Ear protection when pumping tires
#51
Shawn of the Dead
Quoted: 277 Post(s)
Liked 448 Times
Have you ever ridden a modern 32c road bike tire at 60 or 70 psi ? I have ridden many thousands of miles on high pressure 23 on 25c tires. For me the 32s are worlds better. I would think that ride quality would be improved for anyone on larger low pressure tires. Especially someone at 220 plus pounds.
You might think 23s at tube destroying pressure and a mattress of concrete are super comfortable....most of the world would disagree.
Ride what you want at whatever pressure you want but there is a reason that more and more bikes come equipped with wider and lower pressure tires. That's because the vast majority of cyclists find them to be faster and more comfortable. Its great that the pro's want crazy high pressures and skinny AF tires. It makes sense for them to do that. For almost everyone else it the opposite.
#52
Quoted: 3510 Post(s)
Liked 2,924 Times
#53
Liked 2,924 Times
#54
Klaatu..Verata..Necktie?
Quoted: 10424 Post(s)
Liked 11,895 Times
From the article smd posted - dated 2017:
"While air pressure usually varies by riders’ weight, most Tour competitors race on something between 6.5 and 8 bar (94-116psi)."
So, even five years ago, the TdF riders were generally pumping up their tires to pressures well below the rock-hard level. Since then, several teams have switched to tubeless, and are almost certainly running lower pressures than that.
#55
Quoted: 4255 Post(s)
Liked 1,354 Times
How the heck did you miss the other stuff I wrote?
Read everything I wrote.
Larry's claim is dumb. Talking about TdF riders isn't relevant to his situation. Why are you trying to divine meaning in his meaningless comment?
#56
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,204 Times
18mm tire
I'm now 58 years old.
In my younger days we "knew" narrow and high pressure was fast.
So I rode 18mm @ 120++psi. (Wolber ... if anyone remembers those)
Yes 18mm did exist, not a typo!
Come to find out, science and systematic testing has proven we were wrong.
Wider and lower pressure are the new fast.
Welcome to the 21st Century
Barry
Barry
#57
What are you talking about? I didn't "infer" anything. Larry was directly objecting to icemilkcoffee's claim that TdF riders were going bigger than 23s:
Likes For HTupolev:
#58
Liked 2,924 Times
I did read everything you wrote. I wasn't quoting Larry when I used the modifier, "pretty." He did day "narrow." When referring to TdF riders, so it IS relevant. And I submit that most folks on this site consider 25c to be "narrow."
Likes For Ironfish653:
#60
Shawn of the Dead
Quoted: 277 Post(s)
Liked 448 Times
Srsly ? No spandex panties here ... I wear loose shorts as often as not...and as I stated ... I ran pressures like that for years and it was indicated on the sidewall....until it became unnecessary.... and no permissions granted ....this is an internet forum... as far as my kindness to you. I have none ...you might be a total tool.
People jump in with suggestions that maybe lower pressures and wider tires have these benefits and it turns into a pissing match... and you steadfastly refuse to even concede the thought that lower pressure tires might possibly be better even for you oh king of comfort.
Hopefully your eardrums will survive the explosive blow outs from your PSI decisions.
#61
Liked 2,924 Times
#62
Liked 2,924 Times
#63
Liked 1,354 Times
Larry wasn't talking about TdF riders using 25mm tires.
You aren't reading stuff carefully at all.
#64
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
"Back when 25mm tyres were becoming a thing, one French team asked its tyre sponsor to label all the new 25mm tyres as 23mm. The mechanics knew that the wider tyres were faster, but also knew that the riders wouldn’t like the change."
https://road.cc/content/tech-news/to...-choose-276949
Likes For Rolla:
#65
I'm not "moving goal posts", you just didn't read the prior conversation. I assumed that he meant 23mm or less because that's literally what he was writing in reference to.
#66
Quoted: 1561 Post(s)
Liked 1,734 Times
Most folks are fine with 25mm. Most of my bikes are on 25mm. The problem is that Larry is pushing 300lb.s. That is the crux of the issue. What works for a 160lb TdF rider, is not going to work for a 300lb rider. At that weight he should be riding 32mm. It's not a conspiracy by Big Gravel. It's just fundamental physics. Large rider needs wide tires. You don't put 185/60/14 tires on a F150 truck, do you?
Likes For icemilkcoffee:
#67
Liked 11,895 Times
See post immediately above yours.
#68
Liked 2,924 Times
#70
Liked 11,895 Times
Dude. Give it up. You were wrong. No shame in that, only in pushing a bad position when you've been proved wrong.
#71
Liked 11,895 Times
He didn't really infer or assume. He concluded, based on the fact that Larry QUOTED the assertion that TdF riders gave up 23mm tires and claimed they had not. It's clear as day. Continuing to claim that he didn't do what he plainly did is nonsensical and embarrassing.
Likes For genejockey:
Likes For njkayaker:
#73
Liked 2,924 Times
Talk about not making sense. I didn't infer anything from his text. After reading it, I did independent research and simply googled what size tire were they running in the TdeF, and the 25c quote came up. Why did you assume I inferred 25 mm from his text??
#74
Liked 11,895 Times
#75
Liked 11,895 Times
Dude. Seriously.
