Rebuilding a Silca Pista Floor Pump - Worth it?
Old 08-14-15, 09:03 PM
dwmckee
dwmckee's Avatar
Quoted: 415 Post(s)
Liked 325 Times in 219 Posts
My 1990 Silca Pista floor pump has finally become unusable. Gauge is erratic, barrel seal and one way valve are unreliable now too. Is it worth the $45 in parts to rebuild it? I did not pay anything like that for it when it was new. All I have done for it in the past 25 years has been to replace the fill valve gasket a few times and lube the barrel so it has been a good pump, but it is getting a bit dated looking compared to the sexy new ones.
Silca has some really nice pictures of the new parts on their site. Makes you want to just buy the parts just because they look so nice!
dwmckee is offline
Old 08-14-15, 09:23 PM
HillRider
Quoted: 1955 Post(s)
Liked 951 Times in 663 Posts
Silca is now under new ownership and their pumps have gone WAY upscale. How about a basic floor pump is now $450 and special "Artist Editions" go for up to $1200? (Actually, went for, they are already sold out.) Repair parts for the older pumps also seem to have gone up as for example the rubber washer for the bell-shaped Presta pump head that used to be $3 is now $9.
If you can still source all of the needed parts for $45, I'd say go for it. Your old pump may be come a valuable collector's item in the future.
HillRider is offline
Likes For HillRider:
Old 08-15-15, 08:40 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Liked 1,343 Times in 850 Posts
My Old 80's one still works .. I wonder what happened to the people and their families back in Italy , now that the gentrification Takeover,
moved the company .
might be some parts in old sellers inventories to use your searching web talents.
fietsbob is offline
Old 08-15-15, 08:52 AM
cale
cale's Avatar
Bikes: Kuota Ksano. Litespeed T5 gravel - brilliant!
Liked 3 Times in 3 Posts
I was recently using my 80's Silca to make a point to my non-cycling friend. I was mentioning that they don't make stuff like they used to and for a very good reason. Silca pumps were so overbuilt that with only modest service they can last 30 years and still work. But company's that make products that last that long better be able to follow up with something else to sell when initial interest runs out because otherwise they wont be seeing those "first buyers" again for a very long time. The Silca Pista was both an engineering triumph and marketing disaster.
Repair your pump. It's a piece of cycling history.
cale is offline
Likes For cale:
Old 08-15-15, 11:46 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 3729 Post(s)
Liked 2,788 Times in 1,730 Posts
The biggest aspect of floor pumps that I see feed back on is the chuck style. So if you're happy with the Silca chuck or are willing to splice in a different kind then rebuilding the piston seal is well worth it. But I don't see much value in replacing a pressure gage. It's not hard to determine a correction factor and remark the dial. Andy.
Andrew R Stewart is offline
Likes For Andrew R Stewart:
Old 08-16-15, 08:09 AM
HillRider
Is the gauge really bad or just reading erratically because the check valve, etc. are leaking? Unless mechanically damaged, gauges are pretty bullet-proof.
Old 08-16-15, 08:23 AM
Bandera
Quoted: 1112 Post(s)
Liked 175 Times in 115 Posts
Apply Captain Fast logic: "The latest and most expensive hardware is always more desirable than last seasons' obsolescent stuff."
You are long overdue for a more "sexy" pump.
-Bandera
Bandera is offline
Old 08-16-15, 04:26 PM
davidad
Quoted: 558 Post(s)
Liked 159 Times in 128 Posts
You can clean up the check valve and replace the o-ring. A new leather gasket will make it as good as new. Mines about 21 years old and still works.
davidad is offline
Old 08-16-15, 06:15 PM
FRANK CANNON
Liked 2 Times in 1 Post
The sexiest air pumps come from Italy.
FRANK CANNON is offline
Likes For FRANK CANNON:
Old 08-16-15, 06:49 PM
Andrew R Stewart
Debatable, but what isn't is that this form of air pump chemically changes the out put. Our bike pumps don't. Andy.
Old 08-16-15, 08:20 PM
HillRider
So do many of the least reliable.
Old 08-17-15, 09:06 PM
tjkoko
Bikes: Rockhopper, Azor Oma cruiser
Attached is an owner's manual for the Silca Pump. I found the manual online about a year ago.
File Type: pdf
tjkoko is offline
Likes For tjkoko:
Old 08-18-15, 09:02 AM
pdlamb
Quoted: 2163 Post(s)
Liked 1,387 Times in 883 Posts
I'd start by trying to clean the check valve. It's pretty easy to disassemble, and it seems to collect dried oil and turn it into gunk. Soak everything in mineral spirits, put some clean oil on, and reassemble. If the pump works then, go ahead and rebuild the rest of it.
pdlamb is offline
Old 08-18-15, 10:38 AM
Grand Bois
Grand Bois's Avatar
Quoted: 442 Post(s)
Liked 16 Times in 16 Posts
When I replaced some parts for my Medai Top Super Japanese pump from the seventies I learned that the threadings for pump parts are pretty much standardized. You may be able to find parts for less money than Silca sells them for. I was able to find a hose with a chuck that I prefer to the original.
