100mm travel fork recommendations?
Bikes: Focus trash find commuter, Eddy Merckx Corsa, BP Stealth TT bike, Leader 720 TT bike, Boardman Comp Hybrid drop bar conversion, Quantec CX budget cyclocross build, SerottaNOS frameset ready to build up!
Quoted: 128 Post(s)
Liked 103 Times
Hi all, I’m looking to upgrade my 29er e-hardtail.
the current coil shock is pretty rubbish.
I’m thinking an air suspension fork would be an upgrade, I assume that I need to stick with 100mm of travel to keep the geometry the same.
Typical use would be bumpy trails and fast descents. No jumps, I’m too old and talentless for that.
thanks in advance for any suggestions, I’m in no way an expert so just act like you’re communicating with a small dull child.
Clark W. Griswold
Quoted: 4335 Post(s)
Liked 3,958 Times
We would need to know axle to crown and what sort of fork you need say like tapered or threaded, 1", 1 1/8", axle type...
Travel is not super important I swapped from a 100mm fork to a 140 because the A2C is actually the same or very very close (within a few millimeters). I would recommend looking at the Fox AWL fork assuming it fits your frame as it was designed for e-bikes and has some future proofing built in with the Bosch ABS mounts. I personally went all out only because I love Kashima coating and got the Fox Factory 36E also knowing that my fender mounting would work as Riese and Müller use fenders and Fox forks on some of their builds and had the needed mounting hardware available.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,102 Times
Depends a lot on the level of your bike and your budget
Good bikes now all have 110mm spaced thru axle hubs, tapered steerers, and disk brakes. You can buy forks for these at all levels.
Forks for 100 spaced, QR axle, rim brake bikes are not very good.
Functional forks start at >$200 and really good forks >$500. Premium forks $1000 and up
Genesis 49:16-17
Genesis 49:16-17
If it's a Suntour spring fork, look at the Suntour upgrade program. You can upgrade to an air fork fairly inexpensively and they can talk you through fit etc. Not saying they are the greatest, but we are not doing jumps, drops or such so we don't need anything crazy and did that route. I have a Rockshox Recon on my bike and doubt I will ever push it. I'm 43 and haven't hit a jump since I was 12. Our trails have a few roots and rocks but are mostly hills and cutbacks. Nothing that's going to tax the fork component, just my cardio, lol.
Quoted: 878 Post(s)
Liked 813 Times
I have a Manitou Markhor (100 mm, straight steer tube) on a 15 or so year old Niner and it has functioned perfectly (cross country) for two years. The cost was about $225 plus tax.
Disco Infiltrator
Liked 2,102 Times
If you are ready to buy something today... 30% off Fox and Marz
https://www.mtbr.com/threads/30-off-...occhi.1210245/
Genesis 49:16-17
Genesis 49:16-17
Quoted: 128 Post(s)
Liked 103 Times
Thanks all for the advice so far, I will measure axle to crown and then revive the thread.
Likes For Barchettaman:
Clark W. Griswold
Liked 3,958 Times
Quoted: 128 Post(s)
Liked 103 Times
Gotcha, will do. Thanks again all.
Quoted: 128 Post(s)
Liked 103 Times
Consider the MRP Ribbon SL: A stout chassis, lightweight, and highly adjustable air spring that allows to set the pressures on positive and negative chambers independently.
Steel is real
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1998KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon,1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Quoted: 666 Post(s)
Liked 964 Times
Rock Shox Silver or Rock Shox Pilot would be my pick
