Can I change wheel sizes?
Old 07-11-21, 05:04 PM
exercion
Bikes: Cannondales: Synapse 5 Carbon and F5
Quoted: 42 Post(s)
Liked 91 Times in 34 Posts
I have a Cannondale F5 mountain bike with 26" wheels and disc brakes. I have been searching unsuccessfully for a spare wheelset so I can have slicks on one and knobbies on the other. 27.5" rims are everywhere it seems, so I was wondering if it's feasible to get slicks for that size, and mount them? I don't have a set handy to try, and don't want to buy some just to see, so I figured I'd ask here.
Eric
exercion is offline
Old 07-11-21, 05:12 PM
HillRider
Quoted: 2026 Post(s)
Liked 1,096 Times in 742 Posts
It's unlikely a 27.5" wheel and tire will fit in a frame designed for 26" wheels as there probably isn't enough frame and fork clearance. Many bikes built for 700c (aka 29") wheels will take 27.5" wheels and vice-versa but not those for 26" wheels.
HillRider is offline
Old 07-11-21, 05:28 PM
exercion
Quoted: 42 Post(s)
I should have added, and will edit, the F5 is a MTB frame, not a road bike, so it's not a 700c.
Eric
exercion is offline
Old 07-11-21, 06:55 PM
hokiefyd
hokiefyd's Avatar
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times in 570 Posts
A 26x2" tire is nominally about 660mm in diameter. A 42mm tire designed for a 27.5" wheel (584mm) is about 668mm in diameter. If your frame has plenty of clearance for a nominal 26x2" tire, then I think you'd be able to fit a 42-584 tire.
hokiefyd is offline
Likes For hokiefyd:
Old 07-11-21, 06:56 PM
Dan Burkhart
Senior member
Dan Burkhart's Avatar
Quoted: 943 Post(s)
Liked 658 Times in 371 Posts
Actually, it's not unlikely at all.650B conversions on 26" wheel mountain bikes are often doable as long as disc brakes are involved. I have done one such conversion myself in the last six months.
A few quick measurements, or a test wheel set fitting will soon tell the tale.
In fact, I have done one 26" to 29er conversion. It put the crank higher than I would have liked, but it's what the customer wanted, and the bike had the clearance. Not many have that much though.
Dan Burkhart is online now
Old 07-11-21, 07:15 PM
CliffordK
CliffordK's Avatar
Quoted: 18373 Post(s)
Liked 4,508 Times in 3,351 Posts
26" rims and wheels should be everywhere, but not necessarily high quality with discs.
For 650b, a lot will depend on tire width.
I did a 26" to 700c conversion a while ago. Going from standard 26" to narrow 700c. It worked reasonably well, although the frame dimensions were a bit off.
CliffordK is offline
Likes For CliffordK:
Old 07-11-21, 09:03 PM
HillRider
I know that but many current MTBs are designed to use 700c wheels referred to as 29".
Old 07-12-21, 12:57 AM
dabac
Quoted: 1074 Post(s)
Liked 295 Times in 222 Posts
Eric
1) where have you been looking?
Many who started riding during the 26” era still have some wheels left. If you’d been local I could have given you a pair.
2) how wide do you want those slicks?
27.5” is also known as 650B, these have the same Bead Seat Diameter, where rim and tire overlap. If you’re OK with a narrower tire, there should be a decent selection of slicks for that size, which would leave the OD about the same.
dabac is offline
Old 07-12-21, 01:35 AM
hydrocarbon
hydrocarbon's Avatar
Quoted: 30 Post(s)
Liked 23 Times in 18 Posts
Dude, it'll work 100% fine and roll better than 26" wheels if we're talking mid-width slicks. People have been using road and cyclocross tires on 700C wheels with 26" disc frames for ages; there's tons of clearance for a 27.5".
Here's an example of a direct swap from 26" MTB to 700C road wheel/tire:
https://www.mtbr.com/threads/is-a-ri...3/post-9683247
hydrocarbon is offline
Old 07-12-21, 03:57 AM
exercion
Quoted: 42 Post(s)
Wow, thanks! I had not even considered 700c, I'm definitely looking for mid-width or narrower slicks since they'll be for rail trail and casual street riding around town, leaving the knobbies for when I need more aggressive tires.
Eric
exercion is offline
Likes For exercion:
Old 07-12-21, 03:59 AM
exercion
Quoted: 42 Post(s)
Not looking for wide, and yes 26" wheels can be found, or cheap enough donor bikes but none I can find with disc brakes.
exercion is offline
Old 07-12-21, 04:13 AM
dsaul
Quoted: 714 Post(s)
Liked 800 Times in 475 Posts
They aren't that hard to find. Here is a whole page of them https://www.universalcycles.com/shop...?category=5479 If you were near me, I'd give you a pair, since I have several pairs that I'm no longer using.
dsaul is offline
Old 07-12-21, 05:20 AM
alcjphil
alcjphil's Avatar
Quoted: 1819 Post(s)
Liked 1,693 Times in 974 Posts
One area that could be a problem is if your current wheels use quick releases rather than thru axles. Some thru axle wheels can be converted to quick release but many others can not so that is another consideration
alcjphil is offline
Old 07-12-21, 06:38 AM
commo_soulja
commo_soulja's Avatar
Bikes: are fun to ride
Quoted: 33 Post(s)
Liked 35 Times in 23 Posts
I've converted old 26" mountain bikes with 700c and 650b wheelsets. 700x23 roadie tires fit fine and so do 650bx47 tires with knobbier tires. Do it.
commo_soulja is offline
Likes For commo_soulja:
Old 07-12-21, 08:29 AM
ClydeClydeson
Quoted: 581 Post(s)
Liked 921 Times in 518 Posts
There are still many 26" rims of good quality available, many good quality hubs available, and good quality spokes available. I know it is not the most common way to get good wheels, but building or having your own built is still an option.
ClydeClydeson is offline