Medai Top Super Pump - Bicycle Parts at discount prices / the Buyer's Guide / Bicycle Parts at their finest! / Professional Bicycle Source / Bike Pro
Grand Bois is offline
Old 08-18-15, 10:42 AM
rmfnla
rmfnla's Avatar
Bikes: Gilmour road, Curtlo road; both steel (of course)
Quoted: 273 Post(s)
Liked 10 Times in 9 Posts
I agree with this, but I tend to try to rebuild everything before replacing.
If this works all you would probably need to replace would be the seals...
Today, I believe my jurisdiction ends here...
rmfnla is offline
Likes For rmfnla:
Old 08-18-15, 03:34 PM
tcs
Palmer
tcs's Avatar
Bikes: Mike Melton custom, 1982 Stumpjumper, Alex Moulton AM, 2010 Dawes Briercliffe, 2017 Dahon Curl i8, 2021 Motobecane Turino 1x12
Quoted: 1223 Post(s)
Liked 1,013 Times in 617 Posts
I bought a presta head from the new Silca. Here's what their marketing sez:
'We felt the need to re-imagine this most iconic of cycling tools as an heirloom quality objet d'art. The utmost care has been taken to machine the part using mono-crystaline diamond tooling to get the perfect surface finish, while the final feel of the part benefits from an investigation into more than 20 different styles and depths of knurl so that it will feel 'just-so' in your hands as it provides a lifetime of useful enjoyment.'
Yeah, okay, whatever, YMMV, but the one they sent me hadn't been deburred after machining. Works just fine, but feels sorta nasty cheap made-in-China-in-1987-ish in the fingertips. Every time I touch it I think, 'Paid too much.'
...getting a bit dated looking compared to the sexy new ones.
Ah, those polished stainless and wood Arundel, Birzman, Lezyne, Silca, Velowurks, etc. pumps, re-fitted with Hirame heads: lovely! - but of course the cool kids are inflating with tanks of nitrogen now.
tcs is offline
Old 08-18-15, 08:45 PM
tjkoko
I'd start by trying to clean the check valve. ... Soak everything in mineral spirits, put some clean oil on, and reassemble. If the pump works then, go ahead and rebuild the rest of it.
Which "clean oil" would you recommend using at the check valve??
tjkoko is offline
Old 08-18-15, 09:22 PM
dwmckee
dwmckee's Avatar
Quoted: 415 Post(s)
It varies more than 30 PSI different from stroke to stroke. Not usable at all.
dwmckee is offline
Old 08-18-15, 09:25 PM
dwmckee
dwmckee's Avatar
Quoted: 415 Post(s)
Can a bad check valve cause the crazy pressure readings I see? I wish I saw that before I ordered the parts...
dwmckee is offline
Old 08-18-15, 09:27 PM
dwmckee
dwmckee's Avatar
Quoted: 415 Post(s)
Thanks, this will be helpful
dwmckee is offline
Old 08-18-15, 10:04 PM
Andrew R Stewart
Pressure gages usually are pretty consistent WRT them selves stroke to stroke. But the other aspects of the air delivery system can and do have variations. Like sticking valves, both check and tube. Or the chuck's sealing on the valve stem can vary with the hose movement and pressure. It's common to see a pressure readout that is high while pumping in air, then briefly stabilizes before bleeding down on the up stroke. A sticking or rusty check valve only further confuses this cycle. Andy.
Old 08-19-15, 08:19 AM
pdlamb
I'd probably use Phil's Tenacious Oil, because that's what's in my garage. 10W40 motor oil would also be good. I'd skip bar chain oil, because I don't want something that sticky in the check valve, and many of the light use chain oils because I don't want the residual paraffin in there either.
pdlamb is offline
Old 08-19-15, 08:47 AM
tjkoko
I'd probably use Phil's Tenacious Oil, because that's what's in my garage. 10W40 motor oil would also be good......
10W40 synthetic or nonsynthetic********** What about 3 in 1 Oil which is considered a light machine oil********** Mineral oil????
Last but not least, what about using Park Tool CL-1 lubricant?
tjkoko is offline
Old 08-19-15, 08:54 AM
pdlamb
Yes
No, it'll harden with age
Mineral oil????
For you or the pump**********
pdlamb is offline
Old 08-19-15, 09:10 AM
tjkoko
10W40 synthetic, yes or no**********
10W40 conventional motor oil, nonsynthetic, yes or no????
Mineral oil which is baby oil without fragrance, yes or no???
Park Tool CL-1 lubricant, yes or no???
And let's omit the facetiousness, okay.
tjkoko is offline
