Did I damage my new carbon frame ?!
Hi everyone , I bought a new cervelo carbon frame and I asked a friend to come help me build it. All went good except when he was checking the crank, he decided to give it a spin real hard to check the new bottom bracket and he was holding an Allen key and he hit the down side of the chainstay with A LOT of force and a loud bang. A moment of silence as we expected the worse.
there was a small paint chip, as I can see, not sure if it is a crack or not. I was a bit nervous so I started the tap test and exactly on this paint chip/the part the Allen key hit, the sound is different and a little bit faint without loud pitch like both areas next to it .
I attached a picture and a video. Unfortunately where I live no one can check the carbon for structural integrity. I feel awful that the bike is brand new with zero miles on it and the chainstay might have been compromised. Anyone who can shed some light or any suggestions would be really helpful.
thanks
thanks
Expired Member
Quoted: 3638 Post(s)
Liked 5,316 Times
Bummer.
Quoted: 2304 Post(s)
Liked 2,741 Times
maybe these guys can do some thing remote? https://ruckuscomp.com/
Likes For squirtdad:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
1) Your 'friend' is an idiot.
2) That looks like nothing more than a paint chip. I'd want to tap it a little harder, maybe w/ a 5 or 6mm wrench to see how it sounds.
I think at this point I'd ride it and keep a close eye on it.
Likes For cxwrench:
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
Carbon is not as fragile as some folks think.
Likes For Badger6:
I tried with a 5mm and the sound seems more uniform, when I use the smaller wrench it happens exactly on the paint chip, dull/dead sound.
it’s my first carbon bike and honestly I am hesitated to ride it with the horror stories that I read online. I don’t know what to expect and if this chip is something or nothing.
I am not sure if it is as fragile or not. But what I witnessed is scaring me, especially after the tap test, which seems that a tiny area has already been compromised at least.
I wouldn't hesitate to ride that frame for a second. I've crashed my TT bike at speed a couple of times and it's still solid as a rock - I was far more damaged than my bike lol . You can always take it down to the LBS and have them check it out if you're really concerned. I doubt they have an x-ray in the shop but they might know where to send it, at least.
Likes For BHG6:
Quoted: 532 Post(s)
Liked 621 Times
I am sure. It's not "bulletproof", but I'd ride that without any concerns...the forces required to damage the carbon structure in such a way that it would be compromised in that place aren't possible with what you guys were doing. The chain stays are quite robust, because they have to be, especially on the drive side. So, maybe better stated, "Carbon frames are not fragile." Good luck.
Likes For Badger6:
Quoted: 194 Post(s)
Liked 204 Times
So stop reading the horror stories, the authors' only care for your likes not your life. Look at the stories this way - how many cyclists die on the road every year through all kinds of accidents? Does this stop you wanting to ride? Does this instead encourage you to be vigilant?
Keep an eye on the area of the chip and how the bike feels while you are riding it. Be vigilant, rather than the puppet of someone else's clickbait campaign.
Likes For Geepig:
Quoted: 581 Post(s)
Liked 921 Times
An allen key held in the hand is unlikely to damage a frame. Imagine the rocks and debris that should be expected to come flying at the downtube during normal use.
When I first read the story of two people working on a bike and one spinning the crank I got nervous for the outcome, because even a crack in a carbon frame (which does not seem to be the case here) is a lot less painful than a hand caught in spokes of a spinning wheel, or between a chain and the teeth of a chainring of a spinning drivetrain.
If there had been an 8mm allen key sticking out the back of one of the crank arms, like to install a pedal, could also cause real damage to the frame. As it is, I don't think there is much to worry about.
Likes For ClydeClydeson:
Quoted: 1217 Post(s)
Liked 1,281 Times
There is obviously nothing wrong with the frame. But perhaps Carbon is not the material for you and you should sell the bike. If this small mark is enough for you to question the frame, lose a friend and reach out to both these forums as well as a carbon repair firm you will never feel comfortable on a carbon bike. Steel adventure bike may be a way to go, very robust and fun to ride.
Bikes: A few too many
Quoted: 1359 Post(s)
Liked 2,173 Times
Ride it .....IMO It's just a chip...nothing more nothing less.
Voltaire
Voltaire
Likes For xiaoman1:
LR÷P=HR
Quoted: 848 Post(s)
Liked 1,161 Times
When your buddy hit the chain stay, did he break his fingers
Barry
Barry
Likes For Rogerogeroge:
Likes For blamester:
Likes For trailangel:
it’s my first carbon bike and don’t know what to expect as far as how can carbon hold to crashes or forces.
Since the majority is encouraging me to ride it and keep an eye from time to time on the area. I will do so until an issue arises, hopefully nothing will happen.
It’s my first full carbon bike and I don’t know how carbon reacts in crashes or forces applied to it, and when he hit it hard and there was a loud bang like hitting with a hammer we only expected it to crack that’s why I am worried as I don’t have expectation how carbon holds up.
Likes For SoSmellyAir:
Liked 1,281 Times
I really don’t care about the paint chip at all even the bike is new. My concern was only and only the integrity of the carbon structure as the amount of force was so high when he hit the chainstay , imagine spinning a crankset without a chain to check how many rotation it can go till it stop (bearing test), and you didn’t think that the tool in your hand will hit the bike, he give it all his force that’s why I am worried not a simple paint chip , it’s a bike and it will get chips and scratches and I can live with that.
As mentioned earlier, sell the bike now as it is in new condition and given the marketplace probably get all your money back. Your reaction over a tiny paint chip in the most durable part of the bike means you will never be at ease. Things are going to happen if you decide to ride it, perhaps another friend may lean their bike against yours or accidentally bump it when leaning on something. Carbon is not for everyone, such deep seated anxiety over its durability would just take the fun out of it for you.
Likes For Mosman12:
Blamester
again, my reaction wasn’t over a tiny paint chip. If it is purely cosmetic I don’t care even the bike is new. My concern was over the blunt force he hit the chainstay with , and what have happened beyond the chip to the chainstay carbon integrity at this spot. As it is my first carbon bike, the amount of force I’ve seen would definitely dent an aluminum tube so I didn’t know what to expect from a carbon one !
In a area like that tapping won't tell you a lot.
Sit on the bike bounce up and down on the pedals and saddle. See shat happens.
Take it for a slow spin bouncing up and down on it.
If you think about it carbon can't be that delicate or it would be useless.
Bikes fall, get knocked, hit potholes and kerbs.
The bike manufacturer knows that.
Quoted: 83 Post(s)
Liked 64 Times
Relax and invite your friend for a beer ride. I have quite a few chips like that (or worse) on my road bike and you will too if you ride yours enough. Mines been through a couple minor crashes, knocked down several times while parked and bent the hanger twice. Lots of gravel chips too but my new gravel bike is carbon for that purpose Some repair shops recommend covering chips in clear acrylic nail polish or a dab of epoxy to seal water out. I’ve ridden carbon enough years to no longer worry.
Likes For veloz:
