Lightest steel freewheel?
Old 09-02-13, 10:21 PM
Campy12
With alloy being fairly useless as a freewheel material and Titanium being waaaay overpriced if someone was going for a lightweight steel freewheel what is the lowest weight option? Currently my Regina 6 speed 13-21 is 340grams and my 5 speed Suntour winner pro 13-21 is 334grams. Anyone?
Campy12 is offline
Old 09-03-13, 03:19 AM
Blue Belly
Blue Belly's Avatar
Bikes: Pinarello Montello, Merckx MX Leader, Merckx Corsa Extra, Pinarello Prologo, Tredici Magia Nera, Tredici Cross
Liked 4 Times in 3 Posts
Good question! I think my findings have been similar to yours. Anyone?
Blue Belly is offline
Old 09-03-13, 05:50 AM
pastorbobnlnh
Freewheel Medic
pastorbobnlnh's Avatar
Quoted: 1378 Post(s)
Liked 1,934 Times in 862 Posts
Good question. I've never weighed any of the hundreds of freewheels I've worked on.
Of course there are two variables in every freewheel's weight; the body and the cogs & spacers. Bodies can vary significantly. For instance, without seeing a picture of your two freewheels, I'd guess the 4 gram difference is primarily in the bodies. Regina bodies tend to use less steel than say a Suntour, Shimano, or Sachs.
For instance, look at this Regina Corsa. Originally this design was for a 4 speed freewheel. Regina then determined how to thread the two smallest cogs together, adding the fifth cog. Eventually this same model could thread the three smallest cogs together without enlarging the body, making it a 6 speed.
But now look at the progression in Suntour Perfect bodies. These three pictured bodies are all Perfects. L to R: 6 speed standard, 6 speed Ultra spaced, 5 speed. The difference in body size is apparent.
The second variable would be how much the cogs and spacers weigh. The oldest models tended to use steel spacers. Newer models almost exclusively use plastic spacers. In regard to the cogs, older cogs tended to be solid with no cutouts, newer cogs usually have more drillium on the cogs.
Bob
pastorbobnlnh is offline
Old 09-03-13, 06:15 AM
RubberLegs
RubberLegs's Avatar
Bikes: 87 Bridgestone 550 (Shocking Electric Metallic Pink)
Over at the Weight Weenies site, they have weights on a lot of cassettes, but not on freewheels....guess they are not into C&V!!! :-)
RubberLegs is offline
Old 09-03-13, 06:28 AM
Velognome
Get off my lawn!
Velognome's Avatar
Bikes: 1917 Loomis, 1923 Rudge, 1930 Hercules Renown, 1947 Mclean, 1948 JA Holland, 1955 Hetchins, 1957 Carlton Flyer, 1962 Raleigh Sport, 1978&81 Raleigh Gomp GS', 2010 Raliegh Clubman
Quoted: 93 Post(s)
Liked 97 Times in 47 Posts
The answer will include drillium
Velognome is offline
Old 09-03-13, 07:40 AM
rhenning
Quoted: 380 Post(s)
Liked 106 Times in 80 Posts
Depending on how many gears you want a BMX single sprocket freewheel will be the lightest. At least the ones I use on my single speeds are. Roger
rhenning is offline
Old 09-03-13, 08:21 AM
RubberLegs
RubberLegs's Avatar
I threw some of the spare Freewheels I have laying around on my scale, SORRY, it is in OZ...it is what it is...big difference is, the more gears you have, the more they weigh....BIG SURPRISE!
Shimano MF Zo12 5 speed 14-28 13.5 oz
Regina Corsa 5 speed, 13-26 13 3/4 oz
Shimano Sante' 7 Speed, 12-23 14 1/4 oz
Shimano MF Zo12 6 speed 14-28 15 1/4 oz
Shimano UL 7 speed 14-28 17 oz
Sachs Maillard 8 speed 13-30 20 1/4 oz
Old 09-03-13, 08:57 AM
Zieleman
Zieleman's Avatar
Bikes: Enough for now
Liked 5 Times in 5 Posts
And Dutch gearing
Zieleman is offline
Old 09-03-13, 09:29 AM
Campy12
How much drillium do you think the steel cogs can handle safely? I've seen people go crazy on alloy chainrings. Without going into the teeth or too near the threads would lots of carefully placed drillium reduce weight noticeably without scraficing too much strength?
