Ear protection when pumping tires
#126
Klaatu..Verata..Necktie?
Quoted: 10424 Post(s)
Liked 11,896 Times
Has no one else ever wondered if Larry is a performance artist? His posts are just on the edge of troll, yet good enough to attract not only the Usual Suspects but the most credible members. I always think that Larry is just shy of absurd, but the best people here still give him the benefit of the doubt (for which I admire them). But there comes a point where I am asking myself, (as we say up near Boston) are you shifting me?
Likes For genejockey:
#127
Quoted: 2333 Post(s)
Liked 2,097 Times
I rode a 23mm front tire on PBP in 2019. PBP is 1218 km over several days and nights.. No problems and no kittens died. I'm fine generally with 25 mm tires. Yes, I have ridden wide, supple for tens of thousands of miles. Conti GP5000 25 mm work best for me.
I'm 220 and bike with gear was 45lbs although was maybe 205 then.
We do not know if TdF riders are on 23, 25, or 28 mm tubies at any given stage. I guarantee they have a narrow tire up front on a TT
#130
Quoted: 1856 Post(s)
Liked 664 Times
When you tend to pull the tire away from the bead the bead might just give a bit and make a small gap. The big-time tire pressure can force the tube to stretch out through that litlle gap and blow through that hole like a balloon. Moments later it bursts like a balloon with a sound like a rifle shot next to your ear.
The sidewall of your tire should have the maximum tire pressure molded into the side. One should never fill the tires up higher than that, and actually it's most likely supposed to be an absolute maximum that is never supposed to be exceeded. This is something your new boss at the bike shop will tell you, accompanied by a dope slap (if you watch NCIS). This problem is especially likely if you are too hasty when you install a tire and not careful about getting all those bits you cannot see to settle into the correct spot.
Bottom line, for this weight you are wrong to use that skinny tire on a skinny rim with that much weight. No offense intended, just some straight talk.
A wider tire and rim will not distort so badly, and can handle the load with much less added pressure.
I know these things because I'm an engineer. We know everything, or at least a lot about simple mechanics and machines.
No, I had it wrong; we know everything. (LOL!)
Likes For Road Fan:
#131
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
I pinchflatted 25s because they were underinflated for the type of riding I was doing (hauling groceries.) I needed 130+ in them, and frankly in terms of historical tire pressures this isn't even abnormally high. Back in the day much lighter people went to higher pressures. Thin tires for heavy riders are perfectly fine as long as they are inflated properly
Likes For cxwrench:
#132
ignominious poltroon
Quoted: 2239 Post(s)
Liked 3,434 Times
My daughter, who weighs considerably less than that, just got a Trek Domane that comes with 32mm tires. (The shop did do its part, however, by pumping them up to a stupidly high pressure.)
Likes For Polaris OBark:
#133
Quoted: 2700 Post(s)
Liked 486 Times
Just a little science if I may. The ability of the tire to support weight is based on the area of the tire contact patch and the air pressure. If you are going to support ⅔ of the 300# on the rear tire, it has to have 2 square inches on the ground when squished by the 200#. Your 23mm tire is less than 1" wide, so no matter how high you can pump that tire is badly distorted. For the sidewalls to splay out from under the rim, which tends to pull the bead area away from where it is seated, under normal conditions (more like 100 # for the tire).
#134
Quoted: 1397 Post(s)
Liked 1,876 Times
no votes for 18's ?
18's pumped to ... 160 psi ?
#135
Liked 486 Times
shouldn't matter if its properly inflated, evidently there wasn't enough pressure because I managed to get a pinch flat. Thats like saying "you shouldn't have hopped the curb if you didn't want a pinch flat" like youre kind of right but its ignoring the root cause,
#136
Bikes: 2021 S-Works Turbo Creo SL, 2020 Specialized Roubaix Expert
Quoted: 762 Post(s)
Liked 4,034 Times
Yes ear protection whilst pumping your tires up to 140 psi is essential. Some wear Bluetooth ear buds while listening to music to accomplish this. I’d like to point out just how truly dangerous this is as you won’t be aware of who might be driving up behind you. And you won’t be able to jump out of the garage in time to save yourself!
Yes, this is a parody thread. It has not disappointed!
#137
Quoted: 3510 Post(s)
Liked 2,925 Times
Likes For alcjphil:
#139
Quoted: 762 Post(s)
Liked 4,034 Times
If youre an engineer you should know that you can pump tires higher than the recommended pressure range, its not going to fail because you put an extra 20 psi in it. Heck you could probably run almost double. Whats gonna happen, the rim fails? 23s are perfectly safe, ive never had a shop tell me im too heavy to ride 23s.
I’ve had a tire blow off the rim at the recommended maximum inflation of 90 PSI. I don’t know why but blow off it did. It even appeared to be properly seated.
Likes For MattTheHat:
#140
Quoted: 762 Post(s)
Liked 4,034 Times
#141
Quoted: 3949 Post(s)
Liked 7,295 Times
Likes For tomato coupe:
#142
Liked 2,925 Times
Likes For smd4:
#143
Liked 3,434 Times
#144
Quoted: 1561 Post(s)
Liked 1,734 Times
https://wheelbuilder.com/content/EastonRimPressure.pdf
Note that for 23mm tire, the maximum pressure is 120psi. Clincher rims/tires are not designed to be run at 140psi. You need to run tubular tires if you insist on running at that pressure.
Likes For icemilkcoffee:
#145
Quoted: 6963 Post(s)
Liked 10,962 Times
How did I miss this thread?
LarrySellerz , a while back many of us told you that running a psi that is 50% over the recommended max is foolish. It's the reason why you're blowing tires.
You don't need ear protection; you just need some common sense.
Likes For Koyote:
#146
Liked 664 Times
You might think this is all crap but if that blowout had happened while you are on a mountain road in a fast, tight curve at 30 mph, your ride could have a really bad ending.
As far as the rim failing, I don't know if it will or worn't with that much stress pushing the sides out. But I would suggest not taking the chance. I've just been reading a wheel builder talking about how he cannot guarantee handmade wheels made of rims he can'r be sure of or did not supply, because he's seen cracks running from spoke hole to spoke hole in some used rims which customers have wanted him to re-use. This actually does sound like rims which could separate.
Likes For Road Fan:
#147
Liked 2,925 Times
You guys would need a change of underwear when my steam locomotive goes over it’s MAWP of 190.
#148
Liked 11,896 Times
#149
Liked 11,896 Times
Is the boiler made of lightweight aluminum less than 2mm thick?
#150
Liked 2,925 Times
