Drilling hole through cycling shoe ?
Bikes: CAAD 10 2105
First of all I wanted to say is that I have very wide feet and finding shoes for me can be a very very fought challenge, 99.90% of the shoes out in the market don't fit my feet very well except for "Crocks", since my right foot is bigger than my left and my smallest 5th right toe always point's outright wards causing it to have discomforts and swell.
My first pair of shoes were really basic Shimano XC30 and I had to wear a size 43 which is 1 - 2 sizes big than what I normally wear just to accommodate the right foot. After a while I got really annoyed of the low quality shoe and decided to purchase a pair of Northwave Extreme Tech MTB shoe for $270 since it fit me the best. How ever I can't move the cleat further back as it's so close to the front as I'm trying to get the ball of my foot to align with the axle.
While comparing my old shoe and my new shoe the cleat position is approx 5mm to 10mm in difference, this got me thinking is it appropriate to drill some holes in the carbon sole shoe ?
The shoe fits me but the cleat position doesn't thus making it unusable.
I did not think of this as I got to carried away at the bike shop, but at the same time I can't return it back.
Any ideas guys ?
Any ideas guys ?
Super Moderator
Do you want to extend the slot or drill 2 new holes at the final position ?
It would be helpful to see under the cleat.
Perhaps 2 holes can be drilled, the sole liner removed, and new nuts inserted from inside the shoe ? You won't get any adjustability though.
Bikes: CAAD 10 2105
Drilling new holes would kind of be a pain.
Heres the shoe with out the cleat.
Where the black line is, that's where my cleats should be sitting at.
It will look similar to this
Super Moderator
Extending the slot doesn't seem too difficult ... worth a try. At some point the interior of the slot will stop, so no matter how far you extend it, the cleat nuts will not be able to slide further, but maybe there's enough space for what you need.
Maybe drill a hole at the line, possibly a second hole in between, then use a sharp blade like a box cutter to cut away the plastic between the new holes & existing slot.
I have completely different Northwave winter shoes, and notice their cleat adjustment doesn't allow me to move the cleats much more towards the arch.
Quoted: 14 Post(s)
Liked 11 Times
There is a recess on the inside of the sole for the nut plate so that it sits level with the sole inside the shoe. It may not allow the plate to be slid rearward beyond what's already available with the existing slots. You may need to extend that recess with a dremel, perhaps use t-nuts instead of the plate, or something.
Quoted: 690 Post(s)
Liked 702 Times
No guarantees it won't effect the strength of the sole but I would do it if I was in your situation as I think it's probably safe and the shoes aren't worth much to you since you can't get the cleat position right as they are. I would just extend the slot but would want to be very precise about getting the same width of the groove and making it perfectly straight. I'm worried that if the groove is even slightly too wide any bolt anchor could eventually pull through the sole. All just speculation of course but experience is my guide.
Expired Member
Quoted: 3031 Post(s)
Liked 3,998 Times
A wood working, steel T nut can be re threaded 5x.8 metric to use the bolts that come with the cleat.
Its a round hole .
use some more Carbon Fiber to fill the old one in..
probably add some on the inside to make up for removing the original shimano nut plate..
what you add will stick up because the new place wont have the recess ..
hope your new Insole hides its feel.. .
Its a round hole .
Quoted: 1570 Post(s)
Liked 638 Times
How does it feel to use the shoes the way that they are now?
If you can't tell the difference, I'd leave well enough alone.
If they bother you, then you have nothing to lose. Drill those puppies. Life is too short to put up with such a petty aggravation every time that you ride your bike.
Bikes: Gilmour road, Curtlo road; both steel (of course)
Quoted: 273 Post(s)
Liked 10 Times
OMG, could you guys make this any more complicated?
Lift the insoles and you will see a cut-out that willl allow you to access the nut plate.
Remove the nut plate.
Use a round file to lengthen the slots as needed.
Don't breathe the dust.
Replace the nut plate and insole and install the cleat.
Today, I believe my jurisdiction ends here...
Likes For rmfnla:
Bikes: CAAD 10 2105
I could not remove the nut plate as the cut out was super glued shut, but I got my old man to use some of his tools to slowly file and drill out the bottom.
Here are the pics. I don't think the material is carbon, seems more like hard plastic with a bit of nylon coating, but I might be wrong.
Went for a quick spin, much better improvement, but will follow this up with my bike fitter in next fort nights time. It took me 30 minutes to try and accurately determine where the cleat should be at since I don't have a round bulge in my foot, had to make a educational guess and feel on the pedals.
But thanks for all the replies from the forum.
Keepin it Wheel
Quoted: 22 Post(s)
Liked 2,719 Times
Bikes: All 80s Schwinns: 88Prologue, 88Circuit, 88Ontare, 88KOM, 86SS, 88Tempo, 88V'ger, 80V'ger, 88LeTour, 82LTLuxeMixte, 87 Cimarron, 86H.Sierra, 92Paramount9c
Quoted: 188 Post(s)
Me too, but I also hate hot sweaty (and resulting in stinky feet) so I just ditched the shoes all together.
Now cool dry happy feet! Cheaper too!
Bikes: CAAD 10 2105
I will give these shoes ago for 1 year, if any discomforts my next shoe will be the Bonts, should of done research before my purchase.
Quoted: 273 Post(s)
Liked 10 Times
BTW, have you noticed my signature line?
It's from the movie Silverado. There's another line I love, by Linda Hunt; "If the world doesn't suit you, change it!"
That's why we have tools...
Keepin it Wheel
Quoted: 22 Post(s)
Liked 2,719 Times
Question: what are the screws at the toe for? Is that front toe-plate somehow a replaceable wear item?
Keepin it Wheel
Quoted: 22 Post(s)
Liked 2,719 Times
Interesting, I never heard of that before.
Here's another of my favorite lines: "...Jake...fell off his horse...?" And: "I think there's only a couple a guys up there, and this *******'s one of them!"
OT, I know, but I LOVE Silverado.
Quoted: 273 Post(s)
Liked 10 Times
<Cough> One of my favorite movies. And the line is: "the world is what you make of it friend, If it doesn't fit, you make alterations." (Which doesn't change the sentiment of your quote.)
I became friends with James Gammon, the actor who played Dawson, who spoke the last line in your post; his daughter lived in my building. I saw him in the elevator one day and said that line to him and cracked him up. Great guy; was so sorry when he passed.
BTW, Silverado is never OT...
Quoted: 99 Post(s)
Liked 9 Times
I have the same issue, bought some Northwave Celzius winter shoes and I cannot move cleats back as I have them on my Shimano shoes. I prefer cleats more towards the back instead directly under the ball of my foot. I would still need to move cleats about 10-12mm back.
First problem is these shoes are winter shoes and when you remove the insole you cant access cleat plate, inside of the shoe is shut for insulation.
Looking from the bottom of the shoe, the cleat is at most backward position, I would want to put them to the red dots approximately, but the cleat plate extends beyond screw holes (until the blue line). So to move the cleat to red dots, the cleat plate would need to move that much beyond, and then I try to push with something from the inside I can feel that actually the slot ends somewhere around blue line, so even if I drilled from the bottom to the red dots, the cleat plate couldnt move backwards any more.
I am so pissed, I dont understand how can there be such difference in cleat position between Shimano and Northwave, I can move cleats on my Shimano 15mm backwards compared to cleats on the Northwave shoes.