Campy12 is offline
Old 09-03-13, 09:40 AM
southpawboston
southpawboston's Avatar
Quoted: 78 Post(s)
Liked 179 Times in 86 Posts
Good thing you're in a clergical line of work there, Bob, and not accounting.
That's interesting. I have two Suntour freewheels, a Winner Pro and New Winner, both 6-spd, with similar sized cogs. The Winner Pro is much lighter than the New Winner, but I haven't dismantled them to see where the weight difference is coming from.
southpawboston is offline
Old 09-03-13, 10:12 AM
spacemanz
spacemanz's Avatar
Bikes: Frejus/Bertin/Cannondale
This might be a contender, maybe. How about Suntour's Pro Compe, in 5-speed or 6-speed? I'd never heard of these until yesterday, when I scored an old Nishiki with a Sunshine Gyro Master rear hub, and the 5-speed version Pro Compe freewheel, which is gold colored (the 6-speed one is silver). I've already been to Velo Base, and there was very little info there. EDIT: After a bit of cleaning, I see this particular freewheel must have had VERY little use, and/or the bit of grease really protected it pretty well. It's a nice sensible 14-28, in excellent condition, but I also see now, that it wasn't "really" all that special, just very decent for the day.
spacemanz is offline
Old 09-03-13, 10:16 AM
Campy12
Has anyone drilled cogs before? I'm going to use my NOS winne pro 5 speed and only the largest cog has cutouts. Even the Campagnolo alloy freewheel in 13-21 has the three largest cogs drilled. I imagine that same drilling wouldn't affect steel like it would on the factory drilled aluminum.
Campy12 is offline
Old 09-03-13, 10:44 AM
Dave Mayer
Dave Mayer's Avatar
Quoted: 1155 Post(s)
Liked 411 Times in 242 Posts
I have a 50 pound pail of 6 and 7 speed Dura-Ace freewheels and spare cogs. I also have an equivalent stash of Winner and Winner Pro hardware. So here is my unbiased advice.
The best freewheel right now for the combination of light weight and shifting quality is Shimano's TZ20 and TZ21 (6 and 7 speed respectively) Tourney freewheels. Why:
  • They cost less than $15 each.
  • They feature Shimano's superior Hyperglide cog profiles, which provide worlds better shifting than any of the old freewheels. Uniglide and Suntour freewheels were somewhat better than the old Italian cogs, which were hopeless.
  • They have a unique design in which the 2 largest (heaviest) cogs are heavily cut away and supported (pinned to) the smaller cogs. This accounts for their low weight.
  • They have a sensible 14-28 gear range. This elimates the useless 11 and 12 tooth cogs found in current cassettes, and includes lower gears for use with standard crankets. We're not getting younger.
Dave Mayer is offline
Likes For Dave Mayer:
Old 09-03-13, 11:27 AM
delicious
delicious's Avatar
Quoted: 87 Post(s)
Liked 60 Times in 34 Posts
Great info, Dave. Do you know how much the 14-28's weigh?
delicious is offline
Old 09-03-13, 11:31 AM
Pars
Pars's Avatar
Bikes: '73 Raleigh RRA, 1986 Trek 500 commuter
Quoted: 54 Post(s)
Liked 16 Times in 11 Posts
Conversely, have you looked at the bodies on these Tourney freewheels? They only extend maybe halfway thru the freewheel and seem rather chintzy. I would question their reliability and durability. I have one and haven't used it for this reason.
Pars is offline
Old 09-03-13, 11:54 AM
Chombi
Chombi's Avatar
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Quoted: 150 Post(s)
Liked 33 Times in 27 Posts
Per my experience, most steel FWs with the same number of speeds, weigh very similarly. I don't think the little difference between them is ever going to be noticeable on the road, so picking your steel freewheel on the basis of weight is a bit pointless. I still think that hybrid Al (cogs)/Fe (body) FWs is not a bad way to go if you want to lose some weight. At least you won't have to worry too much about stripping pin wrench holes or notches on them, if you have to remove the thing from your rear wheels. The Zeus 2000 FW is a good one, and the Al cogs for them are still available from sellers at eBay.
Chombi is offline
Likes For Chombi:
Old 09-03-13, 12:25 PM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3856 Post(s)
Liked 2,526 Times in 1,555 Posts
I wonder if that's because the hub+cluster is already lighter for cassette systems, or if other benefits to cassette wheels make freewheels not worth considering for that group...
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 09-03-13, 12:27 PM
miamijim
miamijim's Avatar
Quoted: 413 Post(s)
Liked 103 Times in 76 Posts
They can handle a lot but most of them are already 'drilled' or have big windows.
miamijim is offline
Old 09-03-13, 12:32 PM
Lascauxcaveman
Lascauxcaveman's Avatar
Quoted: 1626 Post(s)
Liked 625 Times in 355 Posts
[*]They have a sensible 14-28 gear range. This elimates the useless 11 and 12 tooth cogs found in current cassettes, and includes lower gears for use with standard crankets. We're not getting younger.[/LIST]
Useless? I'm not so old that I can't enjoy a +45mph descent every now and again And I live among hills that make that doable, if I wasn't all spun out around there.
Lascauxcaveman is offline
Old 09-03-13, 12:34 PM
RubberLegs
RubberLegs's Avatar
Originally Posted by miamijim
They can handle a lot.....
Sounds like a challenge...Oh Drillium Dude!!!!!! I don't even want to think about how many bits cutting all that hardened steel would cost me!
Old 09-03-13, 12:39 PM
Campy12
I would never put a $15 shimano on my full vintage super record bike! Gross. 13 is as big as I'd like my smallest gear.must not descend much where you are from. Which also makes the 28 useless. All in good humor of course. I think I'll just disassemble my sun tour and drill the cogs and be happy.
Campy12 is offline
Old 09-03-13, 12:46 PM
miamijim
miamijim's Avatar
Quoted: 413 Post(s)
Going through my 30+ freewheels this is what I've found:
Steel freewheels weigh between 350 and 400 grams depending on gearing. There're a few outliers, a Suntour 13-23 7s I have weighs 335, a Sachs 14-24 6s weighs 411.
A few samples:
Suntour Microlite 194g
Dura Ace 13-21 360
Dura Ace 13-21 398 I don't know why this weighs more, I double checked the weights
Helicomatic 6s 400g
miamijim is offline
Old 09-03-13, 12:57 PM
noglider
noglider's Avatar
Quoted: 7138 Post(s)
Liked 2,086 Times in 1,240 Posts
I have a modern Shimano freewheel on my McLean. It's a wear item, like tires and brake cables. As Dave points out, they're a heck of a lot better than older freewheels. And I do trust it, even though it's chintzier.
noglider is offline
Likes For noglider:
Old 09-03-13, 01:18 PM
Campy12
I use only NOS parts on my drivetrain. I replace the freewheel and chain an usually rings all at once. I can get years out of the system as a whole. They wear but not that fast.
Campy12 is offline
Old 09-03-13, 01:21 PM
old's'cool
curmudgineer
old's'cool's Avatar
Bikes: 2 many 2 fit here
Quoted: 263 Post(s)
Liked 110 Times in 69 Posts
The wear items are the cogs. The body will last longer than any other moving part on the bike, with a modicum of care. That goes for the ball bearings as well, which are at any rate cheap to replace, in the unlikely instance of needing replacement.
Of course, the internal lubrication cannot be expected to last forever, this comes under the "modicum of care" proviso.
For some C&V enthusiasts, it is practical to dismantle and overhaul freewheels, and for others, it is more practical to discard and replace them.
old's'cool is offline
