Going tubeless with a new oddball sealant.
Quoted: 680 Post(s)
Liked 948 Times
One thing that has stopped me going tubeless is I did not want to deal with charging out the sealant. I know I would lose track nd end up with a dry wheel.
People wit their fat tire e bikes have been using flatout on the lower psi tires and it works well. I tired it in my tubed tires at 70psi and its ever really worked. Now on my 50 pis fatter tires it has plugged several leak and after about 3000 miles the tubes stopped leaking air.
Flat out came out with a thinner formula for smaller bike tires and I bought some. But before I could use it I decanted to try tubeless on out tandem. The marathon tires were such a harsh ride my wife needed something better. So I bought tubeless ready tires and tape and valves and I figured I would try the new flatout in them. Mainly because it doesn't to dry out. It can last in a regular tire for 10 years. But hey I would take a couple of year or less when I wear the tire out.
So I did the back first I only wanted to try one tire at a time. I used a Stans valve and aI really tightened it down clean everything with alcohol. The wheel leaked after I set the bead then I added about 6 oz of the flatout and swirled it around and all the leaked around the bead sealed up. After a couple of rides the tire did not lose any air. It's been about 3 weeks now and I hav not had to pump u the tire. So I bought another tire and did the front using a mucoff valve and it lost air several times till I tighten the valve enough and now it does not lose air either.
So several hundred miles and so far no issues. It's supposed to plug unto 1/4" holes but I bet that depends a lot o the PSI. I was at 70 but went down to 65. I am changing over my commuter to tubeless this week using it too.
If anyone want to try some especially at higher PSI I would be willing to send some to you as I have a gallon
https://shop.flatouttire.com/collect...mall-tire-32oz
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1943 Post(s)
Liked 1,465 Times
Is this Flat Out also added via a tubeless valve? How about the aerosol can version in the link in your OP?
Quoted: 680 Post(s)
Liked 948 Times
one of my complaints about it is the tube is made for a schrader valve and does not fit tight on the presta and can make a little bit of a mess. its worse with a tube then tubeless. the first one I used the valve and wrapped it with some masking tape to make a tight fit. but the second time before I got the last of the tire on I just stuck the hose into the gap and put it in that way much easier. I do not think they have aerosol like fix a flat. the thinner version that I used is new and I had to order it directly from them. So bought a gallon as 1/2 gallon would be the same cost and Igot free shipping the gallon comes with a pump.
Liked 1,465 Times
The recommendation is 8 ounces per tire?
Products By FlatOut | Tire Sealant & Additives | Shop Now (flatouttire.com)
That seems to be a lot.
I like tubeless on my mountain bike but I didn't really want to go the hassle of changing over on my road bike, so I've been trying out Muc-Off inner tube sealant. I wondered if I would know if it had worked, but the answer is definitely yes. I came to use my bike last week and the front tyre was flat. So I thought I'd pump it up to the usual 80 psi and go out for a ride. When I came back it was still hard but the next day it was down to 20. Not really having time to fix it I just pumped it up again, and the next day it was down to 40. Interesting, I though, and pumped it up again, and since then it's been holding pressure just fine. It's supposed to last the life of the inner tube since it doesn't cure in air. Fortunately I have Schwalbe and Impac inner tubes with removable valve cores, so I've just injected it with the Stan's injector. You have to put rather more in than you would with Stan's - about 3oz. I'm reasonably impressed.
Quoted: 381 Post(s)
Liked 145 Times
Quoted: 680 Post(s)
Liked 948 Times
Quoted: 680 Post(s)
Liked 948 Times
I like tubeless on my mountain bike but I didn't really want to go the hassle of changing over on my road bike, so I've been trying out Muc-Off inner tube sealant. I wondered if I would know if it had worked, but the answer is definitely yes. I came to use my bike last week and the front tyre was flat. So I thought I'd pump it up to the usual 80 psi and go out for a ride. When I came back it was still hard but the next day it was down to 20. Not really having time to fix it I just pumped it up again, and the next day it was down to 40. Interesting, I thought, and pumped it up again, and since then it's been holding pressure just fine. It's supposed to last the life of the inner tube since it doesn't cure in air. Fortunately I have Schwalbe and Impac inner tubes with removable valve cores, so I've just injected it with the Stan's injector. You have to put rather more in than you would with Stan's - about 3oz. I'm reasonably impressed.
Quoted: 492 Post(s)
Liked 431 Times
Surely everyone using Presta valves has a Schrader adaptor in their seat pack (or you can just leave it screwed to the valve) so they can use gas station air lines?
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
It's like riding a bicycle
Quoted: 680 Post(s)
Liked 948 Times
it has fibers in it. fibers that can plug up valve stems too. the regular stuff can do upto 1/2" holes it has some long fibers in it its super thick. I tried it in a tube at 70 psi and it would not seal. it worked at 50 pis in other tires. it also sealed the tube so it does not need air but it took over 3000 miles to manage that.
Dunno how much this stuff weighs, so let's assume it's the same density as water.
Water weighs 3.78kg per gallon (8.34 lb). 8 fluid ounces is 1/16 of a gallon.
When you add that much of the stuff, you're adding over 236 grams (or over 1/2 pound) per tire. And it's all rotating mass in the worst possible place - e.g., very nearly the outer part of the tire.
I'm not overly concerned about weight. But even to me, that seems like quite a lot.
I think I'll stick with my 125g or so butyl rubber inner tubes and use puncture-resistant tires, thanks.
Likes For Hondo6:
Quoted: 980 Post(s)
Liked 582 Times
I sort of figured that, but my inner pedant went crazy. Fortunately for me, I'm firmly in the "tube" camp, so it's academic.
Quoted: 2338 Post(s)
Liked 2,822 Times
and of course i can't resist: Don't call me surely
now get of my l lawn
Quoted: 492 Post(s)
Liked 431 Times
Well yes, I carry pump and CO2 and spare tubes and patches. And a Presta Schrader adaptor.
Really? Blown up, not simply blown off through overenthusiastic inflation when they weren't properly seated?
"Don't call me Shirley" surely?
Likes For grumpus:
Quoted: 506 Post(s)
Liked 638 Times
Well no. I just use my pump, as I have done for decades. Gas station air lines are often not working, don't go to the desired pressure, cost money, and I have to wonder why you find out that you need air when you're at the gas station and not when you are ready to ride or have a flat when riding. I can't imagine being dependent on gas stations to keep my bike tires at the proper pressure.
Quoted: 492 Post(s)
Liked 431 Times
Quoted: 8 Post(s)
So the "new" stuff is the small tire Quickstrike product? Wish Amazon carried it, but looks like they only have the original products. I'm willing to give it a go but fairly pricey shipped only from Flatout as near as I can find it.
I ride road tubeless for about 6-7 years now. I started with Orange Seal and it turned to goo in just a few months. Too much maintenance effort. I then tried Slime Pro (no longer made) 1.5oz and it lasted two years for the life of my tires with maybe a 1oz topoff once... 3500 miles (Hutchinson Intensive 2 tires...lasted forever but a firm tire). Still had plenty of liquid in there to soak up, maybe not much fiber or bonding agents to actually seal a hole, but I never had anything it didn't seal. I then ran GP5000 tubeless tires with it, no problem there either. Might go try some of the Slime blue-label, which seems like the current closest product to what the Slime Pro was.
More recently, new bike and wheels, running 25mm internal wide hookless carbon wheels with 28mm Schwalbe Pro One TLE, using Oko Magic Milk high fibre. Really haven't been impressed with it. Dries out quickly, never seems like I've ever gotten the tires to seal with it. Not sure whether to blame tire+rim combo, but too often I think I'm losing 10-20psi just on a 3 hour bike ride (from ~65psi starting point). Blame the tires? Blame the hookless format? Or blame the sealant? I'm ready to blame the sealant first until I wear out these tires and go back to GP5000S TR that I already have sitting here for when the Schwalbe tires wear out.
Quoted: 680 Post(s)
Liked 948 Times
ya I had to order it from them. so far n flats at all. the first wheel I did I had to take the tire off as a spoke cracked and it has only lost air a bit a couple of times in the last couple of months. but there was some in the tire but not as much as I expected. the inside of the tire was wet but no puddle really or not much of one.
Quoted: 680 Post(s)
Liked 948 Times
got my first puncture on the way hole and the flat out sealed it well did not even lose enough air to need to add more. thats so much better then I got with tubes and various sealants.
