
I am not at all a fan of expander posts, especially sliding wedge types. They can over stress and (as noted) bulge thin wall seat tubes. They violate one key tenet of good design, namely that failure should be planned for and managed such that the cheaper part always fails first. Another tenet is that there should be the widest possible margin of error separating tight enough to do the job, and tight enough to fail.
IMO combining this post with a thin tube imposes a narrow margin. It can be widened by improving traction between the post and tube, and (obviously) by using a seat tube with a thicker wall.
FB
Chain-L site
“Never argue with an idiot. He will only bring you down to his level and beat you with experience.”, George Carlin
FBinNY is offline
Old 08-17-16, 01:56 PM
Chombi
Chombi's Avatar
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Quoted: 150 Post(s)
Liked 33 Times in 27 Posts
My youngest brother just never learns.....
He tightens fasteners to his personal, biological, "quivering hands and arms" tourque limit........ which is usually followed by a loud snap and "RATS!!" From where ever he happens to be working on something......
Chombi is offline
Likes For Chombi:
Old 08-17-16, 02:25 PM
shipwreck
shipwreck's Avatar
Quoted: 141 Post(s)
Liked 8 Times in 6 Posts
I have always just used a four inch allen like Bulldog said. But never used locktight, just greased the post like I would any stem. Its never slipped, so far with just regular hand tightening. Mine is in an aluminium schwinn 974.
shipwreck is offline
Old 08-17-16, 02:33 PM
shuru421
Quoted: 284 Post(s)
I believe it was a park tool, longer than 4 inches.. From the looks of it, the bolt that tightens the seatpost doesn't seem to be protruding A WHOLE lot so I think I might be in the clear? Ive searched to see how others seat posts were looking online and looks pretty similar. I was going by those pictures as a guide loll.
shuru421 is offline
Old 08-17-16, 02:35 PM
shuru421
Quoted: 284 Post(s)
Rekmeyata, I have watched that clip, however HIS 'tightest point' seems A LOT less than mine. I was going atleast 4-5 full circles. His was maybe more or less than 90 degrees. Wish mines was that easy.
shuru421 is offline
Old 08-17-16, 02:39 PM
non-fixie
Shifting is fun!
non-fixie's Avatar
Bikes: Yes, please.
Quoted: 2123 Post(s)
Liked 4,083 Times in 1,613 Posts
We have an expression here that would translate into something like: 'tight is tight enough". It means that one shouldn't tighten a bolt any more than necessary. In practice it means that you should use less force than you might be inclined to do. I have found that to be very sound advice.
I wanna be like you!
non-fixie is online now
Old 08-17-16, 02:49 PM
SquidPuppet
Calamari Marionette Ph.D
SquidPuppet's Avatar
Bikes: 3 Chinese Gas Pipe Nerdcycles and 2 Chicago Electroforged Boat Anchors
Quoted: 2358 Post(s)
Liked 33 Times in 26 Posts
+1
Do tighten it until the component stops moving. Don't tighten it until the bolt stops moving.
SquidPuppet is offline
Old 08-17-16, 03:11 PM
randyjawa
randyjawa's Avatar
Quoted: 1361 Post(s)
Liked 1,711 Times in 921 Posts
The trick is knowing what is enough? And, though it might look like he is applying little force, he is applying the force to a cam. Try using a four inch skewer lever and see how tight that gets with just a bit of force. The power of the cam is pretty impressive and that cam, don't forget, is driving a wedge into place.
BE CAREFUL would be my approach to using a quill seat post on any of my bikes. Plus, on a regular bike, only the lugged area is actually applying force to clamp the post is the seat tube lug. There are so many things to consider.
For my money, or lack of it (I am married with kids and grand kids), I probably won't be using a quill seat post ever. Of course, this Skyway does use a quill post and it is still in Thunder Bay and I really like the bike...
But it is not made of exotic thin walled tubing.
randyjawa is offline
JBerman
Road Cycling
59
04-04-17 02:37 PM
Rest_assured
Bicycle Mechanics
25
04-09-14 03:46 AM
boggy
Road Cycling
11
07-30-12 04:13 PM
MrEss
Classic & Vintage
17
02-18-12 03:27 PM
todayilearned
Road Cycling
22
10-23-11 04:47 AM
