Different size tires front and rear
Old 08-26-15, 07:36 PM
CFster
Bikes: 2014 Giant Escape 1, 2005 Specialized Allez Triple
Just bought a 2005 Specialized Allez Triple.
I notice that instead of the spec 700x23c tires, it's fitted with a 28 front and 25 rear. They're Michelin Dynamics.
Is it common to put a bigger tire on the front? The 28s take a little effort to push past the brakes when putting the wheel on.
If I wanted to replace these (because they're worn too), what would be a good tire to go with for the following conditions:
1. I'm a Clyde, so need something to hold the weight.
2. Riding mostly on smooth bike paths, or smooth road.
3. Don't see myself riding in the rain much - probably only if I get caught out...
4. I like a nice ride, but would forego it for more durability as I'm riding on smooth surfaces anyway.
Thanks
CFster is offline
Old 08-26-15, 07:39 PM
bt
I'd put the bigger on back if I had to choose
bt is offline
Old 08-26-15, 07:42 PM
Shimagnolo
Shimagnolo's Avatar
Quoted: 3023 Post(s)
Liked 4,419 Times in 2,246 Posts
A bike typically has more weight on the rear, so that is where a larger tire should be.
In fact I am currently running one bike with a 25mm front and 28mm rear just because I am using up the stock I have on hand before buying more tires.
Shimagnolo is online now
Old 08-27-15, 11:20 AM
ColaJacket
ColaJacket's Avatar
Bikes: Fuji Sportif 1.3 C - 2014
Quoted: 5 Post(s)
Right, but on the rear, the chain stays and seat stays may not have the ability for the wider tide. But, if the wider tire will fit on the back, then that is the way to go.
GH
ColaJacket is offline
Old 08-27-15, 01:12 PM
rmfnla
rmfnla's Avatar
Bikes: Gilmour road, Curtlo road; both steel (of course)
Quoted: 273 Post(s)
Liked 10 Times in 9 Posts
For off-road the bigger tire goes on the front so the increased tread area can provide more "bite" in a corner.
For the road the bigger tire goes on the rear to deal with the increased weight on that wheel...
Today, I believe my jurisdiction ends here...
rmfnla is offline
Likes For rmfnla:
ironwood
General Cycling Discussion
24
07-20-13 05:13 PM
Wilk
Mountain Biking
16
09-18-12 08:54 PM
MudvilleStomper
Singlespeed & Fixed Gear
5
05-12-12 10:45 PM
EdIsMe
Road Cycling
3
07-07-11 09:11 AM
zigmin
8
08-27-10 01:14 PM
