Trek Boone Crockett other? Disc owners wanted
Old 04-28-20, 07:00 PM
joejack951
joejack951's Avatar
Bikes: 2016 Hong Fu FM-079-F, 1984 Trek 660, 2005 Iron Horse Warrior Expert, 2009 Pedal Force CX1, 2016 Islabikes Beinn 20 (son's)
Quoted: 1242 Post(s)
Liked 94 Times in 65 Posts
Per the thread title, I'm looking for owners of Trek disc brake cross and gravel bikes, more specifcally, those with 15mm thru axles forks (but not the Domane as I have that sorted already). I'm gathering info in an effort to make a 12mm thru axle conversion kit for these forks which have M14x1.5mm threads as a permanent part of the fork leg (as opposed to part of an insert, like the Domane). See here for some background on what I've been up to: https://weightweenies.starbike.com/f...9055&start=135
These kits allow you to run 12mm wheels in a 15mm fork, something that previously wasn't possible (not to be confused with using 15mm wheels in a 12mm fork which is a far simpler problem and addressed several times over).
In addition to the fork, you'll also need digital calipers to take various measurements for me, and probably a good dose of patience as I ask lots of questions. Bonus points if you are local to DE, 19803 and willing to meet up. Obviously some comp'd product is up for grabs for anyone who can help me out.
Thanks in advance!
joejack951 is offline
Old 05-07-20, 11:52 AM
joejack951
joejack951's Avatar
Bump. Anyone? 920 owners, too.
Old 05-29-20, 07:08 AM
joejack951
joejack951's Avatar
For anyone curious, here is the solution that will be ready in about a month:
The kit uses a special thread adapter and locking nut to secure it to the fork leg due to the M14x1.5 threads. Everything else is similar to my other kits, additional details of which can be seen here:
and here...
https://gravelcyclist.com/bicycle-te...th-15mm-forks/
Old 07-10-20, 07:55 AM
joejack951
joejack951's Avatar
Yeah, so that took a lot longer than anticipated. But it's here:
Likes For joejack951:
Old 07-19-20, 07:18 PM
dwmckee
dwmckee's Avatar
Quoted: 427 Post(s)
Liked 339 Times in 229 Posts
Can this work on any 15mm TA fork? Why not just make the axpe 15mm at the head instead of having a separate insert in teh fork? That would cut down on the number of parts to machine... I'd love to put this on a Lauff fork.
I may be a customer!
dwmckee is offline
Old 07-19-20, 08:26 PM
joejack951
joejack951's Avatar
1. This specific kit, no, as it is made to fit the unique Trek forks that use M14x1.5mm threads in a non-removable insert in the fork leg. But I do make a kit for Lauf's suspension forks. That kit is more 'standard' in that it uses my original style of thread adapter, made from aluminum and reducing from M15x1.5mm threads to M12x1.5mm threads, that screws in from the outside of the fork and does not use a locking nut. That kit can be found here: https://www.ebay.com/itm/114044322669
2. I considered that very early on but my original plan when I finally decided to start making kits did not include making axles. That didn't work out for several reasons and it's been for the better that I now make axles in specific lengths to fit forks converted with these kits. Most of the kits add some width to the fork and making custom axles allows me to offer one that fits perfectly even when the same length as the original 15mm axle is available. But many of the conversion kits that I've started producing are uncharted territory for 12mm axles. Trek forks, and a few others, use a 140mm long axle (stock is 138mm). The Lauf kit uses a 152mm axle. Try finding those sizes anywhere in 12mm.
Now, as to why I didn't make axles with the reducing sleeve as part of the axle, a. it allows my inventory to be more flexible. Some axle lengths get paired with 5 different sleeve lengths and I haven't been at this long enough to know exactly what will be ordered and the thru hole inserts are cheaper to stock than axles. And b. making that sleeve a separate part allows for a normal axle to be used in a pinch if the special axle were to be lost or damaged.
Happy to answer any other questions or provide more detail. A lot of this is easier to explain with the forks and kits sitting in front of us. I go into some detail in my other YouTube videos about these kits so they might be worth a view if you are curious.
Old 07-19-20, 08:46 PM
dwmckee
dwmckee's Avatar
Quoted: 427 Post(s)
Thanks for the info. We are a gravel shop that deals with this sort of need regularly!...
dwmckee is offline
Old 07-19-20, 08:54 PM
dwmckee
dwmckee's Avatar
Quoted: 427 Post(s)
Will the link you sent work on the original Lauf fork and the 3T Luteus fork used on the OPEN Classic frame, or would that be a different part?
thanks!
dwmckee is offline
Old 07-19-20, 09:21 PM
joejack951
joejack951's Avatar
thanks!
The 3T Luteus II fork has its own special kit: https://www.ebay.com/itm/114257282214
So far, I offer 16 different kits. Within the next two weeks I’ll be adding about 5 more, most of which are kits I have been providing but just at very low volume using modified parts from my inventory. There are a couple known gaps that will get addressed soon after that as well but for the most part, if you’ve heard of it, I have a kit for it.
Dealer inquiries are always welcome!
Old 07-23-20, 10:40 PM
dwmckee
dwmckee's Avatar
Quoted: 427 Post(s)
This is excellent! So glad I have found you. Will be in touch.
dwmckee is offline
