Converting Quick Release to Wing nuts
I have a Fuji Helion mini velo with quick release axel. Been working on this bike. Looks so classic and vintage with all the mods. I just got some vintage wing nuts and they don’t seem to fit existing QR axel.
The OP probably needs to either find a suitably-long axle that will work with their hub, or find a different wheel or hub that has a suitably-long axle built in.
edit: But you're right, if the nuts don't thread onto the axle even when it's off the bike, that's another problem to deal with.
Likes For beng1:
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Likes For Rolla:
Quoted: 3509 Post(s)
Liked 2,924 Times
Quoted: 506 Post(s)
Liked 638 Times
Remember that the quick release was invented by Tulio Campagnolo because wing nuts are such a pain. And you would need a longer axle so that there is enough protruding past the dropout so that the wing nuts can get adequate purchase. Seems like a kludge. But then maybe you are "A dedicated follower of fashion" (See Ray Davies)
SE Wis
Quoted: 2746 Post(s)
Liked 3,390 Times
I don't believe wing nuts were ever made in 9 or 10mm modern axles sizes. Most are 3/8 or 5/16
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
SE Wis
Liked 3,390 Times
https://www.bikeforums.net/classic-v...-new-ones.html
Clark W. Griswold
Quoted: 4349 Post(s)
Liked 3,986 Times
Wing nuts are terrible, they do look cool on a vintage machine but they are tightened by hand and need to be checked regularly for them coming loose so you don't lose a wheel while riding and have a nasty crash
If you want to fancy things up and give it more of a vintage look these are a treat, I have them on my touring bike and they are fantastic:
https://www.paulcomp.com/shop/compon...lease-skewers/
Likes For veganbikes:
Quoted: 2482 Post(s)
Liked 2,952 Times
https://www.ebay.com/itm/303217564380
Liked 2,924 Times
Quoted: 1943 Post(s)
Liked 2,164 Times
My understanding for wind nuts was to be able to easily remove a wheel without needed a wrench.
The issue is that you cannot apply enough torque to get them sufficiently tight. There is just not enough leverage.
John
John
Likes For 70sSanO:
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
A vice grip could be clamped onto each end for more leverage.
Liked 2,924 Times
Liked 2,952 Times
Vice grips were routinely used to secure the rear-wheel wing nuts on Peugeot A08s and the equivalent Gitanes and Merciers and so on when I worked in bike shops in the early '70s. The Huret wing nuts were a bit painful to loosen and tighten by hand. Some other company made nicer polished wing nuts with larger wings that were capable of securing rear wheels properly, but I don't remember the company's name, if I ever knew it.
Liked 2,952 Times
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
Not hearing a lot of love for wing nuts - I've never had to to deal with them.
Quoted: 9653 Post(s)
Liked 6,365 Times
Bikes: lots
Liked 2,932 Times
Likes For cxwrench:
Quoted: 1397 Post(s)
Liked 1,876 Times
back in the day I had a Sears Free Spirit 10 speed with wing nuts
purchased it used - so don't know if the bike was equipped with wingnuts from the factory or they were installed by the first owner
Clark W. Griswold
Liked 3,986 Times
