Shimano's "new" idea
Port
Quoted: 983 Post(s)
Liked 1,854 Times
Likes For Rocket-Sauce:
Likes For jethin:
Cantilever believer
Quoted: 529 Post(s)
Liked 1,823 Times
Been there, rode that. With a 38-tooth Perfect freewheel.
Likes For RCMoeur:
*____*
Bikes: Turner 5-Spot Burner converted; IBIS Ripley, Specialized Crave, Tommasini Sintesi, Cinelli Superstar, Tommasini X-Fire Gravel
Quoted: 406 Post(s)
Liked 389 Times
This is for mountain bikes. It will help.
Cantilever believer
Quoted: 529 Post(s)
Liked 1,823 Times
The triple-pulley Suntour derailleur, or the big ol' freewheel?
(starts rummaging through parts bins)
Quoted: 3807 Post(s)
Liked 6,676 Times
Triple pulley with a clutch for 1x? Hmm.
Likes For nlerner:
Likes For embankmentlb:
*____*
Bikes: Davidson ’81
Quoted: 120 Post(s)
Liked 229 Times
When I first saw that Shimano drawing I didn’t notice the 3rd pulley and I thought they were just moving the pulley cage back to where it was meant to be.
Likes For C9H13N:
Quoted: 964 Post(s)
Liked 1,451 Times
This thing looks like the love child of a MounTech and a three-pulley LePree.
Likes For scarlson:
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,390 Times
Quoted: 406 Post(s)
Liked 389 Times
Likes For vespasianus:
Quoted: 3464 Post(s)
Liked 2,828 Times
I seriously considered a Schwinn with a Suntour S-1 rear mech, the return of the Nivex before Jan Heine.
Bikes: a couple
Quoted: 563 Post(s)
Liked 862 Times
Oh crap, don't give partszilla the idea to come back out with whatever that forward ratchet system they used in the 70's "shift while you're not pedaling system"
Likes For Schweinhund:
Liked 4,390 Times
I'm not against derailers, but for the amount of overengineering that the technology has had thrown at them, you'd think we'd see a bit of IGH innovation too. I'd love to have a selection that's not limited to slip-prone Nexus 8s, infamously trouble-prone Alfine 11s, and Rohloffs that are unaffordable and require one too many cables.
-Kurt
Likes For cudak888:
In all the years of mountain biking I did, not a single time did I hit something with the rear derailleur. Just don't see the idea of ground clearance as a valid design idea here. Sprocket size, no question about it. This design is a nice nod to Sun Tour as it validates their original idea by copying it, and no doubt making it better.
As for IGH, they are kinda like bents, those who have them snub those that don't. Too bad, as they really are ingenious, just not for me as the weight penalty is more than I am willing to accept.
Likes For TiHabanero:
Liked 4,390 Times
-Kurt
Quoted: 964 Post(s)
Liked 1,451 Times
Yeah, weight has always been my concern with IGHs too. Some of them feel like a cannonball when you are lacing up the wheel and hefting the thing around.
It would probably require a lot of engineering to make a lightened IGH. Gear teeth would still be steel, but the centers of the gears could be aluminum. Mating the metals would be a lot of work. Or else doing extensive machining on the steel gears before hardening, to remove all unnecessary metal - instead of solid wheels, the gears could be in the form of spoked wheels. Still a ton of work! And diminishing returns as the gears get smaller.
Likes For scarlson:
Master Parts Rearranger
Quoted: 1556 Post(s)
Liked 2,024 Times
We just need someone to figure out a single speed CVT setup and we'd be good to go. Super simple. Totally.
Otherwise, IGH should become IGBB. Light wheels are kept or improved, gear weight is centralized, and there really isn't a size limit to the transmission in that area, which would allow one to build it pretty beefy. I know Pinion has a 2-speed setup there and many E-bike companies run "mid drive" motors in the area, so it's not new ground or new thought, just "bumping" the thread of ideas.
Quoted: 964 Post(s)
Liked 1,451 Times
Schlumpf's "mountain drive" is a two speed that fits in a normal BB.
Liked 2,024 Times
Two speed? Pinion's got 18 speed in there! Doesn't retrofit to anything, though. You need a custom frame with a big housing, and it's bulky. The way it works reminds me of a cross between Citroen 2CV gearboxes (concentric shafts) and Eaton Fuller truck gearboxes (ranges and split gears).
Likes For P!N20:
Liked 4,390 Times
Ball ring is next to impossible to modify as-is, but I can see a design with a smaller diameter pawl ring in steel on an aluminum carrier with a press-fit bearing raceway.
-Kurt
